Rear differential swap question, "will it work"
Old 02-02-2011, 02:08 PM   #1
pyro13g [OP] pyro13g is offline
pyro13g will become famous soon enoughpyro13g will become famous soon enough
pyro13g's Avatar
pyro13g's Tacoma Gallery
I have an 07 5-lug 4 banger and i have done some research on re-gearing and the cheapest route would be to swap 3rd members with another truck if i can find one. The question is can i swap mine with that of an 2000-2004 year truck? ECGS wants to charge me $500 to build me one using used parts! Plus they want mine in return! 4-wheel parts wants$700 to build it there, but if i buy one on egay its only like $300-$400 and less money for an 00-04 rear differential.
Will the old style fit/ work?
Why do you ask that im so cheap?
Answer: College Student (were all broke you know if you've been there for any amount of time)
Old 02-02-2011, 03:35 PM   #2
JKD JKD is offline
JKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shed
JKD's Avatar
JKD's Tacoma Gallery
I'm fairly sure the track was narrower on the previous generation truck.
Old 02-02-2011, 04:27 PM   #3
Bullwinkle J. Moose
bjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shed
bjmoose's Avatar
bjmoose's Tacoma Gallery
Rear, maybe
Front no.
Old 02-03-2011, 11:14 AM   #5
pyro13g's Avatar
So correct me if I'm wrong 08whitetaco but according to this page i can interchange my rear diff with the same model truck from 95' and up. .???
Btw great find on the website!
Old 02-06-2011, 03:10 PM   #6
pyro13g's Avatar
Here is what mine looks like... so if i find one that looks the same i should be in business right?
Old 02-06-2011, 08:18 PM   #7
Solid Axle FTMFW!!
Supra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shed
Supra TT's Avatar
Supra TT's Tacoma Gallery
If it doesn't have a diff locker, than yes it can be swapped... at least thats what I got from that site. If you pull your 3rd, buy a gear set, and bring the 3rd member in to a shop, it shouldnt cost more than $400 total.
Why do you want to regear?
Old 02-07-2011, 06:34 AM   #8
pyro13g's Avatar
I would like 4.10 but they are only made by the factory for some reason not even east coast gear supply had any 4.10 they wanted to sell me a used gear set! If i could find a used 3rd member with it already in it that would be ideal. However if it's a lot of trouble ill. Just get it in 4.56
Old 02-07-2011, 06:58 AM   #9
afd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shed
afd23a's Avatar
afd23a's Tacoma Gallery
4.56's will probably be overkill unless you're going to be running 35" tires. If you're going for 4.10's then it's most likely going to be a used set that someone took out of a truck, unless you order the gears from Toyota. The differentials that will work with your truck are non-elockers that have the new style bearing cap. The bearing cap is shown in the picture below. It's what the bolts are being removed from in the picture.
Old 02-07-2011, 11:05 AM   #10
Nom Nom Nom
05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed
05RedTaco's Avatar
05RedTaco's Tacoma Gallery
www.marlincrawler.com offers build 3rd members with 4.11:1 gears.
When I re-gear, I will be going with 4.56:1 gears. Right now I am running 31's, but will be switching to 33's and the 3.33:1 gears are hurting a lot, I gotta drop two gears to accelerate on highway.
Old 02-07-2011, 11:09 AM   #11
Trifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shed
Trifenix's Avatar
Trifenix's Tacoma Gallery
What size tires are you going to run? If you are auto, you should get 4.56 if you can find them, but 4.10's are most prevalent. 96-04 non e locker axle 3rd members should fit.
Old 02-07-2011, 12:19 PM   #12
pyro13g's Avatar
I'm currently running 30" tires and may upgrade to 33" in the future after these get bald. I think my ratio currently is 3.58 and its so sluggish to accelerate and it feels really loaded down at 60 mph and 65 mph only turning 2k RPMs at 65 mph. At 55 it turns a little over 1500 RPMs and it's good for fuel milage im sure but I rarely get to go that fast. 4.10 seems to be the magic ratio but finding a used 3rd is hard but then again im only looking on egay and craigslist... Maybe i need to search a few local junk yards?
Alternative Differential Locker Mod. by "dbbd1" toku58 2nd Gen. Tacomas 6 08-18-2014 06:57 PM
"Toyota 4x4 specific swap meet" Petaluma CA Rucas Northern California 10 07-09-2011 07:01 PM
Axle Wrap, "Lurch", "Clunk When Stopped" question closed31 2nd Gen. Tacomas 21 07-11-2010 02:43 PM
3" toytec lift rear differential drop question.... tommyboy2929 Suspension 6 12-25-2009 07:23 PM
Another tire/rim/"will it work?" Question! jefferson Wheels & Tires 11 10-26-2009 08:32 PM
