2007 Steering issue
Old 02-14-2011, 08:10 AM   #1
mdcteague [OP] mdcteague is offline
mdcteague is on a distinguished road
Army:
mdcteague's Tacoma Gallery
2007 Steering issue
Steering - Issue
2007 SR5 - 4cyl - standard - 68,000mi - A few weeks ago I had some issues with hard steering - (during some really cold weather - 10deg) - checked ps pump and it was very low on fluid - I got some dexron ATF as recommended and topped it off - now a few weeks later - the steering is hard to turn- and it almost won't return to straight after making a turn. I have checked the gear box and rack & pinion - no leaks--- very strange - I really hope I don't need a new rack
Old 02-15-2011, 07:24 PM   #2
MushyB is on a distinguished road
MushyB's Avatar
MushyB's Tacoma Gallery
Send a message via AIM to MushyB
check your steering shaft u-joint. it's located on the driver's side of the engine bay, you can follow it from where the shaft comes out of your firewall and down to the u-joint. spray it with some pb blaster and work it with the wheels off the ground or just by driving it. if that's the problem you can either spray it down a lot to make it really clean and lubed, or replace it. i found it easiest to spray the u-joint from under the vehicle from the side of the skid plate. this happened to me a couple years ago and after this remedy it happened once again last year. this year it hasn't happened again (knock on wood) haha. my friends dad had the same problem and opted to have the shaft replaced for x amount of dollars. me... i'd rather spray it for a 5 dollar can of weasel piss. the salt and corrosion up here in mass really gets to that thing! good luck, hope that works for ya, keep us posted if that's the problem.
Old 02-16-2011, 08:40 AM   #3
Army:
steering issue
Thanks - that was exactly the problem - $3 woth of kroil and problem solved
Old 02-16-2011, 09:19 AM   #4
MushyB's Avatar
good deal. let me know if you come up with any ideas for a boot or cover for this.
Old 04-28-2011, 06:16 PM   #5
FLyhighdp is on a distinguished road
FLyhighdp's Avatar
FLyhighdp's Tacoma Gallery
same problem for myself... I was actually more surprised that I found write-up so quick. I'm lovin "tacomaworld" more and more everyday! Thanks for the help guys!!
Old 05-02-2011, 11:12 PM   #6
MushyB's Avatar
glad we could help!
Steering issue T Fades 2nd Gen. Tacomas 1 10-06-2011 09:56 AM
Power steering / VBelt issue...??? Mr.Tacoma 2nd Gen. Tacomas 1 08-29-2011 06:23 PM
power steering issue? maybe? danteisme 2nd Gen. Tacomas 2 03-13-2011 07:45 PM
HELP!!! i got steering issue.. i dont know what else to do bbravomTaco Technical Chat 13 03-13-2010 01:15 AM
Power Steering issue cordillera 1st Gen. Tacomas 0 03-03-2010 03:57 PM
