remove lower grill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AsianAnts, Feb 24, 2011.
  1. Feb 24, 2011 at 9:40 PM
    AsianAnts
    AsianAnts [OP] just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    am i blind ? i cant find and threads on how to remove lower grille...any help would be much appreciated... thanks
  2. Feb 24, 2011 at 10:04 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Is this a thin grill insert in your front bumper?
    If so then there appear to be MANY tutorials on R&R on the Internet. Here is a good step-by-step one with color pictures here.
  3. Mar 4, 2011 at 10:23 PM
    AsianAnts
    AnT
    no its not a thin grill insert... its not an x-runner
  4. Mar 4, 2011 at 10:28 PM
    toothaker1219
    toothaker1219 Well-Known Member
    On your front bumper? The plastic grille insert is molded with the bumper (or is heated to the bumper by melting tabs), only way to get the grille out is to cut of the center part or break the melted tabs.
    All 05-11 Tacoma Front bumpers are the same
  5. Mar 4, 2011 at 10:42 PM
    AsianAnts
    AnT
    trying to remove the bumper soo its easy to dremel and do the satoshi mod..
  6. Mar 4, 2011 at 11:20 PM
    toothaker1219
    Im not exactly understanding where your going with this.. If your taking about Satoshi'ing the lower grille "insert", you will have to take off your bumper, or leave it on the truck and be SUPER careful about cutting, fiberglass'ing, and bondo. Dont want to get that stuff allover your new truck
  7. Mar 5, 2011 at 8:33 AM
    AsianAnts
    AnT
    soprry for the confusion..yes, im talkin about satoshing the lower grille... and i want to take off the bumber soo its easier to work on rather than leaving it on the truck and being super careful.. soo im trying to find a how to remove your bumper...haha
  8. Mar 5, 2011 at 12:02 PM
    toothaker1219
    Ohhhhh ok, its all good man.
    I would still mask everything off (obviously), But to take off the bumper "skin" you will have to remove your grille, headlights, and the lower trim piece underneath your headlights.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/60788-front-bumper-removal.html
    Post #2... once all the snaps are taken off, look closely at what you see that is holding on the bumper, and unscrew it or pop it off- Take your time.
  9. Mar 5, 2011 at 12:40 PM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Skillsaw is lazy way:cool:
  10. Mar 6, 2011 at 9:11 AM
    AsianAnts
    AnT
    yup! got it yesterday... gutted the plastics in the middle... sanded it and filled the gap with epoxy... today im gonna but another layer of epoxy, sand it again, install the screws via epoxy to hold the mesh down ...primer and paint, install mesh and install the bumper back on!
  11. Mar 6, 2011 at 9:12 AM
    AsianAnts
    AnT
    was thinking of putting the TOYOTA emblem spread apart on that lower grill.. any thoughts?
  12. Mar 6, 2011 at 6:14 PM
    AsianAnts
    AnT
    i finished my lower grill and triangles... had a hard time putting the bumper back on... and missed one of the bottom clips because it got bent in D:
  13. Mar 6, 2011 at 7:39 PM
    pinktaco808
    pinktaco808 Hot Steppa
    this is what im doing too. what kind epoxy you using???
  14. Mar 7, 2011 at 4:01 PM
    AsianAnts
    AnT
    2 part plastic epoxy... u can find it at any home store and possibly and auto store as well.
  15. Feb 4, 2012 at 2:15 PM
    octacorunner
    octacorunner Well-Known Member
    G
    Orange County
    11 DCSB
    t|x pro rims, trd exhaust painted flat black, retrofit hids on oem smoked headlights, weathertech digifits, interior & exterior LEDs, console vault, 20% tint (need to install: eyelids, lower grillcraft, satoshi by homer)
    hey so did you find a thread that shows how to remove the bumper cover? i'm trying to do the same thing you're doing but having trouble finding a thread with info
  16. Feb 4, 2012 at 6:26 PM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    follow the link in the second post, the first 12 steps apply to non x-runners as well
    there is 3 push clips on the top, 4 on the bottom, 4 screws on the bottom and a screw and pin in each wheel well
