2011 taco HID problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lopezoscar03, Mar 5, 2011.
  1. Mar 5, 2011 at 7:18 PM
    lopezoscar03
    lopezoscar03 [OP] Well-Known Member
    lopezoscar03@gmail.com
    hey whats up everyone. i order two sets of HIDs for my truck. 55w h4 hi/lo kit and a 35w h10 kit for the fogs. the fogs operate perfect but headlights are different. the driver side works perfect but the passenger light doesnt. i have turn on and off the light switch a few times and then it turns on and stay on. its weird. i called DDM tuning and they said it might be the truck cause we tried different test and they test supposably show that the ballast and bulb are good. what are your thoughts on this? all help is welcome
  2. Mar 5, 2011 at 8:53 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    do you have the extra harness?
  3. Mar 6, 2011 at 6:09 AM
    lopezoscar03
    Yes i do have the extra harness connected. I have the power cable going to the battery. The two grounds connected to some grounds on the car. I am thinking maybe switching the bulbs around. Any thoughts
  4. Mar 6, 2011 at 6:10 AM
    lopezoscar03
    Should i run two seprate harness. I one for each bulb?
  5. Mar 6, 2011 at 7:29 AM
    sandjunkie
    Aaron
    OC
    not sure. I had the same problem with DDM in my jeep. I am hesitant to put them in my tacoma
  6. Mar 6, 2011 at 11:43 AM
    lopezoscar03
    any advice???
  7. Mar 6, 2011 at 11:47 AM
    meeestirg
    meeestirg Well-Known Member
    Vance County, NC
    where are you located? if you are close to LA, come to me and i'll help you find out what the problem is.
  8. Mar 6, 2011 at 1:30 PM
    lopezoscar03
    miami my friend lol
  9. Mar 6, 2011 at 1:35 PM
    erion109
    erion109 Well-Known Member
    Jayson
    Nashville
    06 TRD SPORT
    Weathertech FR & RR, DDM Tuning HID 55W 5000k Bi-Xenon, ARE topper, Yellow painted fog-lamp mod, anytime fog-lamp, Ipod interface, Red Top OPTIMA, Bilstein 5100s and 1.5 Toytech AAL, Redline Hoodstruts and EZdown tailgate.
    If you bought the kit with the slim (digital) ballast, that could very well be you're issue. I went down the same road for several months and after DDM sent me two different full sets, someone there got smart and said they have had some issues with the digital ballast working with our trucks. I didn't think I would want the analog ballast, but they fire just as fast, work every time and I no longer have to cycle my switch to get my passenger side to fire. Also, if you have the hi/lo kit, you don't need the extra harness they sell. The same guy told me to take it off and only run the harness that came in the hi/lo kit. Mine have been working perfectly for about 6 months now (knock on wood). Good luck!
  10. Mar 6, 2011 at 1:37 PM
    lopezoscar03
    so i dont need a harness. just plug them in like any other kit?
    i also have their raptor kit
  11. Mar 7, 2011 at 12:00 PM
    lopezoscar03
    still looking for some help
  12. Mar 10, 2011 at 9:28 AM
    meantaco
    meantaco Well-Known Member
    Andres
    2005 Prerunner. Gone,but not forgotten.
    Retrofit,bull bar,hellas and color matched grill.
  13. Mar 10, 2011 at 10:26 AM
    lopezoscar03
    thanks for the bump cause i am still having the issue and i have no idea what to do
  14. Mar 23, 2011 at 8:22 AM
    ninja28
    ninja28 What am I supposed to put in this box?
    Mario
    North Las Vegas
    2010 4X4 DC TRD Off-Road MGM
    More to come
    Bump
    I'm having the same problem. drivers side works intermittently and the passenger light is on the fritz. I don't think theses harnesses are working like they should. help please
  15. Mar 23, 2011 at 8:27 AM
    T@co_Pr3runn3r
    T@co_Pr3runn3r XXXXXXXXXXXXXXXXXXX
    08 RC Prerunner SR5
    Smells like slim ballast issues from post above. Poster got regular balasts and hasn't had issue since..........
  16. Mar 23, 2011 at 8:50 AM
    ninja28
    Mario
    North Las Vegas
    More to come
    I used the large analog ballast I have for my fogs and I'm having the same problem. also, I don't know if I'm talking out my ass, but it seems like I only ever have problems with the HID's when it's raining. (not sure if that related)
  17. Mar 23, 2011 at 3:42 PM
    jerysan
    jerysan Well-Known Member
    San Diego
    09 PreRunner TRD Off Road SB
    Flowmaster 40 Delta Flow, K&N Air filter, TSB Rear AAL with 1" Block & 5100's, OME 885x with OME Nitrocharged and Toytec Top spacers, Built Right UCA's , Satoshi Grille, HID's, Bull Bar,
    Have the same problem with my 09. DDM has replaced everything and the problem still persists. They said that I needed to install a resistor on the passenger side....i think its crap. I've heard the raptor kit will work, but haven't tried it yet.
