Dakar springs with 3degree shims and D29xl
Old 03-27-2011, 08:02 AM   #1
crf69 [OP] crf69 is offline
scraping my emblems off my plasti-dip
crf69 is one of the sharper tools in the shedcrf69 is one of the sharper tools in the shedcrf69 is one of the sharper tools in the shedcrf69 is one of the sharper tools in the shedcrf69 is one of the sharper tools in the shedcrf69 is one of the sharper tools in the shedcrf69 is one of the sharper tools in the shedcrf69 is one of the sharper tools in the shedcrf69 is one of the sharper tools in the shedcrf69 is one of the sharper tools in the shedcrf69 is one of the sharper tools in the shed
crf69's Avatar
crf69's Tacoma Gallery
are the center pins gonna be long enough?
i searched and i searched.....till i could search no more
Old 05-25-2011, 06:45 AM   #2
crf69's Avatar
bump lol
Old 05-25-2011, 06:54 AM   #3
MAXTacoma is one of the sharper tools in the shedMAXTacoma is one of the sharper tools in the shedMAXTacoma is one of the sharper tools in the shedMAXTacoma is one of the sharper tools in the shedMAXTacoma is one of the sharper tools in the shedMAXTacoma is one of the sharper tools in the shedMAXTacoma is one of the sharper tools in the shedMAXTacoma is one of the sharper tools in the shedMAXTacoma is one of the sharper tools in the shedMAXTacoma is one of the sharper tools in the shedMAXTacoma is one of the sharper tools in the shed
MAXTacoma's Avatar
MAXTacoma's Tacoma Gallery
Send OZ-T a pm or look at his threads. He ran into the same problem. I didn't get axel shims with mine, instead I got a drive shaft spacers.
Old 05-25-2011, 06:58 AM   #4
crf69's Avatar
pretty sure he didnt add the D29XL.
pretty sure
Old 05-25-2011, 07:07 AM   #5
MAXTacoma's Avatar
pretty sure
No he didn't add the D29XL but he extended his center pins long enough for the AAL/shims. Here it is. THANKS OZ-T
Old 05-25-2011, 07:09 AM   #6
crf69's Avatar
yeah i got those spacers also....
i should be good i hope.
Old 05-25-2011, 07:48 AM   #7
near the Tannhauser Gate
OZ-T's Avatar
OZ-T's Tacoma Gallery
You should be fine , the Dakar centring pin is about an inch extra long on the top of the pack , the collar is only about 3/8" and the overloads are about 1/2" thick .
Old 05-25-2011, 08:54 AM   #8
OZ-T's Avatar
Originally Posted by PSU Taco85 View Post
x2- I would think that the centering pin has extra room to spare. Plus OME designed the leaf pack to add the extra leaf, that is probably why the pin is so long. If you install the D28xl, you will probably not have to drill out your stock bumpstop, another added benefit of the extra leaf!
We just cut off the extra bolt length when we were done .
Old 05-25-2011, 09:02 AM   #9
OZ-T's Avatar
More than one way to skin a cat. Only problem I see with that would be if you ever needed to take the leaf pack apart, the end of the thread is probably stripped and jagged and you'd need to buy new centering pins. I couldn't think of a reason to ever take it apart though, besides adding the extra leaf.
The nut is on past the cut so it would be no problem getting it off , I would just replace the centering pins if I ever added the extra leaf , I think they are about $8 a pair
Dakar Springs elk340 Suspension 6 05-18-2011 05:23 PM
ome dakar springs allian04 Suspension 2 04-07-2011 09:44 AM
Finally new Dakar Springs!! GearBox Suspension 13 12-31-2010 07:51 AM
Dakar springs BFA Suspension 5 05-12-2010 04:27 AM
