Bilsteins at 2.5", AAL, Spidertrax- Before/ After
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeenyusSB, Mar 27, 2011.
  1. Mar 27, 2011 at 10:34 AM
    JeenyusSB
    JeenyusSB [OP] Well-Known Member
    Stock
    Before
    After
    Before
    After
    Before front
    After front
    Before rear
    After rear
    Spidertrax
    A comparison shot if you have a 4' ladder
    The shadow kind of sucks but its to cold to take more. Hope this helps some people with a lift decision.
  2. Mar 27, 2011 at 11:06 AM
    Eman5pt0
    Eman5pt0 Well-Known Member
    E
    NY
    how much higher does the rear sit with the 2.5 AAL
    im going with the same similar but i dont know if i want 2aal or 2.5 . i know it will
    ill be ass high ether way but i eventually want coil springs, which aal will give it more of an even look with the 5100's coil springs ?
  3. Mar 27, 2011 at 12:05 PM
    JeenyusSB
    This is actually the 2" aal from toytec. I set the 5100's to 2.5" the back end still sits up higher then the front.
  4. Mar 27, 2011 at 12:13 PM
    sambojee
    sambojee Well-Known Member
    Sam
    Iowa
    2011 TRD OffRoad
    Bilstein 5100 all around set at 2.5. 1.5 AAL in the rear. 265/75/16 Hancook Dynapro MTs on Black Moto Metal 951s. Black badges. Aftermarket grill. TRD seat covers.
    i have the same set up, 5100s set at 2.5 but i have 1.5 AAL and its almost perfectly level. why did u get spacers? were ur tires close from rubbing on the uca? im thinking about getting wheel spacers cus they rub when im at full lock and im scared when i go offroading they r gunna rub like crazy.
  5. Mar 27, 2011 at 12:31 PM
    JeenyusSB
    I have the spacers just for the more aggressive stance. Im getting new wheels and tires soon. Which size tire do you have. I plan on getting 265/75/16.
  6. Mar 27, 2011 at 1:09 PM
    sambojee
    Sam
    Iowa
    2011 TRD OffRoad
    i have 265/75/16 and they r really close to my liking. how big r ur spacers? 1.25?
  7. Mar 27, 2011 at 3:14 PM
    JeenyusSB
    Yup 1.25". The wheels on you truck in your sig looks good.
  8. Mar 27, 2011 at 3:18 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    OP - did you use the stock springs???
  9. Mar 27, 2011 at 7:51 PM
    BeardedWeirdo
    BeardedWeirdo Junior Mint
    Texas
    2010 AC SR5 PreRunner
    Barcelona Red Pop & Lock, Tint, New Shoes, Removed Rear Headrests, Grille(in the works)
    You didn't replace the UCA's did you?
  10. Mar 27, 2011 at 8:18 PM
    sambojee
    Sam
    Iowa
    2011 TRD OffRoad
    i have 5100s and i have stock everything (springs and ucas) exept for the shocks which r the 5100s set at 2.5
  11. Mar 27, 2011 at 8:19 PM
    sambojee
    Sam
    Iowa
    2011 TRD OffRoad
    thanks. they dont look as nice as they do in the pic but they work for now. yours look good tho
  12. Mar 27, 2011 at 8:52 PM
    JeenyusSB
    Yeah I did. I heard they were built to.
    No I didn't. when I get new tires I'm going to get it aligned and if it doesnt get in spec Im going to buy them.
  13. Mar 28, 2011 at 12:00 AM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    That was a good idea putting the ladder for comparison. I was wondering when someone would do that.
  14. Aug 11, 2011 at 12:40 AM
    jdmdcfan
    east WA
    dcsb
    Did you end up buying uca? I just bought the same setup as you. more than likely gonna install it on monday.
  15. Aug 11, 2011 at 3:50 AM
    SPENCAF
    SPENCAF Well-Known Member
    Jason
    Shiloh, IL
    2012 TX PRO 4X4
    AFE Pro dry filter, AttennaX, bed liner on front skid plate, AVID sliders, AVID light bar, KONG Storage Box, OME 2.5" 885 coils 1.5" AAL 265/75R16 Guard Dawgs
    How dose it ride with the front set at 2.5" with the stock springs? I thought I read some where on here that setting them at 2.5'' causes to much preload on the stock springs? I have know idea just trying to research this because I would like to do this mod once I get my truck.
    looks great!!!!
  16. Mar 15, 2012 at 5:31 PM
    trktwo
    trktwo Nagger
    tommy
    biloxi
    2015 MGM DCLB TRD Sport 4x4
    awesome truck, tag
