07 Tacoma Torque Specs for drive shaft
Old 03-31-2011, 10:47 AM   #1
SEAustin87 [OP] SEAustin87 is offline
SEAustin87 is on a distinguished road
Marines:
Gender: Chick
SEAustin87's Tacoma Gallery
I've been trying to find the torque specs for the drive shaft in an 2007 Toyota Tacoma Double Cab V6 TRD Off Road Package 2WD with the rear locking slip differential. I replaced all three u-joints yesterday because I finally got tired of the vibrations and squealing and it seems to be running much better... but I couldnt find the torque specs for the 4 bolts that connect the flange and the diff and also the 2 bolts that hold the middle of the shaft to the frame. I have them on there as tight as I could get them but would like to know the actual specs to make sure its up to par. Thank you in advance.
Old 03-31-2011, 11:04 AM   #2
Time is precious; use it wisely
Crom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shed
Crom's Avatar
Crom's Tacoma Gallery
I believe the answer for the four bolts is this: Torque: 88 N*m (899 kgf*cm, 65 ft.*lbf)
The center support bearing with the 2 mounting bolts is: Torque: 36 N*m (369 kgf*cm, 27 ft.*lbf)
Found here: http://www.ncttora.com/fsm/05+/data/...6ta/035001.pdf
From here: http://www.ncttora.com/fsm/05+/local...es/repair.html
Welcome to the forum!!!
Lubricating drive shaft or propeller on 2006 4x4 Tacoma's... DeeKay21 2nd Gen. Tacomas 179 01-06-2015 10:13 AM
Drive shaft bolt re-torque Homersimpson2 2nd Gen. Tacomas 6 04-20-2011 09:00 PM
Drive shaft Specs Torspd Technical Chat 5 06-25-2010 10:21 AM
Wanted: 2005 Toyota Tacoma Drive Shaft kyrac1978 Buy / Sell / Trade 0 04-15-2010 06:02 PM
01 tacoma drive shaft for sale $150 kenny Buy / Sell / Trade 0 11-29-2009 05:51 PM
