Squirrel Damage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hard Taco2, Apr 4, 2011.
  1. Apr 5, 2011 at 1:37 PM
    #21
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    So you use the humain "havahart" trap just to drown them? LOL. I think I would rather be shot than drowned alive
  2. Apr 5, 2011 at 5:04 PM
    #22
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    lol Bill Murray in Caddyshack keeps playing in my head
  3. Apr 5, 2011 at 5:05 PM
    #23
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    sit out there with a little 22 rifle and blow the fuckers away if they get within 15ft of your truck ha
  4. Apr 6, 2011 at 10:46 AM
    #24
    Mardi gras
    Mardi gras New Member
    Birmingham, AL
    11 PreRunner SR5
    Caught another one in my Havahart this morning. The traps make a head shot a sure thing. In B'ham it costs too much to drown them. Our sewer board charges quite more for gray water than potable water. Or is that grey Squirrel water?
  5. Apr 6, 2011 at 10:54 AM
    #25
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Get some old panty hose and put some mothballs in it. Place a few of these around engine area. It will drive them away. The last thing you want is to bait them into engine area. I have seen these little "Tree Rats" go into the vent systems of cars and chew through cabin filters and stink up the vents with waste.
    Or hire these guys
  6. Apr 6, 2011 at 2:18 PM
    #26
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    5100's and 883 OME Coils TRD Exhaust Deaver 1.5" AAL Rear Differential Breather Extension, 4WD Light, Tailgate Pipe clamp, Fog lights on while High Beams on, Carrier Bearing flip
    I feel for you subby. I just had my truck fixed due to the grey squirrels bastard little cousin, the chipmunk, gnawing on some wires. The little bastards ate through the wire harness for the knock senors and a little more. About an 18 labor hour fix to remove everything and put it back. I like the idea of a suppressed pellet gun...........
  7. Apr 6, 2011 at 2:55 PM
    #27
    o5iiawah
    o5iiawah Well-Known Member
    Tim
    Philly 'burbs, PA
    '11 4x2 access cab 2.7l
    Um, the squirrel is going to be hysterical thrashing around in the trap. Dunk him in the water and he's likely to take a great big breath and be dead in seconds.
    Unless you're going to get headshots every time on the little bastards, shooting them with a pellet gun can only maim them sometimes. Plus, there's no chance of ricochet and if you hide the trap behind a trash can it will be out of view of nosy neighbors.
  8. Apr 6, 2011 at 2:57 PM
    #28
    o5iiawah
    Tim
    Philly 'burbs, PA
    Fair enough, but if you keep a recycle bin full of water, pull the trap+squirrel out and bury him in a hole or on your compost you can re-use the water.
  9. Apr 6, 2011 at 3:04 PM
    #29
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    You can maybe try getting a couple of cats. I keep my Chevelle at my parents garage and squirrels were storing their nuts on top of my intake. I ended up getting a couple of cats and they stopped.
  10. Jun 14, 2011 at 1:36 PM
    #30
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Damn it .... I just went to change the cabin air filter and found a huge squirrel nest on top of the air filter. It was freekin' huge and took me an hour to vacuum it out.
    Any able to tell me how the heck they gain access to the air filter so I can block it with something?
    Thanks.
  11. Jun 14, 2011 at 1:37 PM
    #31
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    :eek:
  12. Jun 14, 2011 at 2:16 PM
    #32
    Taco-NB
    New Brunswick
    I pulled up the shroud that stop leaves from dropping into the HVAC.
    You can see the new, clean filter down the hole.
    The squirrels are getting in there by going up into the wheel well and through these little holes. The holes are down in the area next to the opening for the filter. There are located on the fender side.
    Gonna go buy a bunch of steel wool and stuff it in there and see what happens.
  13. Jun 14, 2011 at 2:20 PM
    #33
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Jason
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    i wouldnt stuff steel wool up there, just put mesh in there, even chicken wire would work so they cant get in.
    if they want in bad enough, they will pull the steel wool out
  14. Jun 14, 2011 at 2:37 PM
    #34
    Taco-NB
    New Brunswick
    How would I attach the mesh. With a bunch of caulking?
  15. Jun 14, 2011 at 3:12 PM
    #35
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    Steel Wool is raw steel, and will turn to a big brown ball of rust in no time. Get some mesh that is zink or galvanised coated to prevent rust, use a cardboard form to get a rough opening measured and cut a screen a bit larger than the hole. I'm talking the really thin mesh, to a human we can bend and form at ease, to a Varment, it's like a steel cage.
  16. Jun 14, 2011 at 3:15 PM
    #36
    Monkeysuncle
    Kevin
    Florida
    then force it into opening and make sure to tuck it in as far as you can, because the rat/squirrel most likely will not be able to pull it out, good luck
  17. Jun 14, 2011 at 3:19 PM
    #37
    Monkeysuncle
    Kevin
    Florida
    Or, you can buy "CHORE BOY" Copper scouring pads that are the copper cousin to steel wool. All crack heads use it as a filter in crack pipes. Ask your local dealer for the 4-11(information). Seriously there is a copper version sold in most hardwars stores, just don't get pulled over with it on the passangers seat.
  18. Jun 14, 2011 at 3:21 PM
    #38
    WCJR
    WCJR Well-Known Member
    W
    GOOGLE HOW TO GET RID OF RED SQUIRRELS. I THINK IT INVOLVES ONLY WATER A PAIL AND SOME SEEDS.
    MY FRIEND HAD A PROBLEM WITH RED SQUIRRELS AND CHIPMUNKS AND THE BUCKET WORKS. HE ALSO SAID JUST ONE BITE A BAIT BLOCK IS ALSO VERY GOOD. HE TOLD ME HE HAD TO SHAVE IT BECAUSE THEY WILL CARRY OFF THE CHUNKS AND IT MAY NOT BE EATEN. LITTLE PIECES ARE CONSUMED NOT STORED OR SO HE TELLS ME.
  19. Jun 14, 2011 at 4:46 PM
    #39
    ruler
    ruler Well-Known Member
    SoCal - Los Angeles - SGV
    08 Tacoma, TRD Sport, DC 4x4
    Fox Extended Travel Coilovers 2.5 (front), Fox 2.0 shocks (rear),Total Chaos UCA's, AllPro Expedition leaf pack, AllPro front plate style bumper,BHLM, GrillCraft MX series Grill, ATX Thug 17inch rims, Toyo Open Country MT (295,70,17), TRD CAI,Rear smoked LED tail lights, slimcubby HID Head Lights (50w 1200k), ADVMonster 60 Series 3600 Lumen LED Off Road Lights , Pioneer Avic-F700bt (navigation,head unit)
    wow that squirrel nest is crazy
  20. Jun 14, 2011 at 4:53 PM
    #40
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
