drive line vibration after 3" lift install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoman2u, Apr 16, 2011.
  1. Apr 16, 2011 at 6:51 AM
    tacoman2u
    tacoman2u [OP] Member
    ca
    TRD sport 4x4
    3" Readlift lift kit. spidertrax 1.25" spacers 285/70/17 Terra Grapplers
    I just installed a 3" readylift and now have drive line vibration between 20/30 mph. anyone know of a fix for this?
  2. Apr 16, 2011 at 6:56 AM
    bridgcat
    bridgcat Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    try a carrier bearing drop. It might fix some of it. The only true method of fixing it is to get a one piece drive saft I believe.
  3. Apr 16, 2011 at 10:48 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Try the CB drop first , cheap and easy
  4. Apr 16, 2011 at 10:49 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2 ^
    And have you gotten an alignment yet?
  5. May 14, 2011 at 7:16 AM
    tacoman2u
    ca
    TRD sport 4x4
    thanks for the info i just bought the CB drop. hope this works im getting pissed off. this is a brand new truck and i love the 3" lift. looking for nice chrome wheels with red beadlocks any suggestions?
  6. May 14, 2011 at 7:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Before you instal any drops, Check the torque of the U bolts. They need to be at 75#
  7. May 14, 2011 at 7:28 AM
    tony92629
    tony92629 Well-Known Member
    Tony
    Dana Point
    2010 White Tacoma Prerunner
    5100's all the way around. Front set at .85. Camburg Spindles. Camburg Uniball 1.25 UCA's. Total Chaos LCA skid plates. Custom Deaver 10 pack rear leaf spring. BFG AT KO's 285/70/17, Weathertech floor liners, Wet Okoles. Midland CB/PA, Firestick.
    Yes - Its the drive line angles. Shim in the rear and or CB drop in the front. Anything over 3" of lift changes the drive line angles which will create vibrations.
  8. May 14, 2011 at 7:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Lets not jump on the angle bandwagon yet. Of all the lifts I have installed on these trucks, NONE have had vibes after propperly torquing the bolts. Not saying its not the angles, but start with the easy stuff first.
    braik likes this.
  9. May 14, 2011 at 8:55 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    its def the angles, these trucks are fussy about that, i have the same thing. went with a 4 degree shim but thats too much, i just ordered a 2 degree shim and those will be almost perfect. if i were you id go with 2 degree shims, and flip the rubber that surrounds your carrier bearing so its upside down, thatll fix it
  10. May 14, 2011 at 9:31 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    The pinon angle must match the output shaft (1st drive shaft after the transmission) angle. If they don't match you're going to experience vibrations.
    See this Dana document for a comprehensive explanation. And this thread is also helpful.
  11. Jun 3, 2011 at 11:20 PM
    tacoman2u
    ca
    TRD sport 4x4
    thank you all for your suggestions. will start with the u-bolts, then the CB drop if that doesn't work. cant wait to get this resolved so i can get wheel and tire combo.
    thanks again
  12. Jun 3, 2011 at 11:28 PM
    OZ-T
    Peter North
    British Columbia
    Interesting , my Haynes manual , and my mechanic's online database both said 37 Ft lbs
  13. Jun 3, 2011 at 11:29 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    I just installed 5100's set at 1.75 with TSB leafs. Amazingly I have no real vibrations to speak of... Except the little (very slight) I have at 55-60, but that started after the TSB install.
    Judging by what I have gathered, the only angle that has changed is between the carrier and diff... With that being said, I think the only thing I should have to do is shims on the diff to return it to factory angles. One of these days I'll get around to trying it.
  14. Jun 3, 2011 at 11:32 PM
    tacoman2u
    ca
    TRD sport 4x4
    oh yeah, i got it aligned the same day i lifted it.
  15. Jun 4, 2011 at 6:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats wrong.
  16. Jun 4, 2011 at 6:53 AM
    tonyplanet
    tonyplanet Well-Known Member
    Glendora, CA
    09 Tacoma 4x4 TRD Off-Road
    enough to get me there
    I would go with 90# minimum. From what I have been reading in TTORA forums most are running 90-95#. And I think some guy quoted Deaver as saying 110#. But I do agree 37# is wrong and just crazy, and asking your axle to fall off.
  17. Jun 4, 2011 at 7:06 AM
    Crom
    Nick
    San Diego, CA
    Millions
    My u-bolts came loose after I got the TSB leafs. I presume this was due to the dealer tech following the wrong information in the FSM.
  18. Jun 4, 2011 at 8:27 AM
    OZ-T
    Peter North
    British Columbia
    I know what I am doing today .
    We re-torqued all my suspension components to the FSM specs last week , I've been driving around with my U-bolts @ 37 for about 5 days
  19. Jun 4, 2011 at 10:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    More than likely. Anyone who has been wrenching on suspensions for over a year, will know the FSM is wrong, and calculate the propper torque values.
  20. Jun 4, 2011 at 10:55 AM
    OZ-T
    Peter North
    British Columbia
    For those of us that haven't it would be nice if they corrected the fucking values in the FSM and Haynes manuals
