OFFICIAL 2nd gen 4x4 front differential bearing vibration thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BenWA, Apr 17, 2011.
  1. Nov 26, 2011 at 3:42 PM
    #41
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Yes, driver's side only. If DIY, bearing & seal will run about $25, axle $65-$100, oil $10.
  2. Nov 26, 2011 at 4:57 PM
    #42
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2023 Double Cab 4x4
    I don't know. Just a couple threads of many that say taking off helps with the vibes. The drop doesn't really looks like it does anything anyways. The before and afters are so minimal. I'd rather ditch the DD and lower the front down a 1/2". Just me though.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/173566-diff-drop-vibes.html
    http://www.tacomaworld.com/forum/2n...emoved-front-diff-drop-my-vibes-vanished.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/45398-so-i-took-my-diff-drop.html
  3. Nov 27, 2011 at 5:35 PM
    #43
    05Moose
    Jim
    Yes, taking it off helps with their vibes...when the vibes are NOT caused by the front diff bearing. I did plenty of experimenting with and without a DD when my bearing was noisy. The DD makes a very noticeable difference in lessening the vibes.
    EDIT: I am going to add another comment. I'm not a fan of the DD. Personally, I want as much clearance as possible. And it doesn't change the angles much anyway. But for lessening the vibe until the bearing is replaced, it is a worthwhile solution (albeit, a temporary one). Once I replaced my bearing, I did remove the DD.
  4. Dec 7, 2011 at 1:49 PM
    #44
    lundy
    Justin
    Reno, NV
    2023 Double Cab 4x4
    @05Moose, you think an RCD kit would solve my issue? Without having the bearing replaced? Dealer refuses to do say anything is wrong. I can't help but think that with angles like this (below) that vibe would have to go away... My control arms alone are 2/3rd's the price of the RCD so I'm really thinking about having a little sale and switching it up...
  5. Dec 8, 2011 at 6:48 PM
    #45
    dw77x
    dw77x Those are not my pants
    SE Wisconsin
    2009 Tacoma Sport LB
    5100's all 4 corners (front at 2.5"), rear tsb springs with 1.5" AAL, 265/70/17 General Grabber AT2's
    I had/have the same vibe described by many. 2.5 lift in the from and only really noticed it when cold and at about 40 mph, it would go away instantly in 4wd. I had it to the dealer twice for this issue and of course they said there is nothing wrong. I recently lowered my truck back down to the .85 setting and it's gone (so far).
    I know what happens when bearings fail. I want to change that front diff oil and see what kind of goodies are floating around in there. At the same time I want the dealership to see it first hand. I really hate the idea of paying them to do it.
    Since I had it in twice while covered by warranty will I have any coverage after the warranty is up when the problem comes back?
    I don't see how the lift would cause the issue but it sure makes it a lot more noticeable.
  6. Dec 9, 2011 at 9:20 AM
    #46
    lundy
    Justin
    Reno, NV
    2023 Double Cab 4x4
    Seems like the best put answer. ^^^ At least you got yours covered once. The dealer pretty much told me to go eff myself.
  7. Dec 9, 2011 at 10:20 AM
    #47
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    I dont know if i would call it a vibration or a grinding/growling like wheel bearings do.
  8. Dec 10, 2011 at 8:58 AM
    #48
    YNPFEO
    YNPFEO Active Member
    Yosemite National Park
    05 D-cab 4x4 All-Pro Hybrd bumper sliders
    285/75/16's Mickey Thompson Classic locks, Hella driving lights
    Looks like I'll need to take mine to a shop. The vibration is getting noticably worse....Anyone know if the LT tacomas are having issues like this?
  9. Dec 11, 2011 at 4:59 PM
    #49
    berg2065
    berg2065 Well-Known Member
    Phoenix
    11 reg cab 4x4
    5100's set at .85,eibachs, LR uca's, toytec 1.5" aal, ride rite bags, receiver hitch, ARE cap with bedrug, Thule rack, wet-okole cover, ultragauge, kenwood dnx5180 navi/receiver, ss rubi404 running factory doors and JL8
    Replaced the bearing this weekend. Vibe is gone for now, time will tell if it is a long term fix.
  10. Dec 11, 2011 at 5:31 PM
    #50
    glennv
    glennv Well-Known Member
    Update on mine. I brought it to a dealer and they checked it out. Natural they found nothing. I told them it only does it when it's cold and they must have run it 30 minutes after I dropped it off. I guess at least it's documented in their system. I'll wait to see if it gets any worse then I'll find another dealer. Just a quick question. Why does the vibe go way when it's hot? Wonder what would happen it I over filled the front diff.
  11. Dec 11, 2011 at 5:48 PM
    #51
    05Moose
    Jim
    So, any scoring on the old cv axle where it rode in the bearing? Curious how many others have had the scratches in theirs too (I've seen one other with scratches and another with pitting).
  12. Dec 11, 2011 at 7:48 PM
    #52
    lundy
    Justin
    Reno, NV
    2023 Double Cab 4x4
    Just an update. Brought my lift from 3" down to 1.5" (just the eibachs) and vibes are gone. It's nice to not hear or feel it.
  13. Dec 12, 2011 at 7:08 AM
    #53
    berg2065
    Phoenix
    11 reg cab 4x4
    i could not feel or detect any scoring, but it was polished where the bearing contacts.
  14. Dec 20, 2011 at 7:17 AM
    #54
    tim allan
    tim allan Well-Known Member
    apex, nc
    2017 double cab trd offroad
    what is the fix for the tundra? a new p/n bearing?
    I wonder what chase at ecgs has to say on the topic?
  15. Dec 20, 2011 at 9:13 AM
    #55
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Dropped mine off and they said they could not find anything. Will be doing a test drive with dealer tonight. Frustrating.
  16. Dec 20, 2011 at 6:27 PM
    #56
    TOYOTA 09
    TOYOTA 09 Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    I am dreading taking my truck in for this. So far my dealer has been good though....any tsb for this?
  17. Dec 20, 2011 at 8:00 PM
    #57
    Cartsjr
    Cartsjr Member
    Bhawk60
    NH
    2010 DBL Cab TRD Sport long bed
    3/1 Low Range offroad Lift, LT 275/70/17 tires
    New to the site. My 2010 Tacoma is having the exact problem as described here, growl, vibration at 30-40 MPH, worse when cold, goes away in 4WD. I have an appointment with my Toyota dealer here in Conord, NH. We will see how that goes...
  18. Dec 21, 2011 at 4:51 AM
    #58
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Denied. Tech declared BFG TKOs "bumpy".
    Drive it till it breaks.
  19. Dec 21, 2011 at 10:29 AM
    #59
    lundy
    Justin
    Reno, NV
    2023 Double Cab 4x4
    My front end vibration that goes away in 4wd was blamed on my rear drive shaft angle lol. I called corporate, I have a FTS coming to look at it soon.
  20. Dec 21, 2011 at 10:38 AM
    #60
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
    I'm in NH also, keep me posted on the outcome. How many miles do you have on the truck?
