Floppy Shaft Syndrome
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mjp2, Sep 26, 2008.
  1. Sep 26, 2008 at 10:47 AM
    mjp2
    mjp2 [OP] Living vicariously through myself Moderator
    Milton Juevo Portimous II
    NJ
    That title oughta grab some attention. :p
    Anyway, the 2-piece vibration-isolation design for the 6-speed shifters is crap and wears out over time.
    I since shoved a bunch of metal into the rubber bushing and epoxied everything in place to clean up some of the slop, but I know it's a temporary remedy.
    Anybody know of a company that makes a 1-piece replacement shift lever?
  2. Sep 26, 2008 at 10:51 AM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    It looks like you're tugging a little too hard on your stick :p
  3. Sep 26, 2008 at 10:53 AM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    C'mon, really, get with the times. This isn't 1925. There are better ways to stiffen your shaft without stuffing metal in it!:rolleyes:
  4. Sep 26, 2008 at 11:05 AM
    mjp2
    NJ
    "Whiskey Shifter" was my alternate thread title but I didn't think as many people would get the joke. :D
  5. Sep 26, 2008 at 11:31 AM
    DFPTaco
    DFPTaco It's TACO time!
    Josh
    Las Vegas, NV
    19 DC SB TRD OFF ROAD
    little lift, wheels and tires, prinsu rack, TRD Pro grille, some lights, and some scratches.
    dare I reccomend viagra?
  6. Sep 26, 2008 at 11:38 AM
    Ahaszard
    Ahaszard Active Member
    St Augustine, FL
    08 Black TRD Off Road Rugged Trail
    TRD makes a short throw shifter. I had one on my FJ Cruiser. Easy to install and really makes a big difference.
  7. Sep 26, 2008 at 11:40 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    first off, I doubt you really drive your truck that hard that you are going to wear out your shifter. Second off, you suck.
    What's your daily driver when your truck isn't running?
  8. Sep 26, 2008 at 11:41 AM
    mjp2
    NJ
    I have a 1995 Honda Civic that I bought for $500. Aw yeah! I'm cruisin' in the hooptie! :cool:
  9. Sep 26, 2008 at 11:43 AM
    mjp2
    NJ
    Is that a 1-piece design? I've seen that one available but haven't seen any good pictures or read much about the actual design. If it's similar to the stock design I'll most likely wear that one out too and be out another $300.
    You've had no issues with it?
  10. Sep 26, 2008 at 11:44 AM
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    Off topic, but wouldn't that signature be more appropriate for a Ford forum?:D
  11. Sep 26, 2008 at 11:57 AM
    Ahaszard
    St Augustine, FL
    It is similar to the stock shifter just a shorter throw. I have a stock shifter from a 07 FJ Cruiser in my garage. It is the same transmission and probably the same shifter. I you need it let me know and I send it to you for the cost of shipping.
  12. Mar 18, 2010 at 10:58 PM
    RelentlessFab
    Eric
    Sparks, NV
    Thread revival!!!
    My shifter has now gone floppy on me too! :( After a year and a half driving with my URD short throw and only 43K total miles on my truck, my shifter is getting a bunch of play in it from this isolator in the shaft. Are there any other remedies for this issue other than what was discussed above? I was thinking I could just cut the shaft off just below the coupling, then take a piece of solid steel rod with matching diameter, thread it so the factory shift knob threads on it, then weld the other end of it on to the remaining shift shaft and everything looks stock, but doesnt have the rubber isolating the shifter. I was thinking some harmonics and vibrations will be transferred through though as thats why the shifter was designed this way in the first place.... any thoughts about that?
  13. Mar 18, 2010 at 11:44 PM
    beetlejuice2275
    beetlejuice2275 Well-Known Member
    Reximus
    Queens, NY
    Drift inspired 08 Reg Cab
    custom ram air. blacked badges, hids, rewired front turn signals and park lights, URD short shifter, Pioneer t-screen (no nav), 10" 1200 watt.
    gayest thread title ever.
  14. Mar 19, 2010 at 12:12 AM
    RelentlessFab
    Eric
    Sparks, NV
    yeah, but considering who started the thread, would you expect any different? :rolleyes: :laugh:
  15. Mar 19, 2010 at 8:06 AM
    mjp2
    NJ
    I cut mine and welded a piece of chromoly tube in place of the 2-piece assembly. Also welded the URD piece on the end of the shaft to ensure zero play in the shifter.
    It's installed backwards in this picture but you get the idea:
    There's some noise from the transmission, but then my truck is so loud anyway that it blends in with everything else.
  16. Mar 19, 2010 at 8:06 AM
    mjp2
    NJ
    :D
  17. Mar 19, 2010 at 11:02 AM
    JKD
    JKD Well-Known Member
    Where is the bushing you are talking about?
    I know a guy who makes custom shifter bushings for Neons. Maybe he can make a solid polyurethane replacement for these.
  18. Mar 19, 2010 at 11:03 AM
    RelentlessFab
    Eric
    Sparks, NV
    Thanks Mike. I thought I remembered seeing that setup somewhere before and thought it may have been yours. How much noise/vibration is transferred? I mean I have M/Ts and a fairly loud intake/exhaust, but is it going to be annoyingly loud on top of those things? I dont want to have to crank my stereo any more than I already do.:laugh: :cool:
  19. Mar 19, 2010 at 11:06 AM
    98tacoma27
    Ben
    Not Beech Creek
    In the rare event of an erection lasting more than 4 hours, seek immediate medical help to avoid long-term injury.
  20. Mar 19, 2010 at 11:07 AM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    mjp2 loves the floppy stick
