05 tacoma stiff automatic gear shifter
Old 04-21-2011, 07:43 PM   #1
Jamie R. Cherry is on a distinguished road
Army: Reservist in the Army 1988
Jamie R. Cherry's Tacoma Gallery
I've only read one thread on this problem. Mine seems to come and go with the weather. Not sure what to do? Can anyone help?
Old 04-21-2011, 07:46 PM   #2
Poodoo
luk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shedluk8272 is one of the sharper tools in the shed
luk8272's Avatar
luk8272's Tacoma Gallery
Could you be more specific? Is there an issue with the shifter or the way the transmission itself shifts? The reason I ask is because my GF's 4runner was difficult to shift by hand, ended up having a plastic piece broken inside the console.
On a side note how do you pronounce the name of the city/town you live in? My brothers name is spelled Schuyler and pronounced Skyler.
Old 04-25-2011, 01:24 PM   #3
Stiff automatic shifter
Hey thanks for the reply. Its in the shifter linkage. The tranmission itself is fine. Not sure how to lubricate the linkage.
Yes my town is pronounced just like your brothers name except withe the ville on the end.
Old 10-08-2011, 05:20 PM   #5
over60 is one of the sharper tools in the shedover60 is one of the sharper tools in the shedover60 is one of the sharper tools in the shedover60 is one of the sharper tools in the shedover60 is one of the sharper tools in the shedover60 is one of the sharper tools in the shedover60 is one of the sharper tools in the shedover60 is one of the sharper tools in the shedover60 is one of the sharper tools in the shedover60 is one of the sharper tools in the shedover60 is one of the sharper tools in the shed
over60's Avatar
over60's Tacoma Gallery
Angry
I've had the same problem with my 2006 Taco...V6. auto tranny.
The shifter sometimes is VERY stiff, and I note that the cruise control will NOT engage when this happens, also Low gear and 2nd gear do NOT light up in the dash, as normal.....
This happened for the 3rd time yesterday..... I drove about 20 miles and then stopped and ran the shifter back and forth a few times and it cleared up.... Go figgure....
The first time it happened, I took it to the dealer..... It was NOT stiff when I got there.... they checked the linkage ane said everything was fine...(gave me a look like I was crazy).....!!
I too believe the problem is with at the consol end, because everything looks good under the truck....
Anyone else...??
Old 10-12-2011, 03:11 PM   #6
Unhappy Stiff transmission linkage.
I took my console apart and lubricated everything that had existing lube on it. Here is the catch, after a few days it started doing the same thing again.I think it is the small black plastic piece under the shifting mechanism. I'm going to remove it and see what happens. I'll re-post at a later date. Thank you.
Old 10-17-2011, 05:55 PM   #7
avelino is on a distinguished road
avelino's Tacoma Gallery
Got the same problem with my 05 tacoma. Problem comes and goes. I also thought it was something to do with the weather. Hopefully it is just the plastic piece.
Old 10-21-2011, 01:39 PM   #8
So it was sticking today, so I took the plastic out and that didnt seem to fix anything. When I put it in drive the dash "d" doesnt light up got to toggle between neutral and drive couple time for light to come on. Probably be back to normal tomorrow as usual.
Old 10-21-2011, 01:43 PM   #9
Say no to Bro
kirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shedkirkofwimbo is one of the sharper tools in the shed
kirkofwimbo's Avatar
kirkofwimbo's Tacoma Gallery
Check this link...shows how i fixed mine
http://www.tacomaworld.com/forum/2nd...r-problem.html
Old 10-22-2011, 07:09 AM   #10
thanks man. But the other day when it was stiff, I took the plastic piece out and went up and down through the gears and it was still stiff. I think i will try greasing the cable though. Maybe white lithium grease. let you guys know how it goes
Old 03-10-2012, 08:43 AM   #11
PINAYBABY is on a distinguished road
PINAYBABY's Avatar
PINAYBABY's Tacoma Gallery
shifter stiffness
hello all, my 2005 tacoma had the same problem: very stiff in shifting, and a fix engine light came on also, took to the dealership and they had to replace the shifter cable..last year in 2011..the dash lights for drive ,1st gear , etc. were not matching up to the desired gear that it was in..they fixed it and it was fine but just a little off on the dash lights though..i just worked around that til now..it seems to be getting stiff again and the dash lights seem to be still off a bit..didn't drive it for a month though, as i was on vacation, but i'll give it a little longer to see if get's worse..AGAIN
Old 06-02-2012, 06:55 AM   #12
Just wanted to give an update on the shifter problem. I washed the undercarriage of my truck and found that the problem started again immediatley after that. After a few days of warm weather it went back to normal. So to be sure I did it again. Hosed off under car and it happened again. So something getting moisture under the truck I believe is causing this problem. Now to figure out what.
avelino
Old 06-08-2012, 06:56 AM   #13
I've asked every mechanic I know and no one has an answer. If anyone has any suggestions I would really appreciate it.
Thanks in advance
Old 10-05-2012, 02:20 PM   #14
Gregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shedGregman is one of the sharper tools in the shed
Gregman's Avatar
Gregman's Tacoma Gallery
So anyone else with an older 2nd gen auto experiencing the stiff shifter? Mine has been intermittenly acting up too. It gets stiff and when I put it in gear the D light doesn't come on until I cycle the shifter back and fourth from D to 4th and back. I took all the plastic stuff off and its still stiff, so I think it must have something to do with the cable. Perhaps it needs some lubrication or replaced?
I'm going to give this a try:
http://www.tacomaworld.com/forum/tec...tic-trans.html
Originally Posted by DonG View Post
I removed the shift knob then the console on my 05 just snaps out whenpulled on from both sides. I removed the shift indicator cover by lifting outon the snaps on each side then removed the rubber slide and lubricated thelinkage and cable. There's a little switch just an inch left of the shifterwhen in park that overrides the break lock and I held that down while movingthe shifter back and forth through all gears. Be sure your parking break is onwhen doing this. Just took a couple sprays and several passes through the gearsand all is fine now.
Gotta get the power steering fluid changed now and hope it's not the pump.
Old 10-17-2012, 06:14 PM   #15
mauledriver is on a distinguished road
mauledriver's Tacoma Gallery
stuck stiff shifter
Gregman,
Exactly the same problem, I ride motorcycles so the taco sits sometimes for weeks before I use it. The shift problem has been going on since 2007. on the 2005 truck. I have removed the console, cleaned and lubed with extreme low temp grease, a little smoother but no real improvement. Shift out of park, no indicator light showing what gear, shift back and forth, indicator finally comes on, no 2nd or low gear available. Last month I ordered and replaced the actuator/shift cable an easy repair, just lube the transmission shifter bolting a couple days before you try to remove the bolts. No need to jack up the truck, all visible from below and in the cab.
The old cable was just fine!! due to a grease fitting mod I made years ago. Still suspected the cable, thus the replacement.
RESULTS: no improvement. The issue is corrosion of the shifter link arm on the side of the tranny, it just rusts up so bad it locks the shifter. The truck has 120K and is used to commute in crap weather of new england read: lots of salt. On extremely cold mornings of 20belowF it just gets worse! After oil undercoating the undercarrige it improved the most but the first big rain and I'm back to stiff to almost impossible to shift.
This weekend it has to be fixed as 25'f on the motorcycle is about this old guys' limit. Stay tuned..........
Old 10-17-2012, 06:18 PM   #16
Just noticed there seems to be alot of '05's in New England and Canada posting this same shifter problem..........?!!
Old 10-19-2012, 06:53 AM   #17
ANY TOYOTA TECHS OUT THERE WILLING TO CHIME IN ON THIS SHIFTER ISSUE....HAS TO BE SOMETHING SIMPLE...??
THANKS IN ADVANCE FOR YOUR EXPERTISE
Old 10-23-2012, 08:25 PM   #18
TacoManDan is one of the sharper tools in the shedTacoManDan is one of the sharper tools in the shedTacoManDan is one of the sharper tools in the shedTacoManDan is one of the sharper tools in the shedTacoManDan is one of the sharper tools in the shedTacoManDan is one of the sharper tools in the shedTacoManDan is one of the sharper tools in the shedTacoManDan is one of the sharper tools in the shedTacoManDan is one of the sharper tools in the shedTacoManDan is one of the sharper tools in the shedTacoManDan is one of the sharper tools in the shed
TacoManDan's Tacoma Gallery
Same stiff shifter here... I mean very very hard to even go back in reverse... Only difference is on mine it wont start... Shows it is in Reverse... UNREAL... Have taken it apart via shifter/console area... Sure wish a Toy Tech wouls assist us...
Old 01-23-2013, 06:16 PM   #19
TDHofstetter is on a distinguished road
TDHofstetter's Tacoma Gallery
Problem isn't specific to '05's, folks - I've got exactly the same situation with my '07.
I've crawled underneath with a helper tugging on the shifter lever, and all the linkage is moving easily UP TO where it goes into the transmission. THAT SHAFT moves very very stiffly if the truck's been sitting for more than a week, or only a couple of days in muggy weather.
I've tried shooting around that shaft with white lithium grease, but it didn't help; it looks a lot like the transmission is "inhaling" moist air and condensing it around that shaft, inside the tranmission case, resulting in rust buildup where we can't get to it without opening the case. I don't like the thought of having to pull the transmission apart to fix a sticky shifter, when the problem's likely to come back again later.
Upshot: Unless someone can come up with a pretty slick repair for it, I'm gonna' sell this thing & drive my M715 instead.
-- Tim --
Old 04-08-2013, 05:34 PM   #20
Well finally have an appointment with a real Toyo-Taco mechanic (ex-dealer) about this ongoing issue with the shifter. After reading most references on the A750F trans,
I don't think it's in the transmission---It's the shifter. The "fix" of straightening the dustcover follower just cleans the grit out of the two layers of plastic. Appointment is 4/8/2013, I'll post the findings next week, stay tuned.
Automatic shifter problem Sideways 2nd Gen. Tacomas 23 02-24-2014 11:45 AM
Stiff Shifter, Automatic Trans. Maddog721 Technical Chat 2 07-09-2011 02:20 PM
Does Automatic shifter need adjusted?? bruce1271 2nd Gen. Tacomas 3 03-16-2010 02:48 PM
Automatic-Wont go in 4th gear on dash light-shifter goes to 4 though. bruce1271 2nd Gen. Tacomas 0 02-18-2010 09:28 PM
automatic shifter EL TACOROJO 1st Gen. Tacomas 1 06-26-2009 06:09 AM
