my Hi-Lift install and other fun.
Old 10-21-2012, 02:53 PM   #21
4th MAW
ETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shed
ETAV8R's Avatar
Marines: MASS 6 El Toro
ETAV8R's Tacoma Gallery
So I have all the parts, drilled the holes larger in the L-brace but tried to use 1/4 inch to hold the hi lift. Wrong, the jack is too heavy. I am mounting mine to the side rail. Have you noticed any wear behind the mount as it hits the composite wall? Thanks.
Old 10-25-2012, 02:28 PM   #22
bkrdave36 is a name known to allbkrdave36 is a name known to allbkrdave36 is a name known to allbkrdave36 is a name known to allbkrdave36 is a name known to allbkrdave36 is a name known to all
bkrdave36's Avatar
bkrdave36's Tacoma Gallery
damn that was simple! I may try it out, but double up the L brackets to reduce the metal fatigue factor and add some strength...
I have the Hi Lift attachment that you hook on your wheels instead.
I carry a jack stand to put under the axle so that I have a solid (and safe) set up before working on the truck. At least that is my plan, I haven't had to do anything with it yet!
Old 10-30-2012, 06:17 AM   #23
NetMonkey [OP] NetMonkey is offline
NetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shed
NetMonkey's Avatar
NetMonkey's Tacoma Gallery
i havent noticed any wear.
Old 11-05-2012, 05:44 PM   #24
bkrdave36's Avatar
Net Monkey
What size are the bolts that are the "pins" for securing the jack to the actual brackets? Did you drill out the bracket any for these bolts?
Thanks!
Old 11-05-2012, 05:56 PM   #25
Go home if you don't like guns liquor and whores.
maxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shed
maxamillion2345's Avatar
maxamillion2345's Tacoma Gallery
IIRC i used a edit: 1/2" bolt with wing nuts for my mounts.
edit: way off
he used maybe a 3/8" ?
Old 11-05-2012, 06:10 PM   #26
hardcrazyace is on a distinguished road
hardcrazyace's Tacoma Gallery
dose the net for the cargo box come with truck when bought new or is it something have to buy extra? mine dident have it .
Old 11-06-2012, 12:07 PM   #27
NetMonkey's Avatar
mine came with the truck, but i didnt find it until i dug under the seats a year after i bought it
Old 11-06-2012, 12:09 PM   #28
NetMonkey's Avatar
edit: way off
ya, maybe 3/8"
Old 11-06-2012, 09:00 PM   #30
I owe it all to little chocolate donuts
JayDirt is one of the sharper tools in the shedJayDirt is one of the sharper tools in the shedJayDirt is one of the sharper tools in the shedJayDirt is one of the sharper tools in the shedJayDirt is one of the sharper tools in the shedJayDirt is one of the sharper tools in the shedJayDirt is one of the sharper tools in the shedJayDirt is one of the sharper tools in the shedJayDirt is one of the sharper tools in the shedJayDirt is one of the sharper tools in the shedJayDirt is one of the sharper tools in the shed
JayDirt's Avatar
JayDirt's Tacoma Gallery
"i watched a bunch of the product videos on the Hi-Lift website to make sure that i knew how to properly operate the jack. good thing too, because you can really hurt your self if you dont know what you are doing. so, had to test the jack out..."
Yep, that's why some call it the widow maker. We learned the hard way by not having the door open when lifting and letting it down and now there's a nice door scar...lol
Old 11-06-2012, 10:12 PM   #31
Originally Posted by bkrdave36 View Post
3/8 .... ok thanks!
I'd use 1/2 or at least 7/16
Old 11-07-2012, 12:25 PM   #32
4th MAW
ETAV8R's Avatar
Thanks for the info. I finally got pics of mine. I used 3/8" bolts and changed from 4.5" long to 3.5". I also used rubber feet to cusion the bolts that hit the composite sides...
Longer bolts stuck out too far:
So I switched them out for shorter ones:
Link to my mount build:
http://www.tacomaworld.com/forum/2nd...ml#post5957969
Old 11-07-2012, 12:37 PM   #33
Previously "MGMTacoFF"
CanisLupus is one of the sharper tools in the shedCanisLupus is one of the sharper tools in the shedCanisLupus is one of the sharper tools in the shedCanisLupus is one of the sharper tools in the shedCanisLupus is one of the sharper tools in the shedCanisLupus is one of the sharper tools in the shedCanisLupus is one of the sharper tools in the shedCanisLupus is one of the sharper tools in the shedCanisLupus is one of the sharper tools in the shedCanisLupus is one of the sharper tools in the shedCanisLupus is one of the sharper tools in the shed
CanisLupus's Avatar
Firefighter: Captain
CanisLupus's Tacoma Gallery
That little cargo net is for the center console I believe. Good write up.
Old 11-07-2012, 06:39 PM   #35
Midship909 is on a distinguished road
Midship909's Avatar
Midship909's Tacoma Gallery
Send a message via AIM to Midship909
Very smart idea I also have the same bike mounts you just saved me on buying custom hi lift mounts
Old 11-07-2012, 06:44 PM   #36
Granite Guru
Spoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shed
Spoonman's Avatar
Spoonman's Tacoma Gallery
Heads up- the hi lift is heavy as you know. i think it might swing a little when just hanging there.
Old 11-07-2012, 08:08 PM   #37
4th MAW
ETAV8R's Avatar
Yes it can swing a bit. But when I'm off road I usually have so much stuff packed back there it won't have much room to move.
Old 11-07-2012, 11:38 PM   #38
If you've got some strips of thin gauge metal and a way to cut it and weld it or just bend it you can make a pretty decent mount.
Not to knock yours!
[IMG][/IMG]
Old 11-08-2012, 12:08 AM   #39
4th MAW
ETAV8R's Avatar
That's the problem. I live in an apt with very few tools. Have to adapt and overcome.
Old 11-08-2012, 05:53 AM   #40
NetMonkey's Avatar
yup... it rattles around a little bit when i go over bumps.
Install Ez Lift 3" FRONT LIFT STRUT SPACER KIT? TEX357 Suspension 44 11-22-2013 12:47 PM
Well guys, it was real and it was fun....and hell it was even real fun..... SoftShellTaco 1st Gen. Tacomas 2 01-29-2012 01:44 PM
suspension lift or body lift which is easiet to install? 1999tacotrd 1st Gen. Tacomas 11 05-01-2011 08:15 PM
Did you install your ToyTec Lift on your own or get an install?? ChopperCam 2nd Gen. Tacomas 18 01-13-2011 09:25 PM
After lift install?? cluck024 Suspension 5 11-20-2010 06:17 AM
