Air Bag ? light on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HiTec, May 31, 2011.
  1. May 31, 2011 at 5:25 PM
    HiTec
    HiTec [OP] Member
    IN
    98 SR5 Ext 4x4
    :(Has anyone else had a problem with the air bag light? At about 50k my air bag light came on and the manual says take to dealer for service. Dealer says will cost at least $80 to diagnose problem. I am thinking this is not a wear item and should be taken care of free of charge.
    Thanks in advance,
  2. May 31, 2011 at 5:55 PM
    Metal Magic
    Metal Magic Active Member
    Stockton Ca
    2007 tacoma access standad
    same thing happened to me, turns out it was an airbag squib (airbag spiral cable) Search around you will find a lot of info here on the subject. My advice is take it to the dealer NOW ! ! ! ! with this light on your airbags will not deploy. I went in at 65,000 and was out of warranty, after making a fuss (which I never do) I was given a 50% discount due to my past experience with the dealership.
    Short story, I would at least check it out . . . eat the 80 bucks and maybe the 500 dollar repair will still be under warranty, also, your safety is worth a few twenties
    oh and check the connections under the seat . . . . . . maybe something knocked one lose ? I was told this could set off the SRS light
  3. May 31, 2011 at 6:01 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Take it to autozone to get the code read for free, before you go to the dealer and pay.
  4. Jun 1, 2011 at 8:08 AM
    reg boulette
    reg boulette Well-Known Member
    Just off the top of my head and having no access to the manual - doesn't the restraint/seatbelt system have a longer warranty period than the usual 3 years/ mileage?
  5. Jun 2, 2011 at 7:20 PM
    HiTec
    HiTec [OP] Member
    IN
    98 SR5 Ext 4x4
    :):)Just got back from dealer in Bloomington,IN. Great place to go for service. Almost 51k on truck and I am second owner and I do not have anything bad to say about them. They told me it would be $49 diagnostic fee but it would be waived if it was covered under warranty. Long story short it came back spiral cable bad and fixed under warranty and even gave me a rental car. This is what I think you should expect from Toyota. No hassle:):)
  6. Jun 7, 2011 at 2:38 AM
    Badbud
    Badbud Member
    BUD
    Alanta ga
    2007 prerunner
    Where is the spiral cable?
  7. Jun 7, 2011 at 8:09 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    It is under the driver's side airbag.
  8. Jun 7, 2011 at 10:13 AM
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    in the steering wheel?
  9. Jun 7, 2011 at 10:18 AM
    Murd3rd
    nice, is there a way to check it yourself and change it out if it is bad? im not very knowledgable on the SRS system, but would rather like to avoid the dealer if my warranty wont cover it
  10. Jun 7, 2011 at 10:24 AM
    Murd3rd
    got a link to a write up of how to test it?
  11. Jun 7, 2011 at 10:35 AM
    Murd3rd
    damn...
  12. Jun 7, 2011 at 11:49 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    DO NOT put your meter on a yellow wire. Yellow is for the SRS. The voltage from an Ohm meter can set off the airbag.
  13. Jun 7, 2011 at 1:37 PM
    Murd3rd
    well my first plan is to see if it is covered under warranty....
    and just because im new here doesn't mean im new to Tacomas or auto mechanics for that matter, not really sure how to take your last statement
  14. Jun 7, 2011 at 1:49 PM
    Murd3rd
    a "noob" to the SRS system, yes, but troubleshooting i am no "noob", using a multimeter, i am no "noob" working on vehicles i am no "noob" give me a wiring diagram and a multimeter and i would figure it out, and now that i think about it i do have a wiring diagram of my entire truck, so this is where i will start if the dealer doesnt want to fix it under warranty
    you are obviously a veteran on this site, i will not deny that, but please dont under estimate someone because they seem to be a "noob"
  15. Jun 7, 2011 at 1:49 PM
    Murd3rd
    no offense taken if none was intended......
    end thread jack
  16. Jun 11, 2011 at 10:00 PM
    Badbud
    Badbud Member
    BUD
    Alanta ga
    2007 prerunner
    How do you remove the drivers air bag?
  17. Jun 12, 2011 at 3:17 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Disconnect battery, wait 15min, remove screws on back of steering wheel.
