2011 Signal Flashers are 12 pin?
Old 06-05-2011, 10:35 AM   #1
sledneck [OP] sledneck is offline
sledneck is on a distinguished road
Law Enforcement: CBP
sledneck's Tacoma Gallery
I recently put switchback LED's up front and LED's in the reay turn signals. Other posts have the LED signal flasher as a 8 pin CF 18ALT but when I took mine apart on my 2011 TRD Sport it is a 12 PIN flasher. Does anyone know if it is different because it is a TRD or because it is a 2011? Also, if anyone can give me direction on where to get a 12 pin that fits my application to fix hyperflash it will be greatly appreciated.
Old 06-05-2011, 01:39 PM   #2
After some more research I found out that the 8 pin flasher is for non-drl and the 12 pin flasher is for trucks equipt with DRL. If anyone knows where I can get a 12 pin DRL LED flasher that would be great!
Backup signal in the 7-pin connector donít work in my 2010 Taco. hgfontana Towing 8 02-16-2014 03:12 PM
05-12 turn signal flasher hotrod45 Lighting 1 01-27-2012 08:15 AM
7 pin wiring colors for 2011 tacoapw Towing 1 11-23-2011 04:37 AM
Need the pinout for a 12 pin connector (1st gen) MacGyvR Audio & Video 0 03-24-2011 07:06 PM
Adding 4-Pin to a Base 2011 SR5 mattygabe Towing 7 02-22-2011 06:35 PM
