2011 Squeaky Clutch Pedal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by K Williams, Jun 7, 2011.
  1. Jun 7, 2011 at 2:47 PM
    K Williams
    K Williams [OP] Well-Known Member
    Long Island, NY
    2011 TRD Off Road V6 MT
    Banks Monster Exhaust URD Stage II Clutch
    My clutch pedal has been squeaking for two weeks now. It's been driving me crazy. So I took a look to see if something was rubbing or needed lubricating. I find out that the whole clutch pedal/arm is made from plastic, not steel. :mad: Does anyone else have this problem? What did you do to fix it? Do I have to take this truck to the dealership again? Thanks.
  2. Jun 7, 2011 at 6:25 PM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    Very common problem. My 08 has done it since new. Dealership replaced clutch pedal assy dec 2010. Mar this year clevis pin assy broke on new clutch pedal. Had to be towed to dealer for warranty repair. After all that, clutch pedal creaking again. Lots of threads on this forum for same problem.
  3. Jun 13, 2011 at 6:30 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Ha ha then it comes back at 110k, at least for me it has. :eek:
  4. Jul 21, 2011 at 9:59 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
  5. Jul 21, 2011 at 10:03 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    Mine too. Not every time. I was going to put some lithium on it but it is not bothering me too much.
  6. Jul 21, 2011 at 10:53 AM
    charles08tacoma
    Santa Cruz, CA
    Need to grease the clutch fork & pivot ball. That's the same noise mine made under the truck before dealer packed the pivot ball & clutch fork with lithium grease. Noise will come back again some time. Others on the forum have made greasing this area as part of routine maintenance.
  7. Jul 21, 2011 at 10:57 AM
    tacokid09
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
  8. Jul 21, 2011 at 12:26 PM
    charles08tacoma
    Santa Cruz, CA
  9. Jul 21, 2011 at 12:44 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I got mine fixed at the dealer. There's a TSB for it
  10. Jul 21, 2011 at 1:46 PM
    charles08tacoma
    Santa Cruz, CA
    There is a TSB for 6 speed which the OP has, don't believe 5 speeds are covered by TSB.
  11. Jul 21, 2011 at 1:49 PM
    tacokid09
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
    noooooo :(
  12. Aug 3, 2011 at 9:13 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    DO NOT SPRAY LITHIUM GREASE UP IN THE AREA OF THE FORK AND THROW OUT BEARING!!!
    If you get it on the clutch/flywheel youll be sorry...
    my truck i narrowed it down to the actuator under the dash and greased it and it hasnt made the noise in a year. its up on the firwall so the noise carries very well to the underside of the truck but im 95% sure its the pivot i greased under the dash
  13. Aug 3, 2011 at 9:21 AM
    resq330
    resq330 El' Capi-Tan
    Josh
    VA
    13 MGM DCSB TRD-Sport
    K&N Drop-In, Dick Cepek 'Torque' Wheels, Wet Okole Seat Covers, LED Interior
    Where would that TSB be located? This is the only one I know of and I thought it only replaced a shaft in clutch assembly.
    TC004-06 JUN 06 M/T - Clutch Pedal Squeaking Noise
  14. Aug 3, 2011 at 9:25 AM
    tacokid09
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
    you my friend should somehow try and pis a picture of it.. :D
  15. Aug 3, 2011 at 9:27 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
  16. Aug 3, 2011 at 9:30 AM
    Yoytoda
    Roland
    completely stock
    oh god..........ok
    im 6'4" and have to fold up like a pretzel to get my big as on the floor and head up in behind the dash.
    stay tuned
  17. Aug 3, 2011 at 9:32 AM
    tacokid09
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
    have your wife take picture of you all in a wad haha :D just kidding, but id like to say thank you in advance :thumbsup:
  18. Aug 3, 2011 at 9:32 AM
    resq330
    Josh
    VA
    :popcorn:
  19. Aug 3, 2011 at 9:46 AM
    Yoytoda
    Roland
    completely stock
    With the clutch pressed you need to grease the return spring pivot on the chassis and the pedal lever.
    With the clutch lever up, grease the pivot where the master cylinder piston connects to the pedal.
    This made my squeak go away.
    I also took the slave cylinder loose and used lucas waterproof bearing grease between the ball and the clutch actuator arm. You need a 12mm to take the two bolts loose and the slave cylinder comes off. dont push the clutch pedal with the slave cylinder removed
  20. Aug 3, 2011 at 9:57 AM
    wmdpowell
    Bill
    Essex county NY
    Seems like mine is inside (more plastic on plastic sound than down in the metal workings)
