Moog LCA ball joint, tie rod, and wheel bearing replacement part #'s and general BS
Old 06-07-2011, 07:30 PM   #1
misc [OP] misc is offline
misc is one of the sharper tools in the shedmisc is one of the sharper tools in the shedmisc is one of the sharper tools in the shedmisc is one of the sharper tools in the shedmisc is one of the sharper tools in the shedmisc is one of the sharper tools in the shedmisc is one of the sharper tools in the shedmisc is one of the sharper tools in the shedmisc is one of the sharper tools in the shedmisc is one of the sharper tools in the shedmisc is one of the sharper tools in the shed
misc's Tacoma Gallery
I haven't seen any condensed info on any of the sites and since these are typical wear items on a 4x4 05+ Tacoma I figured I would throw out some part numbers and pictures for all to see/use when they have the same issues.
I have never used Moog before, so I contacted some guys I know before investing in their parts. No one had anything bad to say so I choose Moog for all of my parts. I purchased everything from Rock Auto Sunday night and it was all delivered today (Tuesday).
Moog's designs seem solid and they have serviceable tie rods and ball joints that should last much longer then OE as long as they are taken care of.
Please note there are 1,000 ways to skin a cat and many other parts from different manufacturers that can be used. This thread is just a summary of what I used.
Tie rod
Part #: ES80895
$24.79
LCA ball joint
Part #: K80827
$36.79
DIY LCA Ball Joint Replacement 2005+ Tacoma link
http://www.tacomaworld.com/forum/sus...ml#post3564451
Front wheel bearing + hub
Part #: 515040
$77.89
(hub isn't required)
Wheel bearing replacement link:
http://www.tacomaterritory.com/forum...93&postcount=1
Note: a 35mm socket or a 36mm socket can be used, but it is not 100% correct.
For the exact recommended socket see here http://toyota.spx.com/hwtordr.aspx
The part # is: SST 09318-12010
http://toyota.spx.com/detail.aspx?id=545&p=281&g=0
See below for a PDF Toyota Tech bulletin on replacement.
**Do NOT follow the torque specks on the PDF labeled "Front Hub (4wd & Pre-Runner)" - this PDF was supplied for removal of parts ONLY.
**For proper torque specks follow the PDF named "Front Axle Hub (4wd & Pre-Runner) Installation. It is the bottom PDF and should be used for installation.
For the people who need gaskets (should be everyone unless you want to replace your wheel bearings again in 3,000 miles)
Wheel seals:
NATIONAL Part # 710477 Oil Seal (Nitrile Seal)
Shaft Size=3.189", Housing Bore=3.801, Outer Diameter=3.809, Width=0.63in
Front Wheel; 4WD; Outer
Rock Auto $8.64
NATIONAL Part # 710573 Oil Seal (Nitrile Seal)
Shaft Size=2.856", Housing Bore=3.525, Outer Diameter=3.537, Width=0.252in
Front Wheel; 4WD; Inner
Rock Auto $9.53
OE O ring Part # 9030192003
Village Toyota $3.94
Rock Auto always has 5% off discount codes so search the web for their current one before ordering. I saved $13.95 in 2 minutes.
Here are some new ball joints you might also want to consider
RAYBESTOS:
BALL JOINTS
• One-piece forged for strength
• Two-piece cylindrical wedge provides Industry's finest fatigue/wear resistance
• No spring, no endplay
• Cold formed, heat-treated stud for superior strength ad durability
• Full Ball design delivers ample wear surface
• Fused urethane boot prevents joint disintegration
• One premium pieces, no galvanic corrosion thanks to coated stud and hardware
2005+ 4.0 4x4 or Prerunner
Upper ball joint PT# 500-1150 Master Installer price is $32.90
Lower ball joint PT# 505-1427 Master Installer price is $32.90
File Type: pdf Front Axle Hub (4wd & Pre-Runner Installation).pdf (142.5 KB, 16 views)
Old 06-07-2011, 07:39 PM   #2
chris4x4's Avatar
chris4x4's Tacoma Gallery
Moog is some good stuff!
Old 06-07-2011, 07:49 PM   #3
Time will tell ultimately, but I'm impressed by their design and overall quality right out of the box.
No missing parts...check
No rust...check
No defective/ripped/weathered/dry rotted boots...check
No forging or mold issues...check
Old 06-07-2011, 07:55 PM   #6
Banned
Yeah Moog makes great parts. Just remember that you have more greasing to do. For bearings I would stick with Timken.
Old 06-07-2011, 08:04 PM   #7
That's the whole point of getting them...the added greasing. Ill remember.
If cash was no object I would of gone with SKF over all other brands. They have the best bearing seals and bearings from what I researched IMO.
If I can get 63k out of OE wheel bearings I think Ill be just fine with Moog.
Old 06-07-2011, 08:07 PM   #8
OZ-T's Avatar
OZ-T's Tacoma Gallery
Originally Posted by Lrgrnr View Post
Thanks! About to order me bearings and hub assemblys. I've narrowed down my problem to wheel bearings or diff bearings. Hopefully it's the wheel bearing.
Was that your noise you were trying to find ?
Old 06-07-2011, 08:10 PM   #9
For the people just ordering bearings or need seals
Wheel seals:
Rock Auto $8.64
Rock Auto $9.53
Old 06-07-2011, 08:17 PM   #10
You have bearing noise already? I hope my truck doensn't need them that soon.
For the past 5-6k. Ive pushed them far and I expect to see some carnage. I got the hubs just in case. You have to remember my truck see's salt 3-4 months out of the year and my local trails are always wet and full of sand and mud. Pretty much bearing hell. I also drive like an a-hole compounding my issues. I have 63k on the truck.
Old 06-07-2011, 08:22 PM   #11
My truck sounds like this baby in action
Old 06-07-2011, 08:25 PM   #12
Originally Posted by HomerTaco View Post
What are you laughing at?
Now that we got you taking your truck into the woods your NEXT
I hear Wharton calling you
*Craig*
*Craig*
*Come play in my sand and mud water*
Old 06-07-2011, 08:30 PM   #13
We need a Wharton hit list
Me: Starter, uniballs, every bearing
Joe: wheel bearings, belt tension-er
Scott: just about every moving part
Josh: 4x4 actuator and who knows what next
John: manual transmission
and I know someone blew out all their pullies, just can't remember who
Yea....lets play in the mud
Old 06-07-2011, 10:10 PM   #15
If it's any consolation, I've got this weird hum when I go over 60mph now...
started after BC...
Carrier bearing is my guess.
Next time I see you Ill take a look.
Old 06-08-2011, 04:42 AM   #16
BIG DADDY
brutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shed
brutalguyracing's Avatar
brutalguyracing's Tacoma Gallery
dam my truck is quiet quiet quiet now....and im loving it....
first time in years
well that is except rear leafs squeaking at times
Old 06-08-2011, 12:24 PM   #17
BIG DADDY
anyone know where i can get just the hub
Old 06-08-2011, 12:29 PM   #18
pAP pAP is offline
pAP is one of the sharper tools in the shedpAP is one of the sharper tools in the shedpAP is one of the sharper tools in the shedpAP is one of the sharper tools in the shedpAP is one of the sharper tools in the shedpAP is one of the sharper tools in the shedpAP is one of the sharper tools in the shedpAP is one of the sharper tools in the shedpAP is one of the sharper tools in the shedpAP is one of the sharper tools in the shedpAP is one of the sharper tools in the shed
pAP's Avatar
pAP's Tacoma Gallery
started after BC...
Me too. Interesting that it started after Wharton.....
Old 06-08-2011, 12:38 PM   #19
East Bound and Down
Dark Knight is one of the sharper tools in the shedDark Knight is one of the sharper tools in the shedDark Knight is one of the sharper tools in the shedDark Knight is one of the sharper tools in the shedDark Knight is one of the sharper tools in the shedDark Knight is one of the sharper tools in the shedDark Knight is one of the sharper tools in the shedDark Knight is one of the sharper tools in the shedDark Knight is one of the sharper tools in the shedDark Knight is one of the sharper tools in the shedDark Knight is one of the sharper tools in the shed
Dark Knight's Avatar
Dark Knight's Tacoma Gallery
Part #: 515040
$77.89
Pressing still required for install or is this finally a full assembly? Looks not all together in the pic to me...
Old 06-08-2011, 12:56 PM   #20
BlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shed
BlueT's Avatar
BlueT's Tacoma Gallery
Timken is crap... as the rest of them...
My LC Koyo's lasted 180K and Koyo's for 2gen truck are expensive but worth every dollar.
Toyota installs Koyo on LC's but the rest of the budget cars get some other shady bearings.
DIY LCA Ball Joint Replacement 2005+ Tacoma XXXX Suspension 52 11-10-2014 12:39 PM
Noises after ball joint / tie rod install cmf21 1st Gen. Tacomas 1 10-29-2011 11:38 PM
new ball joints and tie rod ends already? 4421.frank 1st Gen. Tacomas 13 04-25-2011 03:59 PM
Moog ball joint part number? eight3one_offroad Suspension 0 06-17-2010 12:55 AM
