Best ground for cb antenna
Old 06-19-2011, 05:09 PM   #1
Khaos [OP] Khaos is offline
Khaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shed
Khaos's Avatar
Khaos's Tacoma Gallery
Just curious where those with antennas that require grounding have is the best place to ground it. My antenna is in the back right corner of my bed for the best reception possible.
Old 06-19-2011, 05:15 PM   #2
Class IV Category 8 Elite VIP Member (Only)
BradleyScottETC is one of the sharper tools in the shedBradleyScottETC is one of the sharper tools in the shedBradleyScottETC is one of the sharper tools in the shedBradleyScottETC is one of the sharper tools in the shedBradleyScottETC is one of the sharper tools in the shedBradleyScottETC is one of the sharper tools in the shedBradleyScottETC is one of the sharper tools in the shedBradleyScottETC is one of the sharper tools in the shedBradleyScottETC is one of the sharper tools in the shedBradleyScottETC is one of the sharper tools in the shedBradleyScottETC is one of the sharper tools in the shed
BradleyScottETC's Avatar
BradleyScottETC's Tacoma Gallery
If your antenna is bracketed to the back right corner of your bed, it's already grounded. Post a picture. What size antenna are you running?
Old 06-19-2011, 05:16 PM   #3
Thieu is on a distinguished road
Thieu's Tacoma Gallery
My ground to the frame is working great.
Old 06-19-2011, 05:17 PM   #4
Whyareyoureadingthis?
VirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shed
VirginiaBound's Avatar
Name: Sam I am, green eggs and ham
VirginiaBound's Tacoma Gallery
Wilson 5000 ftw.
Old 06-19-2011, 05:23 PM   #5
Khaos's Avatar
It's a 4ft fiberglass antenna. I have it mounted to the sliding bed rail using some washers and a cheap mirror mount.
Best pic I have ATM.
Old 06-19-2011, 05:27 PM   #6
Ah, I see. If you mounted the bracket like this, it wouldn't need a ground.
You can run a wire from the bracket where it is now to one of the bolts I used, that should work pretty good. Keep the ground wire as short as possible.
Old 06-19-2011, 05:32 PM   #7
Khaos's Avatar
The mount I had wouldn't fit, thats how I originally planned on mounting it. Might as well move it.
Coax cable is done with zip ties like yours. Worked out great as I just had 'em sitting in the garage.
Old 06-19-2011, 05:42 PM   #8
JKD JKD is offline
JKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shed
JKD's Avatar
JKD's Tacoma Gallery
http://www.k0bg.com/ground.html
Old 06-19-2011, 06:54 PM   #9
I had to drill my bracket out with a uni-bit a few steps to get it to fit, with a washer behind it to level it out.
Old 11-25-2012, 05:16 PM   #10
Swampterror is on a distinguished road
Swampterror's Tacoma Gallery
4' fiberglass with mount
Is there a good spot to mount on the front of the bed that is grounded ? Pretty sure the rail is not. I'm not picking up further than half mile. Or should I make a bracket?
Old 11-25-2012, 05:32 PM   #11
I mounted mine On the sliding bed rail behind the cab not picking up worth a crap. I had to make a custome block to put the 1/4-20 screws into. Is that rail grounded or does anyone know? I can post a pic but bracket and screws are stainless steel but the block is steel and not sure about the rail.
Old 11-25-2012, 06:04 PM   #12
Rich91710's Avatar
Rich91710's Tacoma Gallery
Rail is not grounded, you'd need to run a ground wire to the frame.
Be careful, the whip will destroy your cab paint, and reflection from the cab will screw up your tuning.
If you don't want to mount to the rear corner, you're better off on the roof.
Old 11-26-2012, 09:19 AM   #13
This I what I have I haves ground wire but not sure where to put it ohm reads zero when both are on the bracket but reads 1 when touching bracket and screws.
Old 11-26-2012, 09:33 AM   #14
Don't know how to post a picture any one can help
Old 11-26-2012, 10:10 AM   #15
Central Scrutinizer
LUSETACO is one of the sharper tools in the shedLUSETACO is one of the sharper tools in the shedLUSETACO is one of the sharper tools in the shedLUSETACO is one of the sharper tools in the shedLUSETACO is one of the sharper tools in the shedLUSETACO is one of the sharper tools in the shedLUSETACO is one of the sharper tools in the shedLUSETACO is one of the sharper tools in the shedLUSETACO is one of the sharper tools in the shedLUSETACO is one of the sharper tools in the shedLUSETACO is one of the sharper tools in the shed
LUSETACO's Avatar
LUSETACO's Tacoma Gallery
What Rich said. Mounting to the rail is not really the ideal spot and behind the cab is even worse for performance unless you have a very long antenna. Your always better off mounting to the roof due to the better ground plane. I had 2 Firestiks that I could never get tuned properly behind the cab. I ditched them for a mag mount on the roof and never looked back.
Old 11-26-2012, 10:33 AM   #17
mike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant future
Army: SFC,  19 years, 5 to go.
mike92y's Tacoma Gallery
I went to Firestick and spoke to the owner for about 2 hrs. He was Military and we swaped war stories. He looked at my truck and said mounting close to the cab would be best. I brought up the ground cable thing and was told to keep it a short as possible otherwise the ground will turn into part of the antenna. Braided ground cable is best. Check out the firestick web site and there are some tips there for your install. Seems there are quite a few people running CB's with a good SWR so Its possible. The CB install is on my list of to do's. I have everything and just put a cap on the truck so I am ready to finish this project now. Good luck let us now how it works out.
Old 11-26-2012, 10:53 AM   #18
I can make a custom bracket to fit it on the side rail just because I don't have a long enough coax cable to get it away from the cab. It is a 4' fiberglass Wilson
Old 11-26-2012, 11:15 AM   #19
rockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shed
rockgecko03's Avatar
rockgecko03's Tacoma Gallery
While the side rails are not grounded, the bolts in the rail that hold them on are. At least the one that I checked on my truck is anyways.
Old 11-26-2012, 11:32 AM   #20
BDUF#
XXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shed
XXXX's Avatar
XXXX's Tacoma Gallery
Just jump it to the frame if you worried about a good ground.
WTT: 4' FireFly CB antenna for 2' CB antenna Taco Man in HD Buy / Sell / Trade - Other 1 02-03-2012 08:33 AM
Firestik Non-ground plane cb anttena BBJ285 Audio & Video 10 12-05-2011 05:35 AM
CB Ground Plane?? bendbolden 2nd Gen. Tacomas 8 10-10-2011 04:48 PM
cb antenna ground or not.... EL ROJO Technical Chat 4 08-04-2010 11:11 PM
CB radio antenna ground josh3972000 Audio & Video 2 04-22-2009 05:17 PM
