Stupid question about wheelin with an automatic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hiker, Aug 12, 2011.
  1. Aug 13, 2011 at 4:07 PM
    #21
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    Being a Prerunner i have no idea what y'all are talking about so ill sit back :D
  2. Aug 13, 2011 at 4:15 PM
    #22
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    You can't get a doublecab longbox TRD Offroad , and you can only get ATRAC in the Offroad model .
    If the OP wants a longbox , it won't have ATRAC
  3. Aug 13, 2011 at 4:38 PM
    #23
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I moded 1999 Taco so much it had turned to Land Cruiser
    There are options.
    IMHO Best option for offroading is to shift to 4 (not D) so truck has towing shift pattern.
    If you dont like that pattern read FSM on how to override shift computer and use shifter to shift manually. For me shifting to 4 works best.
  4. Aug 13, 2011 at 4:47 PM
    #24
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Fifth gear is already disabled in 4LO.
    And about keeping it in 4HI during offroad, couldn't that cause the transmission oil to overheat due to higher amount of "slippage" into the torque converter?
  5. Aug 13, 2011 at 4:55 PM
    #25
    OffroadToy
    The OP was asking about wheeling in in 4LO. The transmission doesn't upshift in 4LO range.
  6. Aug 13, 2011 at 4:55 PM
    #26
    OZ-T
    Peter North
    British Columbia
    4LO limits your speed dramatically , I guess it depends what speed you are offroading at , as I said earlier I mostly limit my 4LO usage to crawling .
    I don't think there is an issue with using 4HI as far as overheating the tranny
  7. Aug 13, 2011 at 4:57 PM
    #27
    OZ-T
    Peter North
    British Columbia
    If you select 4th in 4LO , you're saying it starts in 4th and stays there ?
  8. Aug 14, 2011 at 8:13 AM
    #28
    OffroadToy
    I might be wrong but I thought there's no upshifting. I thought while in 4LO there's no over drive (D)...the tranny is in 4th gear (weather you have the shifter in the D position or the 4 position. )
    Quote- OC-T...
    Yes...unless you shift down into 3, 2, or 1 manually with the gear shift selector.
  9. Aug 14, 2011 at 9:55 AM
    #29
    OZ-T
    Peter North
    British Columbia
    No , it shifts , just up to the gear selected , but no D
  10. Aug 14, 2011 at 10:23 AM
    #30
    OffroadToy
    Maybe I'm reading the owners manual wrong. Under automatic transmission (5 speed) it says...
    When the front drive control switch knob is in "L4" the driving pattern selector setting has no effect on gear shift timing.
  11. Aug 14, 2011 at 11:46 AM
    #31
    OZ-T
    Peter North
    British Columbia
    Intetesting .
    I'm quite sure it upshifts and downshifts , but apparently you cannot force it to remain in a gear with the shift lever
    ie : if you have it in 4th , it starts in 1st , shifts up when appropriate to 2nd etc .
    It doesn't start in 4th because you have 4th selected
  12. Aug 14, 2011 at 12:03 PM
    #32
    OffroadToy
    Are you saying your transmission shifts between gears automatically when your in 4LO? :confused:
  13. Aug 14, 2011 at 12:07 PM
    #33
    Rich Beauregard
    Rich Beauregard Well-Known Member
    Rich
    New London, CT
    17 Taco 4x4 SR5 Access Cab White
    I have 06 Db Cab 4x4 TRD Sport Long-bed automatic. I have always kept it in "D" while wheeling. I have put it in 4-LO to make it up a wet muddy hill a few times. Remember, Db Cab long-bed is only offered in automatic and the 06 only came with limited slip rear. No Locker! I must say that the limited slip has been an awesome set up. I know all these guys that have lockers and say "You'll never make it without a locker". That a bunch of BS! I have gone everywhere they have with the only exception of clearance issues because of the long wheel base. That and a few rocks that my front bumper would not clear.
    My Jeep friends were really amazed how well the Limited Slip works!
  14. Aug 14, 2011 at 12:12 PM
    #34
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I haven't had my Tacoma in 4LO that often, but it seems to me that it does not shift at all, like the manual states. It feels like it stays in 1st no matter the throttle/RPM/shifter position.
  15. Aug 14, 2011 at 12:44 PM
    #35
    OffroadToy
    Interesting...I wasn't aware they changed the automatic transmissions between 07 and 010. Like mentioned earlier mine states right in the owners manual...
    "When the front drive control switch knob is in L4 the driving pattern selector setting has no effect on gear shift timing."
    While in 4LO my transmission neither up-shifts or down-shifts on it's own. On mine any gear selected (4,3,2, and L) stays locked in those gears when in low speed 4WD.
  16. Aug 14, 2011 at 1:17 PM
    #36
    OZ-T
    Peter North
    British Columbia
    Where are you finding that in your manual , I just flipped through mine and didn't find that .
  17. Aug 14, 2011 at 1:18 PM
    #37
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    lol at the end of that video. FWIW my '07 behaves the same way
  18. Aug 14, 2011 at 1:20 PM
    #38
    OZ-T
    Peter North
    British Columbia
    Lol
    No need for ATRAC
  19. Aug 14, 2011 at 1:41 PM
    #39
    OffroadToy
    In my owners manual it's on page 170 under the heading... Automatic transmission (5-speed)
  20. Aug 14, 2011 at 2:14 PM
    #40
    OZ-T
    Peter North
    British Columbia
    Mine has no mention of the same , it does however have a chart listing the allowable top speeds for downshifting while in 4LO
