$1500 limit but so confused...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Xewkija631, Aug 15, 2011.
  1. Aug 15, 2011 at 11:44 AM
    Xewkija631
    Xewkija631 [OP] Well-Known Member
    LI,NY
    2011 BLACK DC TRD OFF ROAD
    I have been looking at lifts and trying to understand them but I just can't... I'm hoping someone can just help me out. First by getting a lift am I going to lose anything I have stock right now? As in comfort of ride, gas milage, ect...
    I'm pretty set on a 3 inch lift but I don't know where to begin looking... And I have read about the leaf or something... All I want to do is make my Tacoma higher without having any problems after the lift...
    If I got a 3inch lift are my stock tires and wheels good?
    What actullaly gives it the lift? The shocks...?
    In need of serious help.
    Thank you very much
  2. Aug 15, 2011 at 11:46 AM
    Xewkija631
    LI,NY
    I also wanted too add this... What would be the best lift I can get and if anyone can link me to the right place
    Thank you
  3. Aug 15, 2011 at 11:53 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
  4. Aug 15, 2011 at 11:56 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Start out by reading this. It's a good explanation of the lifts out there and how they work.
    http://www.tacomaworld.com/forum/suspension/11282-tacoma-lift-faq-guide-read.html
    At 3" you might lose a little with your gas mileage and anytime you modify the driveline of a vehicle you run the risk of introducing vibrations from the change in geometry. Some have lifted without any issues, some spend a lot of time chasing out vibrations.
    Don't rush your lift, do your homework and it'll pay off. Do the lift right the first time, it's too expensive to do twice.
  5. Aug 15, 2011 at 12:32 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    You will gain ground clearance at the expense of gas mileage.
    The ride will be entirely dependent on how you lift the truck.
  6. Aug 15, 2011 at 2:00 PM
    Xewkija631
    LI,NY
    Thank you for the replies greatly appreciated..
    To pugga: "Don't rush your lift, do your homework and it'll pay off. Do the lift right the first time, it's too expensive to do twice."
    What would you consider doing it the right way? That's what I want too do.
    I know I want a 3" but I feel like theirs things you have to buy sepertely...
    Any opinions on the toytec ultimate lift and the 3" lift kit with Bilstein 5100 Height adjustable Coilovers...
    If I went with the second one does that lift my whole truck..? Cause it says adjustable front shocks... Does the rear not use shocks...
    I'm so sorry for the silly questions but I don't want to mess up on this buy and I read that sticky about the suspension yet still lost
    Thank you very much
  7. Aug 15, 2011 at 2:14 PM
    Pugga
    Massachusetts
    "Doing it right the first time" means different things to different people. For example, my truck stays mostly on pavement and I did not want much of a lift so I went with Eibach coils and 5100's all around and a 1.5" AAL for the rear. It's perfect for me and my type of driving but maybe not for you.
    Here are a few decent options for a 3" lift that would keep you within your budget. Keep in mind with each option would have to add upper control arms and these can be pricey. There are a few options, each with their pros and cons. Check out Total Chaos, Light Racing, Downsouth Motorsports, Camburg (I'm sure I'm forgetting a couple).
    Here's a 3" lift accomplished by Eibach coils and a custom built spacer and an AAL for the rear. Toytec Ultimate lift kit - popular for other TW members, has a decent reputation. I'd avoid the block option for the rear and either go with an AAL or the Dakar leaf pack (depending on your budget or usage). Old Man Emu lift kit - another popular option although not adjustable like the Toytec kit. You have to choose the correct coil to get the right amount of lift. For a second gen you'd be most likely looking at 885 coils and the top plate spacer to get you to 3" of lift. Again, I'd avoid the block for the rear and go with the AAL or Dakar leaf pack.
    If you spend a lot of time loaded, you might want to look at a replacement leaf pack instead of just an AAL (That would be the dakar option I mentioned above and is an option to choose in each of the links). I'm not an expert and only relaying information about these kits I've read through other's reviews and lurking on this site. One of those 3 options would be your best bet if you want to stay under $1,500 and still have a decent 3" lift though. If you call the vendors I mentioned earlier, they are very knowledgable and willing to work with you. I've dealt with all 3 of them at one time or another and they're quick to answer questions and help you put your lift together. After you start leaning toward a specific lift kit, I'd give them a call and tell them what you're thinking, they may have some valuable input to help you with your decision.
  8. Aug 16, 2011 at 12:49 PM
    Xewkija631
    LI,NY
    Thank You very much for your help.. I really appreciate your input.
    So I think the ultimate lift kit is out cause I do want to spend a but less money but I was looking at the
    If I were to go with this would this be what I should do...
    Rear Lift Options: Dakar rear leaf springs
    Front diff drop kit: 4x4 only
    Would I need to purchase anything else or is this all I would need to get my 3" lift?
    Thank You
    I do plan on reading up on it first and seeing what people have to say about it before any purchase is made...
    Thank You
  9. Aug 16, 2011 at 1:01 PM
    Pugga
    Massachusetts
    You forgot Upper Control Arms! Big expense and definitely needed with a 3" lift to get your alignment within spec.
    With the Dakars, there are a couple small items that you should consider, extended centering pins in case you need axle shims later on, axle shims and a carrier bearing drop kit. These are fairly inexpensive parts and you can buy them with your kit to save shipping costs. The CB drop kit and shims can help eliminate driveline vibrations post install but not everyone uses them or needs them. It seems to be sort of case by case unfortunately.
  10. Aug 16, 2011 at 4:41 PM
    Xewkija631
    LI,NY
    Their is no option for UCA on the one I listed... ?
    This one right here
  11. Aug 16, 2011 at 4:47 PM
    hard2kill
    hard2kill Well-Known Member
    John
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    im running 5100 front and rear with them set at 2.5 in of lift...i did not need a diff drop or carrier bearing drop nor did i need new upper control arms...alignment is good and ride is great...i have rear blocks for now but i recomend a 1.5in add-a-leaf or full leaf packs...
  12. Aug 16, 2011 at 5:00 PM
    Pugga
    Massachusetts
    UCA's aren't part of Toytec's lift kits. You'd have to go through one of the companies I listed above (Camburg, Total Chaos, Downsouth Motorsports, Icon, Light Racing and I'm sure there are others I'm forgetting).
    At a true 3" lift you'd be very lucky to get your alignment within spec without new upper control arms. You can put a 3" lift on without new upper control arms but it'll mostly likely handle like crap since you can't get the caster within spec. You might be able to sacrifice some camber to get caster within spec but that means your front tires will sit like this \/ and you'll wear down your tires quicker.
  13. Aug 16, 2011 at 7:02 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I put the downsouth motorsports UCAs on mine. Quality product and couldnt be happier w/ my lift choice (same as pugga). Dont forget installation costs, alignment cost, etc...(eventual tire upsize). It adds up quick, but SOOO worth it! You'll be very happy w/ the lifted truck
