2011 Creaking Clutch Pedal & Chirping Blower Motor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moondeath, Sep 3, 2011.
  1. Sep 3, 2011 at 6:07 PM
    moondeath
    moondeath [OP] Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I just had my 15k service done. While there I had them check my creaking clutch pedal. This is the second time I've had it looked at. They told me the tech contacted toyota about it and they are aware of the problem and currently coming up with a solution. They said maybe by my next service they'll have a solution. As for my blower motor they replaced it and added an acoustic cover under TSB 0092-10. Hopefully this fixes that problem.
  2. Sep 3, 2011 at 8:25 PM
    skiracer0112
    skiracer0112 Well-Known Member
    Bryan
    Breckenridge, CO
    '11 Silver Double Cab 6-speed TRD OR
    Both of these issues will be brought up with the dealer when I go for my 10k service, I have just started to notice both problems at 7k miles. I hope that what they have done for your motor will work for me too so I can get that fixed as well as a quick solution to the pedal problem.
  3. Sep 4, 2011 at 4:56 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    all the motor needs is some wd-40, its held in by 3 screws, not a big deal. however the clutch creek is pissing me off!!
  4. Sep 4, 2011 at 7:10 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    There is a fix for the clutch pedal somewhere on here. It has to do with turning a shaft on the pedal assembly. I did this about a year ago and haven't had the creak since. Maybe someone can find the thread?
  5. Sep 4, 2011 at 7:26 AM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
  6. Sep 4, 2011 at 8:01 AM
    moondeath
    Pa, Gardners
    This is fine for those who don't have a warranty. But my take on this is I just paid $29k for a brand new truck. Toyota is responsible for coming up with a permanent fix for a poorly designed part. I don't want to be out in the mountains thousands of miles from now and have the clutch pedal brake on me and leave me stranded.
  7. Sep 4, 2011 at 8:13 AM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Somehow I don't think a creaking clutch pedal is going to leave you stranded. Yes, it is annoying. If you're that concerned you should get the dealer perform the TSB. I fixed mine myself in about 2 minutes.
