Problems with wheels spacers...HELP!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rharris5551, Sep 3, 2011.
  1. Sep 3, 2011 at 6:24 PM
    rharris5551
    rharris5551 [OP] Well-Known Member
    Jasper, TN
    17 TRD OR DCLB
    CBI bumper, TRD skid/exhaust, Icon deltas, 6112/ Tundra 5160, All Pro standard progressive leafs, Wheelers U-bolt flip w/ bumps F/R, Wheelers ext. brake lines, BD lighting, OVtuned, TRD wheels, Spidertrax, Auxbeam hi/low, TRD pro tails,
    i recently ordered a set of 1.5" wheel spacers off ebay for my 06 tacoma, got them all put on and torqued down and from about 45-55mph the steering wheels gets a pretty bad wobble :confused:, thats the only time it does it, any clues of what might be causing this? thanks
    mahaloTaco likes this.
  2. Sep 4, 2011 at 5:22 AM
    schleygo
    schleygo Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
    Are these spacers hub centric?
    Only ones I would recommend are the Spidertraxx spacers. They are hub centric. Most ebay spacers are junk.
  3. Sep 4, 2011 at 12:16 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    x2,the old saying..........you get what ya pay for.
  4. Sep 4, 2011 at 12:20 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    x3
  5. Sep 4, 2011 at 12:28 PM
    Shaun8180
    Shaun8180 Member
    Shaun
    San Antonio, TX
    08' Taco 6" lift 35 mudders 4.0 V6
    black headlight mod, blacked out badges, 6" pro comp lift, 35" mudders on 17" rims, K&N drop in air filter
    sounds like shitty spacers that werent cnc'd correctly, throwing the tires off balance. X4
  6. Sep 4, 2011 at 12:47 PM
    jazzystoy69
    jazzystoy69 Little Punisher
    Joseph
    CONNECTICUT
    LITTLE PUNISHER
    Intake mod - Flowmaster super40 - cree reverse lights - Grillecraft - MetalMiller emblem - Bilstien 5100s front and back - Spidertraxs 1.5 - AFE prodry S filter - Extang Black Max cover - Black muffler tip - 20% Tints All Around - Energy Poly Sway Bar Bushings - Sway Bar Links -Energy Suspension cab body mounts- AVS Hood Bug Defflector - AVS Black smoked window rain guards - Engine Silicone Hoses - sockmonkey bedside badges - sockmonkey TRD windshield Decal - westing step bars - snobord Light Bar & Hella Black Magic 500 Lights - TRD shift Knobs - Black shorty antena - dee zee all weather floor mats -Smoked spider Euro LED tail Lights -T R D 3rd brake Light Cover - Tail Gate Seal -CoverKing Neosupreme seat covers.
    I had those spacers nothing like these
    • [​IMG]
    MaxxTRD likes this.
  7. Sep 4, 2011 at 12:56 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    these are the way to go if your gonna run spacers!
  8. Sep 4, 2011 at 1:06 PM
    jandrews
    '09 FourDubDee TRD OR
    Spidertrax is the only brand I would ever run in spacers.
    But then I wouldn't ever run spacers, so that's sort of beside the point I guess.
  9. Sep 4, 2011 at 4:25 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    thats what i said......:cheers:
  10. Sep 4, 2011 at 4:32 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I've got 1.5 wheel spacers and no wobble. Did you get the hub centric ones? If not then that's def the problem. Btw as said before eGay spacers are crap. I got mine from All Pro Offroad for $170 with shipping and e/t lug nuts for the fronts.
  11. Sep 4, 2011 at 4:33 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Damn ebay! Works its magic again!
    Allpro makes good spacers too and for people like me that dont live around salt and stuff and dont need to spend that extra $40 a pair for the coating on the Spidertraxx, the Allpro's are perfect!
  12. Sep 4, 2011 at 4:38 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    lmao
  13. Sep 4, 2011 at 4:42 PM
    elblako91
    elblako91 Well-Known Member
    Blake
    Lubbock/Houston/Katy
    1992 Toyo Pickup
    It's almost a shame to cover them with your wheel/tire :(
  14. Sep 4, 2011 at 6:08 PM
    rharris5551
    Jasper, TN
    17 TRD OR DCLB
    dam... once again i get shafted, old sayin goes you live you learn :(
  15. Sep 4, 2011 at 6:35 PM
    dmz1241
    dmz1241 Well-Known Member
    Dan
    SE, Connecticut
    01 Gold DC TRD
    Bilstein 5100's all around, Eibach coils, 2" shackles, Flowmaster 60 Series
    Is there any cons to having spacers? I want some new rims and tires soon, and not sure if ill need wheel spacers. Its just nice to know in case i do end up getting them.
  16. Sep 4, 2011 at 6:36 PM
    TexasTacoma37
    You won't need spacers if you buy the proper rims.
  17. Sep 4, 2011 at 6:44 PM
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    Debateable. I think 1.25'' or less it would be hard for anybody to argue anythign negative. One of the primary concerns is that it places added stress on the hub and that may be true but I think its hardly an issue. I would say there are 1000's of people running spacers with no problem and a couple guys had an issue which they either correctly or incorrectly attributed to spacers then the naysayers ran for the hills yelling the sky is falling. Like anything if you are conservative you will be fine.
    Here is the spidertrac FAQ you can take a look at
    http://www.spidertrax.com/s.nl/sc.13/category.2/ctype.KB/KB.4303/.f
  18. Sep 4, 2011 at 6:46 PM
    dmz1241
    Dan
    SE, Connecticut
    01 Gold DC TRD
    Its okay.....i half expected that kinda response anyway.....I think ill just start a whole new thread on it, screw the search function ;)
  19. Sep 4, 2011 at 6:46 PM
    dmz1241
    Dan
    SE, Connecticut
    01 Gold DC TRD
    thank you^
  20. Sep 6, 2011 at 10:00 AM
    allpro
    allpro Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    Like others have said, you likely need hub centric. But, not all ebay spacers are crap, we sell ours on there sometimes when we're overstocked! We sold nearly 2,000 spacers last year alone, and have very few reported problems, which are usually due to installation errors.
    Crom likes this.
