Touch up or Repaint?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDsport253, Sep 8, 2011.
  1. Sep 8, 2011 at 12:23 PM
    TRDsport253
    TRDsport253 [OP] Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
  2. Sep 8, 2011 at 12:24 PM
    KalamaKid
    KalamaKid Well-Known Member
    Jason
    Oregon
    same shit as everyone else
    i gave up trying to keep those things looking good. I'd just leave it and wait until someone is selling one online for cheap and replace it.
  3. Sep 8, 2011 at 12:25 PM
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
    Sometimes I wish my truck was black.
  4. Sep 8, 2011 at 12:26 PM
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
    Was moving the refridgerator out the house and thought I was clear.
  5. Sep 8, 2011 at 12:28 PM
    KalamaKid
    Jason
    Oregon
    Branches tore mine up real good
  6. Sep 8, 2011 at 12:32 PM
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
    I may try to touch it up as it may take me for ever to find a use one. It's plastic so I'm sure its not going to rust or anything but It doesn't help when the entire truck is flawless except that one spot.
  7. Sep 8, 2011 at 12:35 PM
    FY01CPO
    FY01CPO Well-Known Member
    Jeremy
    CT
    SR5 4x4
    black tube steps, side marker turn signals, 15% tint and window strip, EGR vent shades, fighter pilot/cockpit mod, console and glove box auto on LED, anytime fog light mod, 3000k HID fogs, bed mat wing nut mod, locking bed storage bin mod, smoked tail lights, plasti-dipped rims, blacked out emblems, black tail pipe, tail gate hose clamp, rear seat utility/dog shelf with rear center console access door.
    Try to touch it up if it is eating at you. You will always know it is there but if you take your time and do it with the right stuff, nobody else will.
  8. Sep 8, 2011 at 12:36 PM
    KalamaKid
    Jason
    Oregon
    Touch up paint didn't look good on mine as its a gash in the plastic. There is no longer a smooth surface to paint on.
  9. Sep 8, 2011 at 12:43 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    I have touched similar nicks up with the OE color matched paint touch up vials. You can get it at Advanced Auto Parts for much less than at the dealer. What is important is to get clear coat also. tape around the scratches as close as you can get to it. lightly sand the edges with wet sand paper, about 600 grit. Apply several coats of white, untill it is built up enough to be flush with the original paint. Sand down a little bit with wet sandpaper, and apply the clear coat. After that is dry sand again to be flush with the surrounding surface. If done right nobody will even see it, except you, because you know it is there. If you did not do it right, like I had done my first few, and it bothers you, you are only out about $15 in paint and a little time, so if you decide to have it painted, you have not wasted much. If you take it to a body shop to get it painted it will probably cost at least $100.
  10. Sep 8, 2011 at 2:06 PM
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
    I kinda rushed on this. Is it to late to sand down?
  11. Sep 8, 2011 at 2:37 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Meh...I'd use touch up paint.
  12. Sep 8, 2011 at 6:29 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    no its not too late to sand, once you apply the color you want to wait a day or 2 for it to dry, then sand and apply clear. then you want to wait a week or so before sanding the clear.
  13. Sep 9, 2011 at 8:18 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    Brake parts cleaner will remove touch up paint without doing a thing to the original paint if you want to redo anything.
  14. Sep 9, 2011 at 8:22 PM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    scratches are custom, especially with this cheap, sweat-shop paint we rock
  15. Sep 9, 2011 at 8:28 PM
    pick21
    pick21 Well-Known Member
    central illinois
    2017 TRD OFFROAD ACCESS CAB
    make sure you use a small block of some sort when u sand it or you will sand through paint around touch up. best way to do it is with a catalyst paint and no clear.
  16. Sep 9, 2011 at 8:52 PM
    tguil
    tguil Well-Known Member
    Nebraska
    2018 Double Cab TRD Sport 4X4 AT
  17. Sep 9, 2011 at 8:55 PM
    jeepmor
    jeepmor Well-Known Member
    Stumptown
    It was fun making those wasn't it.
  18. Sep 9, 2011 at 9:02 PM
    Ivan
    Ivan Well-Known Member
    Ivan
    Western Mass
    06 Tacoma, 4x4 + SR5
