Tsb getting done now need 5100 help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jodyc, Oct 4, 2011.
  1. Oct 4, 2011 at 10:51 AM
    Jodyc
    Jodyc [OP] Member
    Jody
    Jersey
    11 Tacoma Trd sport
    Ok so dropped off the Tacoma today to get the tsb done no prob from the dealer. And I ordered the 5100s now my question is what do I set them at to level it out also im goin to buy new tires whats the biggest size tire I can stuff under. It has 17 in rims if I go 16in rims then what would the biggest size? I realize it will b the same in the end help!
  2. Oct 4, 2011 at 10:54 AM
    RoyR
    RoyR Well-Known Member
    San Diego, CA
    Billies, TSB
  3. Oct 4, 2011 at 10:54 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    When you get the truck back, measure both front and back from the center of the hub to the fender. The difference is the setting you should use on the 5100. It will either be the .85 setting if you want a little bit of rake or 1.75 if you want to be closer to dead level.
    Biggest size you can fit without rubbing is 265/70R17 and I believe if you go to 16's it's 265/75R16 (might want to have someone confirm the 16" size though, I've got 265/70R17's on mine).
  4. Oct 4, 2011 at 9:32 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    check out my stats and pics
    << ( click on the camera )
  5. Oct 6, 2011 at 4:13 AM
    Jodyc
    Jodyc [OP] Member
    Jody
    Jersey
    11 Tacoma Trd sport
    Tsb done what a difference the dealer gave me no prob. The back is wat higher than the front now. What do I set my billies at.
  6. Oct 6, 2011 at 5:23 AM
    Pugga
    Massachusetts
    Measure from the center of the hub to the fender both front and back and see what the height difference is. Set the fronts at whatever setting you need to compensate. It will probably be 1.75 to be level or .85 if you still want a little rake.
  7. Oct 6, 2011 at 5:57 AM
    tailwaters
    tailwaters Well-Known Member
    Brian
    S.W Michigan
    2011 Tacoma T/X TRD 4x4
    I've just got a leveling spacer kit and was able to run 265/75/16 with no issues. Without the leveing kit I did get a little rub now and than.
  8. Oct 6, 2011 at 7:25 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If you want the stock rake, set 'em at .85. If you want level, set 'em at 1.75. For tires, as has been posted, either 265/70R17 or 265/75R16.
  9. Oct 6, 2011 at 7:34 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I am still down about 3/4" up front with TSB rear and 5100's @1.75". I did not want to go any higher to avoid alignment issues, having to buy new UCA's, etc. I think the truck rides great as it sits now.
  10. Oct 6, 2011 at 7:51 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    Should of put the 5100's on before the TSB and taken advantage of the free alignment. I have TSB, billies at 1.75, and 265/75/16's. I am level, with a lot of weight I am nose high.
  11. Oct 6, 2011 at 8:55 AM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    the back is going to settle over next monthn or 2. on my last taco i had 1.75 and on my next probably doin 0.85 so im not nose high when i put anytrhing in back
  12. Oct 6, 2011 at 9:03 AM
    waterwolf603
    waterwolf603 Well-Known Member
    New Hampshire
    2011 SR5 v6 4x4
    i set mine at 1.75
  13. Oct 6, 2011 at 11:12 AM
    Tylan
    Tylan Active Member
    Tylan
    Wakefield, MA
    2012 DCLB Nautical Blue - "Bella"
    Weathertech Floor Liners, Access LightRider, 235/85/16 DuraTrac
    I just tried this and was told that the dealer couldn't align it to anything other then the manufacturers specs. I said BS, but they wouldn't get it to the specs that I wanted, so I have to go and get it done again elsewhere. I guess it depends on the dealer, but just watch out.
    As far as what to set them at, I set the front at 1.75 with the TSB leaf pack in the rear to make it level. I forgot to take into consideration that I have a cap on the truck that adds a few hundred pounds and now with the bed empty I still slightly nose high. If you want some rake left in the stance, go for the .85. If you want it level, be aware that 1.75 is about level with no weight in the back and it will look to sag slightly when you add some weight.
    Here is how she looks with just the cap and the bed empty:
  14. Oct 7, 2011 at 8:43 AM
    Jodyc
    Jodyc [OP] Member
    Jody
    Jersey
    11 Tacoma Trd sport
    So it look like I'm goin to set them @1.75 now tire question want a aggresive look but want them to drive good on the rd. I drive 60 miles a day to work I don't want to hear them hummmmm. Also rim size I have 17 in stock wheels can I get wider rims or is there a specific backspacing I should look for. I love xd wheels
  15. Oct 7, 2011 at 10:48 AM
    waterwolf603
    New Hampshire
    2011 SR5 v6 4x4
    i had the dealer add my billies and they set them at 1.75 for me while they did the tsb just had to pay for labor on the billies
