Deleted
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cypherian, Oct 22, 2011.
  1. Oct 22, 2011 at 7:35 PM
    Cypherian
    Cypherian [OP] Well-Known Member
    Mid Atlantic Region
    Deleted
  2. Oct 29, 2011 at 3:22 PM
    Oshnjoe
    Oshnjoe Well-Known Member
    Joe
    Outside Philly
    2010 SR5 4X4 DC LB
    seat covers, floor mats, ARE cap, Yakuma racks, 4 leaf TSB, running boards
    the brakes on my 2010 w/11k does the same:
    when going real slow to a full stop like when creeping along in heavy traffic
    asked the dealer about it when I got the squeaky blower fan replaced last month
    said they didn't hear it but after me having to sit at the dealership for several hrs I just wanted to get out of there and get back to hunting.
    been doing it (brakes & hunting) for quite some time
    but only when going real slow to full stop
    this must be happening to others as well
    I just haven't found the thread yet:confused:
  3. Nov 12, 2011 at 4:49 PM
    Murman
    Murman Well-Known Member
    North Carolina
    2011 Prerunner SR5 Access Cab 4cyl auto
    Undercover hard tonneau WeatherTech Floor Liners
    I mentioned this same problem to my dealership when I took my 2011 Prerunner in for it's 10k mile service two weeks ago. They took a look at it and said they needed to replace the brake booster. They ordered the new booster and I took my truck in this morning to have it installed. Four hours later, they pulled my truck back around from the shop and said the new booster was installed but it didn't solve the problem!:mad: The technician even grabbed a new Tacoma off the lot and drove it to see if he could duplicate the problem and guess what? That one did the same thing. The service manager said they have sent Toyota some kind of service bulletin asking for help with this problem and that they will get back to me when they hear of a possible solution. I will update you guys if I can get the problem fixed.
  4. Nov 12, 2011 at 11:47 PM
    ruslanus
    ruslanus Well-Known Member
    Rus
    Wasilla, AK
    My 2010 has the same squeal
  5. Feb 10, 2012 at 2:55 PM
    SmiXon34
    SmiXon34 Member
    Scott
    Lakeland GA
    2010 TRD Sport PreRunner SR5
    Undercover Bed Cover, Step bars
    My 2010 has the same problem, they replaced : Front pads, Rotors, rear drums and once again IT STILL SQUEALS..... then i was told.... "TACOMA'S just make that sound" in my honest opinion, that answer doesn't cut it.
    COME ON TOYOTA !!!! FIX THIS !!!
  6. Feb 10, 2012 at 3:15 PM
    black_magic2010
    black_magic2010 Well-Known Member
    South Texas
    10 Tacoma TRD Sport DBL Cab
    Mines been doing it since day 1.
  7. Feb 10, 2012 at 3:17 PM
    harleyg
    harleyg Landscape Photographer
    Harley
    2011 PreRunner AC 2.7 Leer 180
    My 2011 does the same. Brake squeak when coming to a stop. The dealer told me I need a brake service. At 10,000 miles of almost all freeway driving. Bullshit. It isn't bad, so I have just put up with it. I will be curious to see if anyone finds a fix.
  8. Feb 11, 2012 at 7:07 AM
    Oshnjoe
    Joe
    Outside Philly
    2010 SR5 4X4 DC LB
    Can't believe we're the only ones with this brake issue
    no difference from last post
    I've only got about 13k mi on it
    With all the folks out there that post on this board, someone has to know up's up :confused:
  9. Feb 11, 2012 at 7:14 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    CBI bed rack and sliders, Backwoods Adventure Mods front and rear bumpers, etc. And some stickers.
    I have an 09 that has always done this as well. I just replaced the front pads and rotors (it was almost time anyway) thinking it would go away, but it didn't -- so I think it is coming from the rear because it doesn't sound any different.
    Mine isn't bad, though, it's barely noticeable and only when easing up to lights/stops.
  10. Feb 11, 2012 at 3:35 PM
    harleyg
    Harley
    That sounds exactly like mine. It happens when easing to a stop and sounds like it is coming from the rear (not mine, the truck's).
  11. Feb 11, 2012 at 3:40 PM
    dfrugia
    dfrugia Well-Known Member
    Goose
    Roswell, NM
    2012 DC TRD OFF RD 4X4
    Running boards w/steps, Weathertechs
    My 09 w/34k miles does that as well.
  12. Jun 4, 2012 at 9:50 AM
    EasyDoesIt
    EasyDoesIt DesertDoesIt.com
    Steve
    Las Vegas, NV
    2011 Dbl Cab TRD Offroad
    Icon C/O's
    2011 dcsb 4x4 does the same thing....less the 15k on it and its been like this for atleast the past 5k. It's definitely coming from the rear. Has anyone tried anti seize or anti brake squeak under the shoes?
  13. Jun 4, 2012 at 11:34 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Does this sound occur only when applying the brakes?
    Suggest pulling the front brake pads and adding a thin coat of CRC brake-quiet to the pads + re-lubing the caliper bolts with the proper lube. I would also lightly sand each side of the rotors and pads to clean and allow their surfaces to re-burnish and mate again. Dust and dirt from the road or course your driving could also be causing that noise. Factory or machine-oil coatings are supposed to be washed off the rotors prior to to installing, and if its not washed off it will normally burn off.
    Something you could also try immeidately is applying firm brakes from 45 mph to a stop, about 3-4 times in a row to get those brake temperatures increased rapidly and clear off some of that pad material. Of course, only do this without traffic around and also while trying to avoid engaging the ABS.
    The rear brakes would be making a scraping or banging noise if there was a problem with them, so I doubt if its them.
  14. Dec 1, 2012 at 7:56 PM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    2011 with the same problem. Im at 25k now and it did go away on its own.
  15. Dec 1, 2012 at 8:00 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    I have a 2012 with 5,000 miles. Mine have squealed when cold and reversing since the day I bought her. Knock on wood but the last day or two haven't been as loud.
  16. Dec 1, 2012 at 8:06 PM
    Tacodog
    Tacodog Well-Known Member
    Ron
    Renton, Wa.
    ‘19 TRD offroad DCSB Cement
    Icon stage 1, Icon upper control arms, 17” Fuel wheels,Ridge Grapplers, TRD exhaust, leather interior.
    Have a 2010 with 13,700 miles on it. Been sqeaking last 6,000 miles.
  17. Dec 1, 2012 at 11:43 PM
    TruckyTruck
    TruckyTruck Well-Known Member
    Tundra Crewmax TSS Off-Road 4x4, sr5/leather
    I had a Toyota "case manager" that calls me about once a month on this. He claims Toyota has a tsb that's about to come out for it. Of course he has been telling me that for 3 months now... he also claims there is a driveline vibration tsb that's coming out before the end of the year... yeah, better get moving on that one buddy. The crazy part about it is that everyone he calls he starts mentioning Toyota buying back my truck! Wth? I'm half tempted to tell him yes if they don't have at least one of the fixes next time he calls. I tell him everyone that it would be a great truck if it just didn't vibrate and squeal down the road... :rolleyes: maybe I'll take him up on the buyback offer just to see what he says
  18. Dec 2, 2012 at 5:59 AM
    Murman
    North Carolina
    I've only got 800 miles left on my free ToyoCare warranty. If these TSB's are released after my warranty expires, will Toyota still repair them for free? I've already been to the dealership about the brakes and even paid them to balance my tires to try to get rid of the vibration on the hwy.
  19. Dec 3, 2012 at 7:54 PM
    TruckyTruck
    As long as the dealer you have been going to has it on file that you have these problems now, they should fix it at no cost. You should contact Toyota 800 number and open a case with those issues. They will give you the case number and you can explain that its been going on for however long. That way they will have it on file there. Just cover your bases.
  20. Dec 3, 2012 at 7:57 PM
    J Rod
    J Rod Loves Sammiches.
    Jared
    Where theres more livestock than humans.
    2010 FJC
    16x8 Method NV Wheels, 285/75/16 Duratracs, Axe/Shovel Mount for Roof Rack, Tuffy Light Mount, Rigid Industries 40" LED light bar, Husky Liner floor mats, TT Blackout all around.
    My taco has done it since I drove it off the lot and my old Lexus did the same exact thing. Must be a toyota thing.
