60-65 mph vibe under load and dynamat
Old 10-25-2011, 09:03 AM   #1
matts11 [OP] matts11 is offline
matts11 will become famous soon enoughmatts11 will become famous soon enough
matts11's Tacoma Gallery
Decided to post this in a new thread. I know a lot of us have some degree of vibration/hum under throttle when cruising at 60-65. I personally have it very slight and think it is related to the vibration of the engine. I have noticed I feel it most in the pedal, as if I use cruise control and keep my feet off the pedal I don't notice it. So here is my thought, if I bought the a small piece of dynamat and put it on the firewall behind the pedal and insulation and then reinstalled the pedal would that dampen the vibration? Can dynamat be used for this? Should I line as much of the firewall behind the insulation as possible and then put it back together? I still wonder if this is not related in some way to the engine/trans mount. I have read where people have had almost every driveline component replaced but not the mounts..anyhow, thoughts on the dynamat? Will it dampen this type of vibes?
Old 10-25-2011, 10:04 AM   #2
jassco has a spectacular aura aboutjassco has a spectacular aura aboutjassco has a spectacular aura about
jassco's Avatar
jassco's Tacoma Gallery
Have you tried making sure nothing is lose? I highly doubt this but even with my 4 banger there is some degree of vibration in everything. I think this might be the "its a truck not a car" deal. My vibes were pretty bad with stock tires until i got new ones and force balanced them. No more vibes. Take it back if you are unhappy.
I wouldn't recommend messing with the accelerator given its weak and plastic already. DO NOT put this on the metal where pedal mounts then screw the accelerator piece onto it. Adding sound insulation to the firewall might dampen engine noise a little but not much for vibrations given how stiff the firewall metal is.
Old 10-04-2012, 07:06 PM   #3
Chief1959 is on a distinguished road
Air Force: 159th Fighter Wing/F-15 Crew Chief
Chief1959's Tacoma Gallery
I just replaced my driveshaft, problem solved. Totally. The damper inside the shaft was loose.
Vibration at 60 MPH??? GeoTaco1 2nd Gen. Tacomas 170 04-23-2014 09:02 PM
25 MPH Vibe bishtacova 2nd Gen. Tacomas 16 10-12-2010 11:03 PM
RPM's at 65 MPH???? 90YotaPU 2nd Gen. Tacomas 11 09-24-2010 07:53 PM
Vibrations in the steering wheel from 60-65 mph...any ideas? TacomaGus 1st Gen. Tacomas 6 08-22-2010 09:12 PM
noise at 60-65 mph steveb 2nd Gen. Tacomas 3 09-08-2008 07:02 PM
