Need Help. Removing Driver Side CV Axle!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bjmoose, Nov 6, 2011.
  1. Nov 6, 2011 at 6:39 PM
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    Removing my CVs so I can drop the diff and have the shop install ARB and gears.
    I pulled the passenger side OK, after applying a drift to the notches on the inside CV axle and wailing on that thing with the BFH like a muthafucka.
    But the driver side has a worse access angle. Because of the diff itself, I can only get my drift in there at a 45 degree angle, and the angle to swing the hammer through is worse, as well. So a swung (swang?) for all I was worth, but the splines on the driver side CV remain firmly stuck within their home.
    I tried prying with a crowbar, but couldn't really get good purchase to get an effective pull.
    Advice? Helpful tips?
    I'm thinking I may purchase an electric impact hammer.
  2. Nov 7, 2011 at 5:19 AM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    monday morning bump. I know quite a few TWers have pulled CV axles....
  3. Nov 7, 2011 at 6:20 AM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    Newlife likes this.
  4. Nov 7, 2011 at 7:35 AM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    I'm taking the thirds to Rear End Specialties in Santa Clara. They also did JBerry's gears for him. Without turning this into a "gear selection" thread - I got Nitro 4.88s. 4.56 seems to be a good choice for V6, 4.88 for 4 banger.
    Back on topic: what/where did you use as a fulcrum for the prybars? There's a big bolt on the diff itself rearward that I can see using 1 at - I tried the crowbar there. Where's the second?
  5. Nov 7, 2011 at 7:38 AM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    Also, I see you can "hammer" on those bars - did you pry with them, or place them and hammer on them?
  6. Nov 7, 2011 at 7:39 AM
    jandrews
    '09 FourDubDee TRD OR
    Every time I've pulled one, a bigass prybar, multiple attempts at multiple angles, and some "gentle" taps with a 2.5lb sledge (as gentle as you can be) have gotten them out.
    I'd say keep trying, vary your angle of attack.
  7. Nov 7, 2011 at 7:42 AM
    Wicked 2007
    Bay Area, CA
    I usually use just one. I have had my front diff out twice and my CV's off a lot so hard to explain by typing - I wish I was closer to SJ I would swing by.
    I use the bar to pry and you can also hit them with a hammer - sometimes hitting it just right it pops it right out.
  8. Nov 7, 2011 at 7:42 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    crowbar and a rubber mallet on the hammer. the cclip is a bitch to center.
    ive taken off my passenger side one time, and my ddriver side three times.
    i feel your pain.
  9. Nov 7, 2011 at 7:45 AM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Try to get two prybars in there and pry with them at the same time. This is how i have always done mine, never needed to use a hammer. Granted, I do have a 1st gen but there cant be that big of a difference.
  10. Nov 7, 2011 at 7:45 AM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Drivers side is a bitch. "Pry" tactics did not work when I pulled out 05moose's axle. Let me try to paint the picture. Lay under the truck on your back with feet facing out the front. With left hand Take prybar and place tip on the lip of the inner cv housing. Grab the largest hammer you have (4-5 lb sledge) with your right hand and take aim on the opposite side of the prybar. You are going to want so smack the hell out of it so try to position yourself to get a good swing. hopefully this makes sense. Let me know if you need more clarification.
  11. Nov 7, 2011 at 7:47 AM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    1st gens are easy. Pry tactics work every time. Second gen = pita
  12. Nov 7, 2011 at 10:33 AM
    Rebel Taco 22
    Gotcha
    Good luck man.
  13. Nov 7, 2011 at 10:48 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
  14. Nov 7, 2011 at 5:55 PM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    TW Comes Through! :bananadance:
    Stopped at sears on the way home and picked up Wicked's prybars and a 4lb short handle engineer's hammer. (I'd been using a 40 oz long handle as my BFH)
    Selected the middle length prybar [​IMG]
    Place it alongside the diff and up against the grooves on the axle
    Fewer than 10 whacks, and this is the result:
    Yes! Yes! Yes!
    Rep for everyone.
    SAR Taco and Crom like this.
  15. Nov 7, 2011 at 6:00 PM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    :humble:
    Glad it worked out. :D
  16. Nov 7, 2011 at 6:01 PM
    92LandCruiser
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Good deal, just for future reference. I used some tire spoons as the pry bars I had on hand weren't working out. I just placed them between the axle and the housing and popped em out. Like sort of against the dust seal, more against the lip of the tube though.
  17. Nov 7, 2011 at 6:08 PM
    jandrews
    Glad you got it out. And yeah, they rarely come out easy. Have fun diff swappin! Hopin to do some of that myself soon!
  18. Nov 7, 2011 at 6:20 PM
    Wicked 2007
    Bay Area, CA
    Awesome! Glad it worked out.
  19. Nov 12, 2011 at 11:15 AM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    flip side - any tips on reinsertion? I've been at it for almost an hour now...
  20. Nov 12, 2011 at 11:35 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Grease the splines to keep c-clip centered. take off spindle, as the shaft absolutly has to be put on centered, cause if you try and wrestle it around the spindle you will bump cclip and throw off everything
