2012 Whistling sound indentified
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Appljaxx, Nov 23, 2011.
  1. Jun 17, 2013 at 5:12 AM
    #181
    VoyageTacoma
    VoyageTacoma Active Member
    Paul
    Denver, Colorado
    2013 Tacoma 4x4 TRS Sport
    I'm still fascinated at the systemic ineptitude of this problem.
    I had to fix my own whistle which was possible due to this thread.
    I'd still have a whistle 6 months after buying my car if I hadn't taken initiative on my own. The degree to which they kind of shrug their shoulders is pathetic.
    Customers have practically figured out the problem a million years ago and they still seem in the dark on it.
    I pointed out to them that most if not all the trucks in their lot are defective because of this.
    Anyway, this thread is the cure.
  2. Jun 19, 2013 at 7:55 AM
    #182
    ktnTacoma
    ktnTacoma New Member
    Alaska
    22.6 MPG
    After reading all these threads, apparently there are two types of whistle in question. The deer call whistle is a windshield thing. The high pitch whistle is a grill to hood seal thing.
    My 2013 had the high pitch whistle that I fixed with $1.53 (3 feet) of windshield washer hose (1/4" OD) purchased at Napa. The hose didn't simply slide in there as the pictures in this thread illustrated. The 2013 upper channel of the grill to hood seal was smaller. I fished the tubing through with a wire attached to a string tied to the tubing then pushed and pulled it through with wd40's help to slid it though.
    Problem fixed with no dealership hassles.
    Thanks TacomaWorld
  3. Jun 19, 2013 at 10:56 AM
    #183
    NateTRD
    NateTRD Well-Known Member
    2013 Red Tacoma TRD Off Road DCSB
    IFS Skid Plate, All-Pro Sliders, OME Lift, 33" Cooper ST MAXX
    Just as an update, I got the grill installed about a week ago and haven't heard the whistle yet.
  4. Jul 16, 2013 at 6:10 AM
    #184
    Jux
    Jux :D
    Steve
    Northern Colorado
    2013 V6 4x4 SW DCSB TRD OR
    Did they give you any grief about the TSB being only for the 2012 year so far?
    I took delivery of my 2013 last Friday and the noise popped up on mine this morning once I hit 45 on the highway. Frustrating to have a truck with 200 miles on the odometer and something has already come up, let alone to hear that some people are getting the run around for trying the drip line fix.
  5. Jul 16, 2013 at 12:03 PM
    #185
    Fletch
    Fletch Well-Known Member
    John 14:6
    Orange County, Ca.
    Tacoma PreRunner
    i have a '13 dc. i hear the noise from 50 mph +. i did the tube trick, just so happen to have laying around. so i'll let ya know if it works. i thought it was the windshield..but..will see..it still may be..??
  6. Jul 16, 2013 at 12:09 PM
    #186
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    Man I'm glad I don't have this, sounds annoying as hell!
    On the other hand, my drivers side window controls vibrate a bit when I have loudish music playing. If I touch the panel with the switches it stops. I might need to take apart the door and foam tape it up.
  7. Jul 16, 2013 at 1:06 PM
    #187
    Jux
    Jux :D
    Steve
    Northern Colorado
    There are two TSB's out for whistling noises on the 2012; one is the grille and the other is a windshield. Seems like both might apply to the 2013 too. Grumble grumble.
  8. Jul 16, 2013 at 1:52 PM
    #188
    Fletch
    John 14:6
    Orange County, Ca.
    Tacoma PreRunner
    my dads old el camino whistled LOUD. you could hear the camino coming 1 full city block away at speed!:D it was the grill.
  9. Jul 16, 2013 at 3:18 PM
    #189
    Jux
    Jux :D
    Steve
    Northern Colorado
    Yes, that's what I want out of a four day old truck: to invoke memories of an old El Camino.
  10. Jul 17, 2013 at 3:15 PM
    #190
    AlpineTaco
    AlpineTaco Member
    Luckily found this thread. Used 1/4" drip line and the whistling is gone! Very helpful, thank you TW!
  11. Jul 20, 2013 at 8:16 PM
    #191
    SSgtTrap
    SSgtTrap Two Shoes
    Trap
    VA
    13, PreRunner, SR5, Dbl Cab
    DeWhistled!
    Took home a 2013 Tacoma a couple weeks ago and was instantly losing my mind over this whistling. A google search later I discovered this thread, and my problems are solved. 1/4" OD drain tube from Home Depot and some WD 40 work miracles. I am now a member of Tacoma World, and look forward to gleaning even more great tips and info.
  12. Jul 20, 2013 at 8:19 PM
    #192
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    U.S.A.
    2023 RAV4 XLE Premium
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    . . . Sub'd
  13. Jul 20, 2013 at 8:27 PM
    #193
    Fletch
    John 14:6
    Orange County, Ca.
    Tacoma PreRunner
    well i just did the "hose through the seal under the hood" trick, and bam! whistle is gone! much thanks!!!
  14. Jul 22, 2013 at 8:16 AM
    #194
    MaxQ
    MaxQ Active Member
    Southern California
    '13 PreRunner SR5 4x2 with exaust tip.
    Welcome aboard Sgt. Trap! I had the same problem, until I found this site. Now I'm hooked.
  15. Jul 22, 2013 at 7:56 PM
    #195
    greg986547
    greg986547 New Member
    2013 white manual 4x4
    you guys are awesome.... new truck on Saturday....drove it home thinking I bought a tea kettle by mistake...found this thread and fixed in a couple minutes with some 1/4 inch water line from Lowes....
    thanks!
  16. Jul 24, 2013 at 10:22 PM
    #196
    drstu
    drstu Member
    Alabama
    '13 DCSB TRD Off-Road in Super White
    Coming soon!
    Had mine in to the dealership last Saturday for the 5000 "service" i.e. free oil change. I told them my 2013 DCSB started it the day I drove it off the lot. I told them I figured it was either the grill or windshield after researching it online. The punk kid service writer responded quickly with, "Oh no it can't be 'cause that was on the 2012s and they've fixed it since then," to which I replied, "Wanna bet?"
    At any rate, he heard it for himself and said I'd have to bring it back and leave it at least a whole day for them to "figure out what was causing it." I'm doing the hose trick tomorrow and hoping it works.
  17. Jul 25, 2013 at 1:15 AM
    #197
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    My '13 had the 40mph whistle. I noticed that the gap between the grill and hood was not parallel the day I bought it. I loosened up the passenger side top grill bolt, pushed the grill in, and re-tightened. Gap is parallel & whistle is gone!
  18. Jul 25, 2013 at 7:48 AM
    #198
    drstu
    drstu Member
    Alabama
    Coming soon!
    Gonna check this out today. I'll post findings.
  19. Aug 1, 2013 at 7:29 AM
    #199
    speddmn
    speddmn Well-Known Member
    Omaha
    TACOCAT
    Basics
    This thread is the stuff miracles are made of - my new truck is no longer annoying the piss out of me!:D
  20. Aug 2, 2013 at 12:52 AM
    #200
    gbell210
    gbell210 Active Member
    Gary
    Poulsbo, WA
    '13 TRD Offroad DCSB
    I took mine into the dealer, so at least the problem is documented by them and they can spent the $2 for hose. They told me they found a fix online (I'm assuming from here) and inserted some hosing. At first it was gone, now I can still slightly hear it. It moved from starting at 45mph to now around 60ish. I'll revisit their fix to see what they actually shoved in there.
    Does anyone know if the problem is solved by installing a bug deflector? I'm looking at non-OEM ones that would mount under the hood, and would think it would reduce that gap size even more.
