Remove 2012 Tacoma climate control panel
Old 11-23-2011, 03:03 PM   #1
Scuzzlebutt is on a distinguished road
Scuzzlebutt's Tacoma Gallery
Since the dash is a little redesigned, I was wondering if removing the climate control panel is any different... Going to try and remove it to install the panavise bracket to mount an iPhone dock. From searching, I saw that some folks use a hook tool to unlatch the clips. Can anyone confirm that it'll be the same for a 2012?
Old 11-23-2011, 03:04 PM   #2
Banned
It looks like it would be the same.
Old 11-23-2011, 03:15 PM   #3
Doc Foster is on a distinguished road
Doc Foster's Tacoma Gallery
Keep us updated, I was wondering the very same thing - how easy or difficult it would be to remove.
Old 12-08-2011, 03:05 PM   #5
Still haven't really attempted to do it yet. I bought these http://www.amazon.com/Pro-Fit-Intern.../dp/B001RLG8S4 from Amazon and they look a little too fat to squeeze between the dash and the climate control panel. Does anyone have a write up on how to get the panel out? I'd hate to scratch the hell out of it.
Old 12-08-2011, 04:20 PM   #6
platinumb is on a distinguished road
platinumb's Avatar
platinumb's Tacoma Gallery
those aren't good tools for panel removal i got mine from a snap on truck but you can get the same thing at harbor freight if you have one near you they are made from plastic that wont scratch panels.
Old 12-09-2011, 08:54 AM   #7
Ok, i'll try and find a plastic one. But what do I do with the tool? From looking at pics, it looks like the panel is held on by tabs at each corner.
Old 12-15-2011, 08:07 PM   #9
AaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shed
AaronArf's Avatar
Navy:
AaronArf's Tacoma Gallery
BUMP...
I had never removed the previous year Tacoma's climate control panel, but when FLYZEYE was test fitting their V2 LED light on my 2012 we removed it. Apparently it is similarly designed but slightly more difficult to pop off.
Grabbing the knobs and pulling does not work. Just work the area's near the fasteners to get it to pop off with a flat blade tool.
Old 12-16-2011, 05:35 AM   #10
sherlock will become famous soon enough
sherlock's Avatar
sherlock's Tacoma Gallery
Thumbs up
Oh yeah........ Thanks! Pictures are worth a thousand words. Clips noted top and bottom of the panel..
Old 12-16-2011, 09:44 AM   #11
docjake has a spectacular aura aboutdocjake has a spectacular aura aboutdocjake has a spectacular aura about
docjake's Avatar
docjake's Tacoma Gallery
I am sure this will be asked a million times:
Is the wiring harness for the climate controls the same as previous years? You said that you have not removed one before so you might not know but can anyone chime in by looking at the plugs?
Old 12-17-2011, 03:55 PM   #12
AaronArf's Avatar
Navy:
Bump for more info on the 2012 VS 05-11 electrical connectors.
Old 01-16-2013, 07:44 PM   #14
dibble9012 has a brilliant futuredibble9012 has a brilliant futuredibble9012 has a brilliant futuredibble9012 has a brilliant futuredibble9012 has a brilliant futuredibble9012 has a brilliant futuredibble9012 has a brilliant futuredibble9012 has a brilliant futuredibble9012 has a brilliant futuredibble9012 has a brilliant futuredibble9012 has a brilliant future
Air Force:
dibble9012's Tacoma Gallery
The wiring connectors are not the same, but the wiring is. If you buy a new connector and pins it'll work plug and play. I'm in the process of doing it now. Found one online cheap and bought it to match my entune upgrade.
Old 01-26-2013, 11:19 AM   #15
Tacofool is on a distinguished road
Tacofool's Avatar
Tacofool's Tacoma Gallery
I had to figure a way to get the panel off to complete a Flyzeye install today. The A/C panel is a little difficult to pull of given that the 2012/2013 dashboards have a slight facelift since the Flyeye website instructions were made. To prevent chipping any dashboard plastic, I was able to pry off the panel with a plastic ruler from the bottom lifting up. Panel comes straight out. Also, the instruction pictures for the 12-13's had the positive wire as solid light blue. Mine was solid green. Confirmed prior to the install by looking at the plug pins and process of elimination from the other wires. Other than that it was a simple install. Very happy with the added lighting.
Old 01-26-2013, 03:43 PM   #16
puma1 is on a distinguished road
puma1's Tacoma Gallery
Pictures ????
Do you have any pictures of yoiur install?Thanks.
Old 01-27-2013, 04:12 AM   #18
Rubber Side Down
Glocker23 is on a distinguished road
Glocker23's Avatar
EMS:
Glocker23's Tacoma Gallery
I like it. May do this for my galaxy s3.
Old 07-21-2013, 02:08 PM   #20
LoneCynic has much to be proud ofLoneCynic has much to be proud ofLoneCynic has much to be proud ofLoneCynic has much to be proud ofLoneCynic has much to be proud ofLoneCynic has much to be proud ofLoneCynic has much to be proud ofLoneCynic has much to be proud ofLoneCynic has much to be proud of
LoneCynic's Tacoma Gallery
Hello all, I found this topic very useful, as I was wondering how much space there was available behind that panel. I have a somewhat crazy notion that I am trying to consider here, and maybe one of you could answer it for me before I try any of it. First, are those connectors long enough that they could reach down to the cubby in front of the shifter? Would it be possible to relocate the climate controls to that location so I could use the space that they currently occupy?
09 tacoma climate control lights rektech Lighting 35 08-01-2014 01:19 PM
Help with climate control Flash 2nd Gen. Tacomas 15 05-02-2012 03:37 PM
Adding auto climate control to 09 Tacoma? xxaarraa 2nd Gen. Tacomas 10 01-25-2012 03:57 PM
Climate Control Panel Bulbs gkozun 1st Gen. Tacomas 10 01-08-2012 03:57 PM
07 Tacoma a/c control panel pgn21540 New Members 0 11-26-2010 11:22 AM
