5 lugger: upgrade to 16 inch from 15 inch .. ?
Old 11-23-2011, 06:37 PM   #1
fchen7 [OP] fchen7 is offline
fchen7 is on a distinguished road
fchen7's Tacoma Gallery
I got this information from a very useful post in this forum.
Base Steel Wheels: 15x6, +40 mm offset, ? backspacing, 5x4.5" bolt pattern, ? hub bore, ? lbs
My Taco is 05 basic silver access cab 4 cylinder 5 lugs 15 inch stock rims, no mod yet. I like to move up to 16 inch 5 lug wheels. And eventually get 235/70/16 or 235/75/16 highway tires. My questions is: how to look for 16 wheels that will fit my car ?? 16x6 ? 16x6.5 ? 16x7 ? And is the +40mm offset a required spec when i look for a wheel ?? If the stock suspension is setup for +40mm offset, then i dont want to mess with it and i would only look for +40mm offset. Or am i not making sense ?
235/70/16 vs 235/75/16. It's a difference of about 1 inch. How will you pick ? I am going for the look. I need to mention that the truck is getting the Bushwacker pocket style fender flares painted and install this week.
thanks fo any comment .... I am learning so much about tires and rims the last day or two. But i need more ....
Old 11-23-2011, 06:40 PM   #2
I'm not 4x4, and have an open diff. So i'm 4x1
Johns Taco is one of the sharper tools in the shedJohns Taco is one of the sharper tools in the shedJohns Taco is one of the sharper tools in the shedJohns Taco is one of the sharper tools in the shedJohns Taco is one of the sharper tools in the shedJohns Taco is one of the sharper tools in the shedJohns Taco is one of the sharper tools in the shedJohns Taco is one of the sharper tools in the shedJohns Taco is one of the sharper tools in the shedJohns Taco is one of the sharper tools in the shedJohns Taco is one of the sharper tools in the shed
Johns Taco's Avatar
Johns Taco's Tacoma Gallery
Go to TireRack and put your vehicle in there and it will show what will fit, I had 18"s on my truck when it was like yours. Welcome to TW!
Old 11-23-2011, 06:46 PM   #3
afd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shed
afd23a's Avatar
afd23a's Tacoma Gallery
Here's a good website for comparing rims to fit on your truck.
http://www.rimsntires.com/specs.jsp
It gives a good visual for comparing offsets/backspacing between rims. I'm not sure exactly what would fit but 15x8 w/4.5" backspacing has been known to fit so I would think a 16x8 4.5" backspacing should fit too.
BTW the hub bore is 60.1 mm.
Old 11-23-2011, 06:53 PM   #4
ok, 4.5" backspacing .. is that also called lug pattern ?
and there is also hub bore of 60.1mm...
i think there should be a class for this, some kind of certificate ...
thanks , i will check out that web site
16 inch rims with a 6 inch lift kit kinkrider101 2nd Gen. Tacomas 19 03-31-2014 07:51 AM
15 inch rims? AlaskanTaco 2nd Gen. Tacomas 10 01-20-2012 08:37 AM
15 inch rims? stevenstaco 2nd Gen. Tacomas 2 02-28-2011 07:56 AM
Quick reference for people with 15 or 16 inch rims texasbowhunter Wheels & Tires 0 10-28-2009 07:17 PM
wheelers 15 and 16 inch steel and alloy wheels on a first gen. tacoma!!! tacomaman06 1st Gen. Tacomas 13 09-10-2008 08:00 PM
