And so it begins..Painting chrome rear bumper..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tamer, Nov 28, 2011.
  1. Nov 28, 2011 at 7:30 PM
    tamer
    tamer [OP] hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    Finally got sick of looking at my ugly, rusty chrome rear bumper..Ripped it off this morning and started sanding tonight. PITA process to do by hand, but I have no other choice, also should have worn a mask, probably took 5 years off my life tonight.
    Did a pretty good 100 grit sanding and will do a 220 wet sand tomorrow. Hopefully that, followed by a nice wash and alcohol cleaning will do the trick. I just bought some krylon primer and flat black, hopefully that will work ok.
    If anyone has done this and wants to chime in feel feel.
    Off the truck
    Rust
    After the 100 grit sanding
    Update 1:
    Picked up the supplies today...I'm hoping to get it done in the next few days..
    Update 2:
    Might get this done tonight..It's snowing and I want to park in the garage, lol
    First Primer Coat
    Update 3:
    Finished primer coat, really happy with how that turned out.
    Bedliner dripped down the side, not happy with that...I'm thinking about getting the roll on stuff, this spray is driving me crazy.
    Update 4:
    Sanded down the entire bed armor layer with 100 grit sandpaper, then wiped down with a wet cloth. Added about 4 more light coats and it turned out great! Will post another photo tomorrow when the sun is out and I get it mounted.
    Update 5:
    Here it is...Looks great, I love it! Probably gonna do the emblems and fender flares. Any little discoloration you see is just a little water from the bath.
    tacoma2g likes this.
  2. Nov 28, 2011 at 7:32 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    hell that looks 10000% better as is! just clear coat that haha
  3. Nov 28, 2011 at 7:35 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    I vote for this^^^. It will look like brushed aluminum. :cool:
  4. Nov 28, 2011 at 7:37 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    Looks good, keep us updated with your progress!
    I will either want to get a rear plate bumper or paint my chrome one sometime in the future. Wish the plate bumpers weren't so damn expensive!!
  5. Nov 28, 2011 at 7:44 PM
    OffroadToy
    That rusted bumper came off a 2008? Damm!!!:eek:
  6. Nov 28, 2011 at 8:01 PM
    07TaCo07
    07TaCo07 Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    I used spray bed liner and it looks great plus more durable than flat black
  7. Nov 28, 2011 at 8:39 PM
    tamer
    NorCal
    Yeah, I thought about that, looks pretty cool, but I'm just so sick of bare metal and rust. Hopefully I do a good enough job to keep it looking good.
    Yeah, welcome to Michigan, we use the most salt on our roads in the US. The bumper actually didn't start rusting until last winter, I was rear ended and the body shop replaced it and it started rusting almost immediately after. They said they would replace it for free, but I don't want another chrome bumper, that will rust in a month.
    Thought about that too..How much was the material, and what did you use?
  8. Nov 28, 2011 at 10:40 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    I'm agree ^^^ Gave me an idea.. I was gonna color match mine too but might do a brushed aluminum type thing now!
  9. Nov 28, 2011 at 10:54 PM
    207Copper
    207Copper Well-Known Member
    South East Kansas
    08 V6 SR5 Quad Cab Red
    16"wheels, Bull bar, Side bars, Retrax roll top tonneau cover
    If you want your paint to stick to that chrome a good sandblasting will get you where you need to be before paint.
  10. Nov 28, 2011 at 11:02 PM
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    Mines a 2009 and it's worse
  11. Nov 28, 2011 at 11:04 PM
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    i really like the bumper in it's brushed current state
  12. Nov 29, 2011 at 4:12 AM
    07TaCo07
    oregon
    I used some stuff from napa and it was like $10-$15.
  13. Nov 29, 2011 at 4:59 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Clean it with lacquer thinner, it is a better solvent.
  14. Nov 29, 2011 at 5:03 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Rustoleum makes a bed liner that's like $8-9/can. 2 cans would cover that no problem and it's got a nice black textured finish.
    Caliph420 likes this.
  15. Nov 29, 2011 at 5:06 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    The bumber off of my 2010 looked that bad after 4 months of having it.
  16. Nov 29, 2011 at 6:53 AM
    tamer
    NorCal
    I will look into that, I just want to keep this as budget as possible..If I'm going to go off and spend hundreds of dollars on prep and paint I might as well buy an all pro and sell this one.
    I'll look for that, thanks.
    What kind of prep work is needed? I'm assuming no primer?
  17. Nov 29, 2011 at 7:03 AM
    Pugga
    Massachusetts
    For bare metal, I'd have to read the can. I painted my Nfab light bar and I just scuffed up the powder coat and applied directly. A coat of primer might not be a bad idea to seal things up but I'm not 100% sure if it's required. It's a thick coating and seems to be pretty durable so far (I knicked a bollard with mine and it didn't even leave a mark :eek:)
  18. Nov 29, 2011 at 7:06 AM
    tamer
    NorCal
    Sweet...knowing my luck with things, I might as well go with something more durable, or I will put all this time in and it will all crack off in a month..Hopefully it will look good on the grille too.
  19. Nov 29, 2011 at 7:39 AM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    I did bedliner as well. It has held up flawlessly on my bumper, though not so much on my rock sliders. I think poorly on the sliders due to the fact that it was rusty underneath. I sanded it but probably should have used a rust-neutralizing coat of something before bedlining.
    My bumper had no rust to speak of before painting.
    I then took some very rough sandpaper (like 80 grit or something) and scratched the crap out of it.
    Then painted:
    Broke the plastic piece trying to remove it to paint, didn't bother trying with the other one. Ended up getting a new one from someone on here I think.
    Anyways, it basically still looks just like that after a car wash.
  20. Nov 29, 2011 at 8:43 AM
    tamer
    NorCal
    Thanks for posting man, I think those photos convinced me to just go with the bedliner :cool:
