2012 Traction control test
Old 11-30-2011, 05:09 PM   #1
Utard [OP] Utard is offline
Utard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shed
Utard's Avatar
Utard's Tacoma Gallery
Does anyone know how to test if the traction control is operating correctly? Today was the first time on wet roads and I had a few times with some wheel spin. Once from a stopping turn the wheel spun fairly good. The other was a step out on a 25 MPH corner. I know I am not used to more power going from a 2.7 to a 4.0. On my dads Honda you know when the traction control is working because it uses the anti-lock brakes and makes a horrible sound.
Old 11-30-2011, 05:12 PM   #2
Banned
Floor it from a stop on a wet road or another loose surface. The TRAC/VSC light will flash(truck with squiggly lines) and you will hear ABS pump noise. The engine power will also reduce even though you have your foot to the floor.
Old 11-30-2011, 06:17 PM   #3
attack ships on fire off the shoulder of Orion
OZ-T's Avatar
OZ-T's Tacoma Gallery
The VSC only seems to engage above 35 mph
Old 11-30-2011, 06:18 PM   #4
Monkeyboy has much to be proud ofMonkeyboy has much to be proud ofMonkeyboy has much to be proud ofMonkeyboy has much to be proud ofMonkeyboy has much to be proud ofMonkeyboy has much to be proud ofMonkeyboy has much to be proud ofMonkeyboy has much to be proud ofMonkeyboy has much to be proud of
Marines:
Monkeyboy's Tacoma Gallery
It takes a half second or so for the traction control to kick in; it's not instantaneous.
The truck will beep and the light on the dash (squiggly line car light) will flash when it does.
Old 11-30-2011, 07:30 PM   #5
Utard's Avatar
That makes sense as soon as I felt the tire slip I got out of the gas. I will just have to gun it once to see what happens? Isn't the VSC different from the TC? The TC with keep you from burning out? And the VSC helps you regain control in high speed out of control problems? That is in its simplest terms.
Old 11-30-2011, 07:32 PM   #6
Banned
VSC is vehicle stability control and TRAC is traction control but yes you got it.
Do I have traction control F27Corsair 1st Gen. Tacomas 6 11-19-2013 02:01 PM
Traction Control TRDsport253 2nd Gen. Tacomas 4 12-30-2011 04:18 AM
Traction Control twfsa 1st Gen. Tacomas 3 07-25-2011 03:30 PM
Traction Control Tacoma_SR5 2nd Gen. Tacomas 4 10-27-2010 08:08 PM
traction control uuc328 2nd Gen. Tacomas 26 09-30-2008 11:06 AM
