TPMS sensor question with pics
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DAVE94LIGHTNING, Dec 9, 2011.
  1. Dec 9, 2011 at 8:43 PM
    DAVE94LIGHTNING
    DAVE94LIGHTNING [OP] Well-Known Member
    I'm trying to build a capsule to pressurize to get rid of the low pressure warning light. I need to know if I can just use one sensor as the valve and just keep the rest of the sensors in the capsule or do I need to fill each sensor?
    Tube drilled for valve
    One Valve installed
    Can the rest just sit in the canister??
  2. Dec 9, 2011 at 8:54 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    The rest can just sit in the can. Nice design. :thumbsup:
  3. Dec 10, 2011 at 7:35 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    Love my 06 mod to turn it off
  4. Dec 10, 2011 at 7:58 AM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    what is your 06 mod to turn it off? it would be nice if it only monitored your spare. the one tire u cant visually see all the time and your screwed if its flat and u need it.
  5. Dec 10, 2011 at 8:02 AM
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    You can just install all the sensors in the spare tire... Same concept as above.
  6. Dec 10, 2011 at 8:03 AM
    Hayes
    Brandon
    Denver, CO
    What are you using to seal the ends? I built one of these but have had problems with sealing the ends. It leaks like mad and I gave up recently.
  7. Dec 10, 2011 at 8:35 AM
    DAVE94LIGHTNING
    ABS adhesive and RTV.
  8. Dec 10, 2011 at 11:42 AM
    DAVE94LIGHTNING
    DAMN...wish I thought of this before buying all the crap to build this contraption. LOL I think i'll just do the spare tire thing and call it a day. Do you know if they have to be "loose" in the spare tire to read the pressure or can they be in a little baggie etc....I'm assuming loose or it wont get an accurate pressure reading. Maybe i;ll just use ruber adhesive to stick them to the ratial tire wall on the inside.
  9. Dec 10, 2011 at 1:32 PM
    JKD
    JKD Well-Known Member
    I think you're still going to want to be able to balance your spare.
  10. Dec 10, 2011 at 1:46 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    I think that I would try to anchor them equidistant around the inside (deepest) part of the wheel (not tire).
    Wouldn't want to try to stick them to rubber and you definitely don't want them loose in there.
    Might use epoxy or banding to anchor them.
  11. Dec 10, 2011 at 4:14 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    darn, where did you get instructions for that thing. plenty of instructions on this forum to build one. I made a "pipe bomb", and it works fine.
  12. Dec 11, 2011 at 10:36 AM
    DAVE94LIGHTNING
    Instructions? Who the hell uses those? lol
  13. Dec 11, 2011 at 1:16 PM
    boatswain
    carl
    palmerton,PA.
    UHH!! ME :D! :anonymous:
  14. Dec 11, 2011 at 2:40 PM
    Phantom
    Phantom Well-Known Member
    Northern NJ
    2011 TRD Sport Double Cab
    What happens if you get new tires and dont have the sensors installed? Other then the light always being on is there anything else? This is the first time Ive had a truck with TPMS.
  15. Dec 11, 2011 at 5:06 PM
    weazel
    weazel Well-Known Member
    I did the same thing and working great for over a year
  16. Dec 11, 2011 at 10:04 PM
    Hayes
    Brandon
    Denver, CO
    If you mount them in the drop center of the wheel, you will break sensors every time you dismount the tire. The drop center needs to be used to install and remove the tire.
    Op, if you install them in a Baggie, you won't get a good reading because inside the bag will have a different pressure than the rest of the wheel.
    Throwing out an idea, you could probably drill out more valve holes very close together on the spare if you are concerned about mounting them solidly and balance it...
  17. Dec 11, 2011 at 10:07 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    i seen someone at TTORA do this a few years back..pretty cool.
    be fun tho in explaining what appears to be a pipe bomb in the pack seat of your taco if searched by law enforcement for whatever reason hahah
  18. Dec 11, 2011 at 10:13 PM
    jflan
    Vancouver, WA
    I'd thought about that, but why not equidistant ?
    Seems like it would balance better that way.
  19. Dec 11, 2011 at 10:17 PM
    Hayes
    Brandon
    Denver, CO
    If you watch someone mount a tire, there is one section that has to get 'tight' on the wheel to mount it up an if the sensor is in that spot, you will break a sensor. Therefore if you mount one at at every 45 degrees, you'll actually break 3 out of 4 sensors while mounting the tire.
    It's hard to explain but if you saw it, you'd see why immediately.
  20. Dec 11, 2011 at 10:22 PM
    Hayes
    Brandon
    Denver, CO
    Plus it is your spare, which (theoretically) only needs to be balanced for shorter distances. Having a heavy weight on the wheel won't affect the wheel and tire for as long as it takes to get to a place to get your tire fixed or replaced.
