step by step removal and installation of e-locker 3rd member
Old 12-21-2011, 10:27 PM   #41
Power Top
MonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shed
MonkeyProof's Avatar
Army: K9 Handler
Gender: Tranny
MonkeyProof's Tacoma Gallery
Send a message via MSN to MonkeyProof Send a message via Skype™ to MonkeyProof
thanks
Old 12-21-2011, 10:48 PM   #42
Go home if you don't like guns liquor and whores.
maxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shed
maxamillion2345's Avatar
maxamillion2345's Tacoma Gallery
Is that a HF floor jack?
Old 12-21-2011, 10:59 PM   #43
Power Top
Army: K9 Handler
Gender: Tranny
why yes it is lol, and the jack stands are as well..
it's a 2 ton low profile HF jack. works great and i have had no issues with it. there's also a few at my dealership that have been around for years and they are still working great. seems like any orange colored jack from HF works great without any issues. just stay away from the blue and silver colored ones, just from my experience anyways
Old 12-21-2011, 11:30 PM   #44
BlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shed
BlueT's Avatar
BlueT's Tacoma Gallery
I dont know what oil you are using but no wonder you are breaking thirds. That oil supposed to be clean
Old 12-21-2011, 11:40 PM   #45
Power Top
Army: K9 Handler
Gender: Tranny
that's motorcraft gear oil coming that you see coming out. normally i use Royal Purple, but since i was in between diff's (this is my spare that broke) i was using generic oil in the mean time because the good stuff costs some coin.
edit: that's my catch all bucket and it as a bit of everything in it since it hasn't been emptied in a while. all considering, i think the condition of the gear oil that drained out was in good condition.
Old 12-21-2011, 11:47 PM   #46
Lol sweet. I love to wander at HF.
Thanks for the review. I've been wanting one.
Old 12-22-2011, 08:43 AM   #47
BlueT's Avatar
That oil is crap, it should not look like that. (not before 60k on it) I wouldn't use that oil again and just go with sync.
Also dont know if it is a picture but that diff looks like it has wear marks in wrong places. It looks misaligned and that could have been contributing factor to break up. If you look on where wear marks are pinion was riding on the edge of the ring and thats where tooth had broken. So bad oil plus bad setup may have been a reason why you lost that diff so quickly. Now it could be that after last damage something in carrier is crooked so you are probably better off just getting whole another third.
Old 12-22-2011, 08:57 AM   #48
Power Top
Army: K9 Handler
Gender: Tranny
This is my original 3rd that came with my truck. I use it as my spare when the other one is broke. But now they are both broken. How you see it is how it came from the factory at Toyota. But I agree, the wear marks are questionable on the ring, the pinion is just fine
Old 12-23-2011, 04:48 PM   #49
ECGS is one of the sharper tools in the shedECGS is one of the sharper tools in the shedECGS is one of the sharper tools in the shedECGS is one of the sharper tools in the shedECGS is one of the sharper tools in the shedECGS is one of the sharper tools in the shedECGS is one of the sharper tools in the shedECGS is one of the sharper tools in the shedECGS is one of the sharper tools in the shedECGS is one of the sharper tools in the shedECGS is one of the sharper tools in the shed
ECGS's Avatar
ECGS's Tacoma Gallery
Don't use royal purple ever under any circumstance!!! Likely the worst gear oil ever made. 15k diffs with royal purple look like they have 200k on them. It thins out and provides no gear cushioning and does not control heat.
Good write up, a couple of options to save time and aggravation. If you remove the brake line bracket Clip, you can cut a line just big enough for the hardline to sneak up through on the bracket, this way you do not have to disconnect the actual brakeline just move the caliper out of the way, and you wont have to bleed the brakes. Also removing the Ebrake cable bracket on control arm gives you enough room to slide shaft out of diff for removal and then as said slide them back in once diff is removed to keep them off the seal.
Old 12-23-2011, 04:53 PM   #50
Man, Myth, Legend
bakerla is one of the sharper tools in the shedbakerla is one of the sharper tools in the shedbakerla is one of the sharper tools in the shedbakerla is one of the sharper tools in the shedbakerla is one of the sharper tools in the shedbakerla is one of the sharper tools in the shedbakerla is one of the sharper tools in the shedbakerla is one of the sharper tools in the shedbakerla is one of the sharper tools in the shedbakerla is one of the sharper tools in the shedbakerla is one of the sharper tools in the shed
bakerla's Avatar
Army: Always Out Front
bakerla's Tacoma Gallery
got a recommended brand?
Old 12-23-2011, 04:55 PM   #51
ECGS's Avatar
Lucas 85w140 Dyno oil. Do not waste your money on synthetics in Ring and pinion applications. Amsoil and Mobil 1 likely have no negative effect that we can see but no gain and you pay for it.
Old 12-23-2011, 04:57 PM   #52
Sorry to pester you Chase but what are the pros/cons of 85w-140 over a 90 wt (stock)?
Old 12-23-2011, 05:05 PM   #53
SoCal LED Dash Swap
Jerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shed
Jerez's Avatar
Name: Roderick aka Royer
Jerez's Tacoma Gallery
x2
...and subd for future reference
Old 12-23-2011, 05:12 PM   #54
Carolina Alliance Southwest Region Ambassador
jandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shed
jandrews's Avatar
jandrews's Tacoma Gallery
Generally speaking, heavier weight gear oil will have greater tolerances for (and provide better protection during) stressful use (high heat, high force, etc.) such as will be seen when towing, offroading, and doing other truck things.
Old 12-23-2011, 05:42 PM   #55
With the downside of added resistance, no?
(not that that really matters at this point)
Old 12-23-2011, 05:43 PM   #56
jandrews's Avatar
Correct. Typically, mileage suffers a little bit. But then, you didn't buy a truck for mileage, did you? If you did, you fucked up
Old 12-23-2011, 05:47 PM   #57
I can tell you I didn't throw 35s on for mileage.
Old 12-23-2011, 06:49 PM   #58
Ban Pending
HBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shed
HBMurphy's Avatar
HBMurphy's Tacoma Gallery
...just move the caliper out of the way...
Oh man if we only could - the drum brakes on these things suck!!!
Old 12-23-2011, 08:32 PM   #59
Yeah seems like Chase is thinking of FJs/T4Rs
Old 12-23-2011, 09:20 PM   #60
ECGS's Avatar
DRUMS!!!! WTF haven't we evolved from these........... well that is a sweet trick for disc brake rears anyway.
As for oil-- 90 weight oil is fine but the 85/140 provides more protection against heat and provides better cushion, holds to the gear better. For Alaska members you may want to run 90 weight otherwise drag is not an issue.
Cheap 4X4 Switch Illumination - Step By Step Write-up Scooter Lighting 41 09-27-2014 05:10 PM
Front bumper removal step by step? 04TacoTRD 1st Gen. Tacomas 9 09-12-2011 06:28 AM
Need detailed step by step help w/ changing brake pads/rotors BAP_29 Performance and Tuning 43 06-29-2011 12:59 PM
FS (am in N.S.) : Hitch step & step rails HwyRogue Canada 2 02-17-2010 11:28 AM
Rear Bumper Step Plate Removal dirto 2nd Gen. Tacomas 0 04-16-2009 10:30 AM
