Instead of a tow ball, shackle instead.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jw1983, Jan 21, 2012.
  1. Jan 22, 2012 at 3:08 PM
    #41
    jw1983
    jw1983 [OP] Well-Known Member
    Jason
    Alberta
    13' Tacoma Access 4x4 OR
    I went to Princes Auto and they didn't even have shackles. They had tow balls everywhere lol. It looks like I am going to order from online if I'm not able to find a local shop that carries them. Oh well, I know I will get one.
  2. Jan 22, 2012 at 3:59 PM
    #42
    jw1983
    Jason
    Alberta
    If they have it on .com could I get it on .ca? How is the shipping to when it comes to parts like this? Is it expensive?
  3. Jan 22, 2012 at 4:37 PM
    #43
    HumboldtReign
    HumboldtReign Where the Grass is Green
    Bay Area
    '05 PreRunner TRD Off-Road
    forigve my ignorance, but...what would you use a shackle for?
  4. Jan 22, 2012 at 4:51 PM
    #44
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Pulling people or being pulled from ditches. Other truck to strap applications like dragging logs around for firewood stuff etc would work as well.
  5. Jan 22, 2012 at 10:06 PM
    #45
    HumboldtReign
    Bay Area
    i thought that was most logical answer, thanks for confirming!
  6. Jan 22, 2012 at 10:59 PM
    #46
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    PA here has shackles, tons of them. But watch their weight rating, I found they were low for their size (weaker steel?) that's why I went with ARB. They were about $8 each and I only bought two.
    Receiver hitch/shackle:
    http://www.princessauto.com/mobile/product/productDetail.jsp?productID=8386088
    Shackles:
    http://www.princessauto.com/mobile/product/productDetail.jsp?productID=3800394
    They have all sizes and weight ratings. Just search "shackle"
  7. Jan 23, 2012 at 6:05 AM
    #47
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I not sure if it really matters but as some have mentioned there are "solid metal" hitch/shackle combos which I felt more comfortable with. I always run with it unless I am towing the boat.
  8. Jan 23, 2012 at 9:55 AM
    #48
    MRW
    MRW Well-Known Member
    Marco
    Sunny San Diego
    2006 DCSB PreRunner
    See my build page!
  9. Jan 23, 2012 at 10:40 AM
    #49
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    This is the one I got- both are solid steel hitches... seem very simular?
    http://www.amazon.com/Smittybilt-29312B-Receiver-Shackle-Receivers/dp/B001CF1A7O/ref=pd_sbs_auto_1
  10. Jan 23, 2012 at 10:44 AM
    #50
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    They are very similar, I leaned to the CSI one because several people mentioned in their review that the smittybuilt was a loose fit and rattles a bit. Nothing some plastic or cedar shims wouldn't fix ... but meh.
  11. Jan 23, 2012 at 10:53 AM
    #51
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  12. Jan 23, 2012 at 10:54 AM
    #52
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    Timichackle FTW.
    love mine.
  13. Jan 23, 2012 at 11:15 AM
    #53
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I'm happy with my Warn shackle
  14. Jan 23, 2012 at 2:48 PM
    #54
    s13bdafocker
    s13bdafocker Well-Known Member
    Daniel
    Lake Havasu City
    2002 Taco TRD SR5 4x4
    3'' lift with 33'' tires and a high lift jack thats all rite now
    I made mine for free from stuff i got from work.
    I took a old hitch ball and cut the ball plate off and used the square tube as the main part on this. I then welded a 1/4'' 2x2 plate to the end of the hitch shaft. Got 2 5/8 eyes we use at work for our base plates for our tents welded those to the 1/4'' plate then i wraped the whole thing with 3/16'' strap. The actual shackle is 1'' pin its about 5'' big. I welded up the shackle pin so no one can take the chackle. I didnt have it powder coated because i want a option to touch it up when it gets fucked up.
    This thing is big and has already been put to good use i helped a couple friends out of tight spots also used it to pull a stump out of the ground.
    I can make them if people want..
  15. Jan 23, 2012 at 3:30 PM
    #55
    SoJersey
    SoJersey South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
  16. Jan 23, 2012 at 5:10 PM
    #56
    Manwithoutaplan
    ID
    i have something like this
  17. Jan 23, 2012 at 5:20 PM
    #57
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Likewise, I have the hook as well.
  18. Jan 23, 2012 at 6:27 PM
    #58
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
  19. Jan 23, 2012 at 6:33 PM
    #59
    Manwithoutaplan
    ID
    that one looks pretty stout.
  20. Jan 23, 2012 at 10:22 PM
    #60
    anethema
    J
    Dawson Creek,BC
    x2
    Mine is nice and short and the hoop part barely sticks out past the receiver at all. I've pulled people out with it several times, no problem.
