Cleaning my throttle body and this is what I found...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DDD, Jan 22, 2012.
  1. Jan 22, 2012 at 10:59 AM
    DDD
    DDD [OP] Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I took apart my intake to clean the MAF and throttle body today. After removing the throttle body I took a look inside the intake manifold and was amazed at all the gunk inside.
    It is a thick black tar like substance all over the inside of the manifold. I used some throttle body cleaner to clean the gunk off of the throttle body and clean the opening of the intake manifold.
    Here are the pictures. The gunk is black, the camera flash makes it look brown.
    Anyone else notice this? My 4.0L V6 has about 72,000 miles.
    I am considered removing the intake manifold and attempting to clean all of the gunk out of the inside.
  2. Jan 22, 2012 at 11:01 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    I'd like to know what filter you run!?
  3. Jan 22, 2012 at 11:03 AM
    DDD
    Derek
    Santa Clarita, CA
    Been using a AFE Pro dry for the last 20k miles. Cleaning it when I change oil and after off-roading.
    Before that I used a stock drop in filter.
  4. Jan 22, 2012 at 11:04 AM
    Sunner
    Sunner Well-Known Member
    Sub'd
  5. Jan 22, 2012 at 11:07 AM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    which is post-filter, correct?
  6. Jan 22, 2012 at 11:07 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5
    Maybe a combination of pcv valve residue and dust from off-roading?
  7. Jan 22, 2012 at 11:09 AM
    covefrog08
    covefrog08 swollen member
    Vancouver Island- Canada
    08 w/west coast pin-striping
    devil horns, weather tech floor mats, Camo seat cover, window visors, premier deck w/ 6 speakers and sub, checker plate tool box, diff breather relocate, Mag light & Fire Extinguisher behind seat
    ouch that could rob some power... maybe i should look at my 4 cyl see what it looks like.
  8. Jan 22, 2012 at 11:14 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    when cleaning the plastic manifold is it safe to just take some gum gone (names wrong i think but cant remember the name) and just spray it through the runners and let it dry?
    with the runners off of course
  9. Jan 22, 2012 at 11:17 AM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    Looks like someone is a light footed driver. Like to run a little higher octane too? Spray some upper manifold cleaner down the intake and let it set. When you start it up, foot to the floor! For about 30 seconds.
  10. Jan 22, 2012 at 11:20 AM
    Sunner
    This is caused by driving lightly? And running higher Octane? Please explain. I do both, I guess I should take a peak in there to see what it looks like as well.
  11. Jan 22, 2012 at 11:22 AM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    never spray alot of gum cutter inside the intake because all that crap will go right through your cats no good. also having some oil residue inside your intake is normal. but your looks like alot of dirt is getting inside id consider a different filter
  12. Jan 22, 2012 at 11:25 AM
    ZMan2k2
    Richard
    ‘Berta
    06 Rad Red DCLB SR5
    How does octane in the gas relate to build-up in the intake? Fuel is added to the mix behind the intake valve, not anywhere near the throttle body. Not that I don't believe you, it just doesn't make sense.:confused:
  13. Jan 22, 2012 at 11:25 AM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    It looks like what you would find when you run an over oiled K&N but he's using a dry filter. Time to check the PCV valve and maybe run a catch can to cutdown on the residual build up.
  14. Jan 22, 2012 at 11:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Every intake I have taken apart has looked like that.
  15. Jan 22, 2012 at 11:28 AM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
  16. Jan 22, 2012 at 11:28 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    "When you start it up, foot to the floor! For about 30 seconds" WTF? No thanks!
  17. Jan 22, 2012 at 11:30 AM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    That's not too bad for the mileage. Clean it out, hook back up, and you should be fine. Chris2x4 probably has some good advice on this. Wherever he may roam.
    edit: nevermind, he's already spoken.
  18. Jan 22, 2012 at 11:32 AM
    jandrews
    '09 FourDubDee TRD OR
    This. Filters are not 100%, some shit gets in. After 76k miles, that's pretty normal for the throttle body.
  19. Jan 22, 2012 at 11:33 AM
    Sunner
    Oh ok, i guess that makes more sense with AlaskanTaco was saying. If you drive lightly with higher octane than you arn't burning as much gas so more carbon builds :notsure: Still not doing the pedal to the metal for 30 secs after starting.
  20. Jan 22, 2012 at 11:33 AM
    08pretaco
    az
    Filters that aren't the OEM paper material are especially prone to less filtering
