Before & After 1/2" OME spacer install, and some observations.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MxRacer190, Feb 4, 2012.
  1. Feb 4, 2012 at 1:52 PM
    MxRacer190
    MxRacer190 [OP] Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Finally got the trim package on yesterday. :D 885's, 5100s@ 0, 13mm(1/2") OME spacers. Then, went playing last night to test it out. Only rubbed a few times, but WAY less than before with just the 885's. Maybe an alignment will cure the rest of the rubbing.
    Before
    After
    Also, while doing the install, I noticed my sway bar had been rubbing the shit out of my 5100 on the driver side only. So, I went ahead and removed the sway bar even though I really didn't want to :(
    Also, I notice my LCA on the passenger side has been rubbed somehow. Idk if the LCa bottomed out(doubt it), or if my tire has been rubbing the LCA. And, idk if it was rubbing it before the spacer or after the spacer.
  2. Feb 4, 2012 at 2:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Thats an interesting mark on the LCA. Can you turn your wheels and check clearances?
  3. Feb 4, 2012 at 2:04 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    I turned my wheel all the way to the right, and there is about an inch clearance between my tire and the two spots you see, so I'm pretty sure it's the tire rubbing, but it might have been before I installed the spacers.
  4. Feb 4, 2012 at 2:05 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    A sway bar relocate kit should fix that problem.
  5. Feb 4, 2012 at 2:09 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    That's what I was gonna say^^^^^^
  6. Feb 4, 2012 at 2:10 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Yeah. I might leave it off for a while. I couldn't really notice a difference on the road. It was night and day off road though.
  7. Feb 4, 2012 at 2:14 PM
    knine00
    knine00 Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    How do you like the 885? I havent installed my lift yet but I have eibach and I am thinking about selling those and getting 885!
  8. Feb 4, 2012 at 2:16 PM
    krimson
    krimson Nothin
    TRD Off Road
    You do get more articulation with it off. I plan on taking mine off too, i want a power wagon electronic sway bar disconnect feature lol. Now that would be badass if the Off Road package came with that.
  9. Feb 4, 2012 at 2:17 PM
    krimson
    krimson Nothin
    TRD Off Road
    I love mine, the ride is really nice!
  10. Feb 4, 2012 at 2:18 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    idk compared to eibach, but compared to stock they are mucho bueno.
    Definitely. I went through a spot with ease that I'm usually left with two wheels off the ground spinning.
  11. Feb 4, 2012 at 2:39 PM
    knine00
    Hudsonville, Mi
    Stock for now
    Did you have eibach at one time?
  12. Feb 4, 2012 at 2:40 PM
    knine00
    Hudsonville, Mi
    Stock for now
    Do you have aftermarket UCA? If not, how is the alignment?
  13. Feb 4, 2012 at 2:44 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Yes, I have LR UCA's.
  14. Feb 4, 2012 at 2:46 PM
    knine00
    Hudsonville, Mi
    Stock for now
    Ok was it required or suggested to run aftermarket UCA with that lift?
  15. Feb 4, 2012 at 2:48 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Suggested, and required if you want proper alignment. Before, I was running stock UCA's with billies set at 2.5", and the outsides of my tires were getting worn pretty bad.
  16. Feb 4, 2012 at 3:07 PM
    knine00
    Hudsonville, Mi
    Stock for now
    OK thanks for the great info!
  17. Feb 4, 2012 at 3:38 PM
    krimson
    krimson Nothin
    TRD Off Road
    No, never rode in a Tacoma with Eibach's before...
  18. Feb 4, 2012 at 3:43 PM
    knine00
    Hudsonville, Mi
    Stock for now
    I cant decide if I want to switch from eibach to ome!
