High lift jack mount..
Old 02-04-2012, 04:26 PM   #1
g34rh34d [OP] g34rh34d is offline
g34rh34d is one of the sharper tools in the shedg34rh34d is one of the sharper tools in the shedg34rh34d is one of the sharper tools in the shedg34rh34d is one of the sharper tools in the shedg34rh34d is one of the sharper tools in the shedg34rh34d is one of the sharper tools in the shedg34rh34d is one of the sharper tools in the shedg34rh34d is one of the sharper tools in the shedg34rh34d is one of the sharper tools in the shedg34rh34d is one of the sharper tools in the shedg34rh34d is one of the sharper tools in the shed
Air Force: Avionics
g34rh34d's Tacoma Gallery
I saw these on Ebay. at first glance, I'm not sure why these couldn't be used on the 2nd Gen Taco rail.. If I decide to pick a set up, I'll post pics if they work.
Anyone else try these?
http://www.ebay.com/itm/Hood-Hi-Lift...item43a8bd6090
Old 02-04-2012, 04:46 PM   #2
Go home if you don't like guns liquor and whores.
maxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shed
maxamillion2345's Avatar
maxamillion2345's Tacoma Gallery
sure but whats the point... just mount them to the rail with carriage bolts if you're gonna use a bracket like that.
Old 02-05-2012, 06:44 AM   #3
Air Force: Avionics
Mounting the high lift directly to the rail certainly was a consideration, but I want it to fit beneath my cover so I thought using the brackets may be a way to do it.
Thanks for the input.
Old 02-05-2012, 12:39 PM   #4
Oh I see. I'd just suggest using some flat strap then.
The benefit of say kevins (ATO) bracket is that it drops it down and supports it on the rail and against the bed side and fender well. With a bracket like that it simply drops and you have leverage on the bed rail. I would say if you bent yourself some simple 1/8 flat strap and got some machinist t-nuts you could accomplish what you want by drilling a few holes.
Sort of an L if you follow. Or you could probably bend your own mount like Kevins.
or maybe if you flipped those ebay ones so the raised part sat against the bed, then just use some 1/2 bolts and a couple nuts to mount the hi-lift on the other side.
here is my set up
good luck!
Old 02-05-2012, 12:48 PM   #5
Some other simple ideas
http://www.tacomaworld.com/forum/2nd...other-fun.html
http://www.tacomaworld.com/forum/2nd...tml#post214515
http://www.tacomaworld.com/forum/2nd...bed-mount.html
Old 02-06-2012, 05:04 AM   #6
Air Force: Avionics
good luck!
Yes, this is ideally the way to go! some strap is a good suggestion.
Thanks for the input!
Old 02-06-2012, 05:11 AM   #7
Air Force: Avionics
Some good ideas here! I did a search on "high lift jack mount" and did not see these. Thanks for sharing!
Old 02-06-2012, 05:17 AM   #8
ระดับอาวุโส สมาชิกอาวุโส
dYL0n is one of the sharper tools in the sheddYL0n is one of the sharper tools in the sheddYL0n is one of the sharper tools in the sheddYL0n is one of the sharper tools in the sheddYL0n is one of the sharper tools in the sheddYL0n is one of the sharper tools in the sheddYL0n is one of the sharper tools in the sheddYL0n is one of the sharper tools in the sheddYL0n is one of the sharper tools in the sheddYL0n is one of the sharper tools in the sheddYL0n is one of the sharper tools in the shed
dYL0n's Avatar
dYL0n's Tacoma Gallery
Thread jack right quick,
maxamillion, do you grill chicken on your spare?
Old 02-06-2012, 09:24 AM   #9
maybe
What's better to jack a tacoma double cab? High lift jack or jack stands? jw1983 2nd Gen. Tacomas 42 04-10-2013 05:25 PM
high lift jack drops when lowering callahansd 2nd Gen. Tacomas 5 06-02-2010 10:24 AM
what is a high lift jack for? XGR50.2 2nd Gen. Tacomas 5 02-01-2010 11:15 AM
Best place to buy a High Lift Jack? MyTaco 2nd Gen. Tacomas 9 12-15-2008 07:27 AM
High Lift jack size longbow Technical Chat 18 07-09-2008 07:57 PM
