Plasti Dip questions Show me your interior !!!
Old 02-09-2012, 08:38 PM   #1
2011BlackTaco will become famous soon enough
2011BlackTaco's Avatar
2011BlackTaco's Tacoma Gallery
Hey yall i did some research through the threads but the mega plasti dip thread has to many pages to read i made it through about 15 of them. I am a novice with the plasti dip but i have noticed its just rubbed in a can and is safe on paint. Are there any limits to what can be plasti dipped. I wanna see anyones pictures of plasti dipped interior components !!! I was looking at some pictures and I i like the black dash interior components. will the textured dash be able to be plasti dipped without it looking bubbly or messed up ? Can anything be plasti dipped ?
Old 02-09-2012, 09:04 PM   #2
didnt even know i could do that. im still learning things about TW. appreciate the help!!
Old 02-09-2012, 09:06 PM   #3
Vivid Illumination
memario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shed
memario1214's Avatar
memario1214's Tacoma Gallery
I have plastic dipped a lot of things... but my interior wont be one of them. It will come off of nearly anything that rubs against it often. I dunno, try it! I wouldn't recommend it though.
Old 02-09-2012, 09:10 PM   #4
Casey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant future
Casey05Taco's Avatar
Casey05Taco's Tacoma Gallery
I had my center console and cd player area plastidipped, then I decided to remove it and painted it black.
Old 02-09-2012, 09:19 PM   #5
good point maybe i wont do the plasti dip. Would the pieces around the air vents be easy to paint black ? i have tried painting some interior pieces on other trucks but sometimes the interior pieces do not absorb color well and they start to look cracked. Any suggestions on how to prep interior for paint ?
Old 02-09-2012, 09:35 PM   #6
Vivid Illumination
Scuffing paste applied with scotch-brite pads... Then apply plastic primer... Then paint! Clear coat if you so desire.
Old 08-26-2013, 11:51 AM   #7
Texas Aggie
CO Taco is a splendid one to beholdCO Taco is a splendid one to beholdCO Taco is a splendid one to beholdCO Taco is a splendid one to beholdCO Taco is a splendid one to beholdCO Taco is a splendid one to beholdCO Taco is a splendid one to behold
CO Taco's Tacoma Gallery
it goes on easy and doesn't bubble. the more coats the better.. i think i used 5-6 coats on all my interior. The trick is masking everything off; i've found with plasti-dip that you want to mask less on the edges, because you can rub off overspray, but the P-D has a habit peeling off with the painter's tape and coming off of the plastic components. if you over taped and this happens, you can use a razor to separate them, but that's definitely not ideal.
here's my P-d interior
Old 08-29-2013, 06:41 PM   #8
Riverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shed
Riverdog's Avatar
Riverdog's Tacoma Gallery
I thought about using plasti dip on mine, but then decided to paint instead. I knew I liked the black, so I figured why do something temporary. I used SEM paint products and it turned out great. It hasn't rubbed off or worn at all and its been almost a year I think. If you go this route and have questions or anything, PM me.
Old 08-29-2013, 06:49 PM   #9
Khaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shed
Khaos's Avatar
Khaos's Tacoma Gallery
Click my build thread. Everything black on my truck, aside from the taillight gaurds, that isn't factory from the factory black is derp. Right now that would include..
Front Lower Valence, Front Grill, A/C Climate Controls, Badges, Bull Bar, and Rear Bumper.
It's awesome stuff. I had also done my cup holders and shifter surround, but due to the constant contact you come into with that area the derp wears off quickly.
Old 08-29-2013, 06:52 PM   #10
jw1983 is one of the sharper tools in the shedjw1983 is one of the sharper tools in the shedjw1983 is one of the sharper tools in the shedjw1983 is one of the sharper tools in the shedjw1983 is one of the sharper tools in the shedjw1983 is one of the sharper tools in the shedjw1983 is one of the sharper tools in the shedjw1983 is one of the sharper tools in the shedjw1983 is one of the sharper tools in the shedjw1983 is one of the sharper tools in the shedjw1983 is one of the sharper tools in the shed
jw1983's Tacoma Gallery
Steering wheel steering silver handles:
Oh shit handles.
Overhead console:
Old 08-29-2013, 06:55 PM   #11
Khaos's Avatar
The oh shit handles and console look stock still?
The steering wheel looks cool though.
Old 08-29-2013, 06:58 PM   #12
They're actually black. I know it's hard to tell because it was cloudy and rainy outside when I finished the project and took the picture.
Since that I used a stock nozzle that came in the can, there wasn't enough coats on the steering wheel, even though I did 6 coats. It came off within 2 weeks and I removed it. I am going to redo it eventually and get better nozzles.
THE PLASTI-DIP MEGA THREAD!!!!!! mmtaco06 Detailing 5051 01-26-2015 02:18 PM
Plasti-Dip Durability? Paczowski123 2nd Gen. Tacomas 15 07-06-2014 08:59 PM
Where to buy plasti dip!!??? th3bigk0 Off-Topic Discussion 13 01-23-2012 04:52 PM
01 Plasti-Dip Wheels? MatthewMay1 1st Gen. Tacomas 5 11-28-2011 11:14 PM
Is Plasti Dip coming off the market? Ivan Detailing 19 10-17-2011 03:51 PM
