Tire sealant?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ItalynStylion, Feb 10, 2012.
  1. Feb 10, 2012 at 6:38 AM
    ItalynStylion
    ItalynStylion [OP] Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I went to NTB yesterday because I had a nail in my rear right tire. I told him it was kinda funny because I've had to fill up my front left tire a few times in the last month but the one with a nail in it is just fine. :p
    So he asks me to come outside and shows me that I have a very very small leak in the side of the tire. It's clear nothing has happened to that area (tire looks fine) but when he put soapy water on there I could see the bubbles. He said that since it's on the sidewall he can't patch it and they don't carry those tires (Goodyear Duratrac) so he couldn't even sell me one if I wanted it.
    Questions....Can I do some sort of slime or tire sealant? Does that exist for vehicles like mountain bike tires use? I bought these tires in August from a local 4Wheel Parts; is it worth me even contacting them?
  2. Feb 10, 2012 at 6:45 AM
    ItalynStylion
    Steven
    DFW, Tx.
  3. Feb 10, 2012 at 6:47 AM
    Snake~
    Snake~ Big Member
    Blake
    DFW
    2010 DCSB TRD Sport
    Autolumination Yellow fog light bulbs, Dynomax Ultra Flo muffler, AFE Pro Dry S air filter, tailgate security mods, TRD skid plate, DeeZee bed mat, Armor Lid tonneau, OEM roof rack, TRD center caps, Satoshi grille, Sockmonkey tailgate decal
    Definitely contact 4WP. You could try a can of fix-a-flat but I would go talk to 4WP first.
  4. Feb 10, 2012 at 6:47 AM
    98tacoma27
    Ben
    Not Beech Creek
    I've used fix-a-flat before. Tire guys hate the stuff. I guess it's pretty messy when they change out tires.
  5. Feb 10, 2012 at 6:51 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2. I've used Slime in all my dirtbike and ATV tires (it's green crap with rubber beads in it). I've had nails, wood chips, screws, etc stuck in my tires and it always sealed up. It does suck when you have to change out the tire though. That crap gets everywhere so the next guy to change your tires will not like you.
  6. Feb 10, 2012 at 7:10 AM
    ItalynStylion
    Steven
    DFW, Tx.
    I guess I can contact 4WP and see what they have to say. If they don't offer any help then I might try a sealant. Is slime the preferred choice? I use it in my bike tires but wasn't sure if that carried over for vehicles. Never knew it had rubber beads in it.
  7. Feb 10, 2012 at 7:20 AM
    52motorhead
    52motorhead Well-Known Member
    If you have tire sensors dont use the junk in a can, not good for the sensors. Wolfpack is right about the side wall.
  8. Feb 10, 2012 at 7:55 AM
    Pugga
    Massachusetts
    Hadn't thought about the sensors... that slime crap would probably ruin them. How far down the sidewall is the puncture? Plugs and patches in the sidewall aren't the best idea although I've done both and never had it fail (maybe not the best idea but it worked). You have to really keep an eye on the area, you don't want a blow out. The tire shops won't touch it because of liability reasons for good reason. It doesn't necessarily mean the tire should be junked, but it needs to be watched very carefull for the rest of it's life.
  9. Feb 10, 2012 at 7:58 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    How high up on the sidewall is it? Those tire sealants work by spreading around the goop via centrifugal force as you drive. That force is going to concentrate the sealant on the tread patch area, not the sidewall.
  10. Feb 10, 2012 at 8:11 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    That time your truck took a bath under the water the other day, I bet a little snake bit your tire :devil:
  11. Feb 10, 2012 at 8:21 AM
    Pugga
    Massachusetts
    Jeez man, that's just rubbing salt in the wound! :laugh:
  12. Feb 10, 2012 at 8:22 AM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    Hole in the side wall=done tire. A patch will last less than a month. You should go to where you bought them for a warranty. Last set of tires I had a life time warranty. They replaced a side wall puncture no charge.
    Some places will not even change a tire that have sealant in them.
  13. Feb 10, 2012 at 8:27 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Here's a picture of the affected area. It's very very close to the tread. It's actually within the armored triangle deal. The white stuff is where I had him chalk the spot so I wouldn't lose it.
  14. Feb 10, 2012 at 8:37 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Move your finger, I can't see, dangit.
  15. Feb 10, 2012 at 8:40 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
  16. Feb 10, 2012 at 8:45 AM
    Pugga
    Massachusetts
    First off, I'd move it to the rear of the truck. Regardless of what you decide, I wouldn't put that tire back on the front. Safest bet would be to replace the tire. Sealants and/or plugs could work and you may never have an issue with the tire for as long as you own it. The problem is, with sidewall punctures, you never know.
    Maybe plug it and make it a full size spare?
  17. Feb 10, 2012 at 8:51 AM
    92LandCruiser
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    if the hole is a pin prick throw a patch on the inside. You'll have to find a shop that will do it but some still will. They just won't warranty it for on road use. or do it yourself
    then stick a bead of rtv on the outside or if it's big enough plug then patch and then rtv over the outside
  18. Feb 10, 2012 at 8:56 AM
    ItalynStylion
    Steven
    DFW, Tx.
    It's a pin prick for sure. Takes something like a week and a half for my TPS to come on because of it. Like I said, there doesn't appear to be any scuffing in the area and it doesn't look damaged at all.
  19. Feb 10, 2012 at 8:59 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Personally if it were my tire I'd find someone who would patch it. I'd just keep an eye on it afterwords.
  20. Feb 10, 2012 at 9:00 AM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    Put a plug from the outside and forget about it, I've done it for years countless times and no problems so far.
    I carry a plug kit and compressor on my truck and saves a ton of time when I get a flat, my spare only comes out when the failure is catastrofic and will not hold air with the plugs.
