Sleeping platform
Old 02-16-2012, 11:45 AM   #1
Khaos [OP] Khaos is offline
Khaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shed
Khaos's Avatar
Khaos's Tacoma Gallery
Sleeping platform
Has anyone used the notches in the side of the bed to build a sleeping platform?
It seems that using some wood and the wheel wells it would be quite easy to build a platform that could be used to support a mattress while providing storage underneath the bed. Anyone given it a try?
Old 02-16-2012, 12:14 PM   #3
Banned
4x4jeep is one of the sharper tools in the shed4x4jeep is one of the sharper tools in the shed4x4jeep is one of the sharper tools in the shed4x4jeep is one of the sharper tools in the shed4x4jeep is one of the sharper tools in the shed4x4jeep is one of the sharper tools in the shed4x4jeep is one of the sharper tools in the shed4x4jeep is one of the sharper tools in the shed4x4jeep is one of the sharper tools in the shed4x4jeep is one of the sharper tools in the shed4x4jeep is one of the sharper tools in the shed
4x4jeep's Avatar
4x4jeep's Tacoma Gallery
Old 02-16-2012, 12:14 PM   #4
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
You don't need a center support. I used 2-2x6's layed in the notches and 3/4" plywood on top of them to make a flat area. I use mine for cargo separation but the concept is the same. It's very sturdy. I made sure to have a couple panels in the front that lift out separately in case things slide to the front of the bed underneath the platform.
Here's one like mine that's carpeted and finished off:
http://www.tacomaworld.com/forum/2nd...rks-great.html
Old 02-16-2012, 12:15 PM   #5
All of those moments....will be lost.....in time
OZ-T's Avatar
OZ-T's Tacoma Gallery
Those notches are meant to accept 2x8 cross boards
Use 3/4" plywood for your platform , you should be golden
Old 02-16-2012, 12:16 PM   #6
Never Forget! 343
Bengland25 has much to be proud ofBengland25 has much to be proud ofBengland25 has much to be proud ofBengland25 has much to be proud ofBengland25 has much to be proud ofBengland25 has much to be proud ofBengland25 has much to be proud ofBengland25 has much to be proud of
Bengland25's Avatar
Firefighter:
Bengland25's Tacoma Gallery
Looks good! i guess if you run the 2x6's you wouldnt need supports! didnt even think of that one!
Old 02-16-2012, 12:17 PM   #7
Tacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shedTacoma831 is one of the sharper tools in the shed
Tacoma831's Avatar
Tacoma831's Tacoma Gallery
I built one and carpeted it and it works great, same idea as Pugga. I'll look for some pics..
Old 02-16-2012, 12:17 PM   #8
She's got the jimmy legs
Toyotacrawler is one of the sharper tools in the shedToyotacrawler is one of the sharper tools in the shedToyotacrawler is one of the sharper tools in the shedToyotacrawler is one of the sharper tools in the shedToyotacrawler is one of the sharper tools in the shedToyotacrawler is one of the sharper tools in the shedToyotacrawler is one of the sharper tools in the shedToyotacrawler is one of the sharper tools in the shedToyotacrawler is one of the sharper tools in the shedToyotacrawler is one of the sharper tools in the shedToyotacrawler is one of the sharper tools in the shed
Toyotacrawler's Avatar
Toyotacrawler's Tacoma Gallery
This guy did that
Old 02-16-2012, 12:17 PM   #9
Pugga's Avatar
3/4" plywood doesn't hurt either. It's definitely overbuilt if you just want to sleep on it, but I use it for cargo. I've had over 1,000 lbs sitting on that platform a couple weeks ago an no failures.
Old 02-16-2012, 12:28 PM   #10
Never Forget! 343
Bengland25's Avatar
Firefighter:
wow thats crazy you have that much on there! good deal! might be going to pick up some lumber this weekend and some marine grade carpet so it will be nice and clean for camping trips
Old 02-16-2012, 12:40 PM   #11
Khaos's Avatar
No such thing as overbuilding for me, 6"3 and 260lbs. I also wouldn't be sleeping back there alone. lol.
The area beneath the platform will be perfect for storing my gear/guns that I want to keep locked up while camping.
Keep the pics coming!
Old 02-16-2012, 12:43 PM   #12
Namyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shed
Namyo's Avatar
Namyo's Tacoma Gallery
I was kicking around the idea of half-a-platform Like a single bed with toats n coolers on the other half....
Old 02-16-2012, 12:44 PM   #14
Pugga's Avatar
Build it like mine and you can have a fat chick orgy back there and not break it.
Old 02-16-2012, 12:55 PM   #15
Namyo's Avatar
Old 02-16-2012, 01:01 PM   #16
Namyo's Avatar
maybe like this..
Old 02-16-2012, 01:40 PM   #17
deeznutz will become famous soon enough
deeznutz's Tacoma Gallery
Here are pics of mine:
Room underneath for storage bins
Small holes in the platform to be able to lift up the panel to get to storage bins underneath.
And the finished sleeping platform
Old 02-16-2012, 01:47 PM   #18
2007 tacoma is one of the sharper tools in the shed2007 tacoma is one of the sharper tools in the shed2007 tacoma is one of the sharper tools in the shed2007 tacoma is one of the sharper tools in the shed2007 tacoma is one of the sharper tools in the shed2007 tacoma is one of the sharper tools in the shed2007 tacoma is one of the sharper tools in the shed2007 tacoma is one of the sharper tools in the shed2007 tacoma is one of the sharper tools in the shed2007 tacoma is one of the sharper tools in the shed2007 tacoma is one of the sharper tools in the shed
2007 tacoma's Avatar
2007 tacoma's Tacoma Gallery
Since you put it that way now I have to have one!
Seriously though. I haven't considered this yet, but think I should. I'm going to get a truck cap (haven't decided between ARE or LEER yet) and this would be a good addition.
Old 02-16-2012, 01:54 PM   #19
surfrat is one of the sharper tools in the shedsurfrat is one of the sharper tools in the shedsurfrat is one of the sharper tools in the shedsurfrat is one of the sharper tools in the shedsurfrat is one of the sharper tools in the shedsurfrat is one of the sharper tools in the shedsurfrat is one of the sharper tools in the shedsurfrat is one of the sharper tools in the shedsurfrat is one of the sharper tools in the shedsurfrat is one of the sharper tools in the shedsurfrat is one of the sharper tools in the shed
surfrat's Tacoma Gallery
Heres one i made a while back. didn't want to kill all the space in the bed. I have a self inflatable ground pad that fits perfectly on it. I blocked the windows with felt and i sleep like a champ in the back of it. The drawer goes back to the wheel well, and i made a hatch to access behind that for more storage. I recently ditched the drawer slides because they didn't go back far enough. i put some Teflon sliders on the bottom of the drawer to let me pull it out all the way. drawer sliders for 4ft are big bucks!
Old 02-16-2012, 04:21 PM   #20
Namyo's Avatar
I'm liking that.
Built my Sleeping Platform. Hoyal Off-Topic Discussion 13 06-07-2014 09:57 PM
Rab89's Tacoma sleeping platform rab89 Other Builds 2 04-08-2014 01:22 PM
Sleeping platform built!!! deeznutz 2nd Gen. Tacomas 10 04-08-2014 01:19 PM
Sleeping platform designs rdwarrior 2nd Gen. Tacomas 31 04-08-2014 01:19 PM
Sleeping Platform Build. Thoughts? ChrisOC1 1st Gen. Tacomas 34 04-08-2014 01:17 PM
