Where to mount a fire extinguisher?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by squirrelNUts, Apr 4, 2012.
  1. Apr 4, 2012 at 5:16 PM
    squirrelNUts
    squirrelNUts [OP] Active Member
    Ted
    Massachusetts
    I'm looking for suggestions on where to mount a fire extinguisher. 2010 4x4 access cab. Usually just me in the truck, sometimes the wife, very rarely do I have passengers in the back, but I'm getting a dog over the summer! I just picked up a 1A-10-BC 3lb unit. It's about a foot tall; it's kind of big, but if I ever need it, I'm sure i'll want it! It came with a super-cheesy plastic wall mount, but I had the same model in an old apartment kitchen and it stayed stuck to the wall with just two screws.
    Thanks!
  2. Apr 4, 2012 at 5:24 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    Doesn't matter so much *where* you mount it - just use a real mount and attach it solidly. You don't want that thing to become a missile in a car crash.
  3. Apr 4, 2012 at 5:25 PM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    BTW, look down at the bottom of this thread to "similar thread" for other mounting location ideas...
  4. Apr 4, 2012 at 5:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  5. Apr 4, 2012 at 5:44 PM
    squirrelNUts
    Ted
    Massachusetts
    I'm going to make a mount so I can clamp it into the bedrails...i'll take pics when I do. That way it will stay in one place and won't get buried in crap if I fill up the bed (mostly camping stuff)
    BTW...I searched for "fire extinguisher" and got tons of crap...not the useful stuff I found in the "similar thread" thing. Any links to good ways to use the search function?
    Thanks,
    Ted
  6. Apr 4, 2012 at 5:50 PM
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    Careful leaving it mounted outside the cab. Somebody told me that their bed-mounted extinguisher got yanked and emptied all around (or over?) the truck once. I think it may have been Mohawk Mike.
    IF you don't mind spending a little extra time, you might think about something like this:
  7. Apr 4, 2012 at 5:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The problem with mounting it inside, is, if/when the vehicle catches fire, your first instinct is to GET OUT. Most people dont have the frame of mind to try to get something out of a burning vehicle. Out of the last 15 years of having a fire extinguisher mounted in the bed, only 1 was discharged by somebody fucking around. Another one was used by someone else to put a fire out, when I wasnt near my vehicle....an added benafit of it being in the bed, is that if its needed, someone else can get quick access to it. To add, Most fires happen at the front of the vehicle. Driver side mount in the bed, allows you to get out of the vehicle, get to the back, assess the situation, and react with the extinguisher if needed. Also, this particular mounting location I have choosen, is right next to the spot I stand when filling up with fuel. If somthing goes up, I have the extinguisher right there.
  8. Apr 4, 2012 at 5:59 PM
    2010TxTaco
    2010TxTaco Well-Known Member
    justin
    Victoria, TX/Gulf Coast
    Black/SR5/4x4/long bed/double cab
    When I bought it, Leer camper shell, N-Fab nerf bars, Westin bull bar. So far I've put K&N air filter and Jet Performance throttle body spacer, lights behind grill, snorkel, custom grill, and weather tech floor mats. Axe and shovel w/bed mounts, high lift jack w/bed mount, and Brute force fab rear bumper.
    I have mine mounted in the bed to the bed rails, I used the quickfist mounts.
  9. Apr 4, 2012 at 6:31 PM
    SoJersey
    SoJersey South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
    feel like making another one???? :eek:
  10. Apr 4, 2012 at 6:36 PM
    Bobber Bill
    Los Angeles, CA
    Probably not, I just don't have the time right now. I'll let you know if that changes though
    Defined has some mounts that can adapted to work there pretty easily. You might look into those:
    http://www.definedengineering.com/products.html
  11. Apr 4, 2012 at 7:49 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    I put one in the little cubby in the bed of the truck. That way it is easy to get to but not visible to jack asses.
  12. Jul 26, 2014 at 10:15 AM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Looking into mounting one in my bed, What grade (ABCE?)is best for vehicle fires?
  13. Jul 26, 2014 at 12:04 PM
    jonnie666
    jonnie666 Active Member
    Hamburg/Germany
    SR5 V6 TRD
  14. Jul 26, 2014 at 12:06 PM
    Large
    Large Red
    Stealing your idea ^^^^^
    :spy:
  15. Jul 26, 2014 at 4:21 PM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    Just make sure it is a good solid mount.
    I had a friend that let his roll around in the back of his SUV, the thing discharged on him.
    cryptolime likes this.
  16. Jul 26, 2014 at 4:33 PM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
  17. Jul 26, 2014 at 4:38 PM
    AR15xAR10
  18. Jul 26, 2014 at 4:44 PM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
  19. Jul 26, 2014 at 4:49 PM
    AR15xAR10
  20. Jul 26, 2014 at 6:22 PM
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
