2010-2012 4runner heated seat switch work on 2012 Taco empty slots?
Old 04-10-2012, 08:00 PM   #1
drsus [OP] drsus is offline
drsus is on a distinguished road
drsus's Avatar
drsus's Tacoma Gallery
This is kind of a shot in the dark.
has anyone tried to fit the 4runner 2010-2012 heated seat switch on the 2012 Taco empty slots next to the A-trac switch? they're both square and look about the same size. I went down to a dealer to try and figure it out but they didn't have any friggin 4runners!
the 2012 taco has two very conveniently placed empty slots next to A-trac switch...one on the left and one on the right of the A-trac switch, couldnt be a better place for the heat switches. Im sure i can take aftermarket heat pads and wire them to the OEM 4runner switches, just wondering if anyone knows of they're the same size? from pictures they sure look like a dead ringer.
the Taco picture only shows the USB slot...the off-road tacos also have the A-trac switch next to the USB slot..leaving two empty slots, one on each side.
2010-2012 4runner heated seat switch work on 2012 Taco empty slots?-liveto3ibm.jpg
Old 04-11-2012, 12:01 PM   #2
griffin407c is one of the sharper tools in the shedgriffin407c is one of the sharper tools in the shedgriffin407c is one of the sharper tools in the shedgriffin407c is one of the sharper tools in the shedgriffin407c is one of the sharper tools in the shedgriffin407c is one of the sharper tools in the shedgriffin407c is one of the sharper tools in the shedgriffin407c is one of the sharper tools in the shedgriffin407c is one of the sharper tools in the shedgriffin407c is one of the sharper tools in the shedgriffin407c is one of the sharper tools in the shed
Air Force: POL/Fuels
griffin407c's Tacoma Gallery
yes they fit.... but will they work?... ehh, maybe. i've been following a thread on an fj forum and it's a mind f*ck to get them to work. the switch has resistors, then you need to purchase the oem controllers, then make a custom wiring harness because the total resistance doesn't match the aftermarket heating elements. a lot of trial and error that has been going on for years. if i remember correctly, only one guy has made it work. there's an aftermarket ebay kit. includes elements and oem style switches that will fit those blanks.
found here > http://www.tacomaworld.com/forum/2nd...ches-pads.html
Old 04-11-2012, 06:21 PM   #3
drsus's Avatar
AH!
that was exactly my sticking point (besides them actually fitting in the same slots), making the OEM switches (resistor type) work with a two position aftermarket element wiring. Im not that good with electricity but i know that this would be a serious challenge.
Awesome Ebay find btw
thank you much
Old 04-12-2012, 01:40 PM   #4
i haven't tried the kit on ebay personally, but they've gotten a ton of positive feedback and seem to have a good warranty. the company has a website as well.
Old 04-12-2012, 03:25 PM   #5
drsus's Avatar
Cool, they look legit and close 100% rating for 400 kits, that pretty damn good.
Seems like a much easier option that going through the oem trouble, would've been trick though.
I just have to PM them see if I can order the kit with just white labels instead of the party mode green and orange labels...Good lawrd
Thanks againn for the tip.
Old 05-27-2012, 04:14 PM   #6
drsus's Avatar
ok, got them and installed them, worked like a charm
$90 shipped from somewhere deep in China, took forever to get them, but they're well made and work great. THeyre back lit when you turn your headlights on, and theres a on/off light that goes on when operated. It has a 5 position click wheel
Im out of blank switch spots on my truck ...i hate blanks, means I'm not getting something others have on their trucks
2010-2012 4runner heated seat switch work on 2012 Taco empty slots?-img_1033.jpg
Old 07-08-2012, 10:37 AM   #7
Pokes Fan
polarisman151 is on a distinguished road
polarisman151's Tacoma Gallery
The switches look great, not crazy about the lights but beats autozone toggle switches. Anyone know where I can get just switches? I have the heaters.
Old 07-08-2012, 12:35 PM   #8
drsus's Avatar
i know trying to wire toyota OEM ones, which you can buy at any dealer with the part number, is a gigantic pain in the ass not worth the effort.
the ones i got im sure you could contact the sellers on Ebay and get them to sell you just the switches
Old 07-09-2012, 08:59 AM   #9
Pokes Fan
Ok thanks I'll give that a try
Old 07-09-2012, 06:27 PM   #10
MBTacoma12 is on a distinguished road
MBTacoma12's Tacoma Gallery
Were there wiring and connectors in the back or did you have to make one.
Old 09-20-2012, 11:17 PM   #11
drsus's Avatar
the heaters had al the wiring and connectors i needed, so i just tapped into the fuse panel for power and into the light wire from one of the adjacent switches for the back lighting when headlights are on...took me maybe 1hr to wire the whole thing.
Old 09-21-2012, 09:36 AM   #12
Throbbing Member
B737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shed
B737's Avatar
B737's Tacoma Gallery
if you use a step drill you can install a switch right into the blank plug... this is what i did with my katzkin heater switch.
Will a 2012 4runner Entune Nav System work in my 2005 Tacoma? BAP_29 Audio & Video 13 02-12-2013 05:30 AM
2012 taco or 2012 tundra? Opinions wanted Metalhead77 2nd Gen. Tacomas 23 12-24-2011 05:14 PM
Heated Seat Switch? Slimwood Shady 2nd Gen. Tacomas 4 10-23-2010 05:48 PM
heated seat switch locations teamfast 2nd Gen. Tacomas 10 07-23-2010 05:04 PM
What are these empty console slots for? proshoppb 2nd Gen. Tacomas 13 12-15-2008 04:04 PM
