Can TPMS be bypassed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spruce Juice, May 26, 2012.
  1. Jun 6, 2012 at 11:14 AM
    #61
    Hot2na
    Hot2na Well-Known Member
    how does it work ? any pics? sorry for sounding stupid,but if I can save myself some bucks -I wanna reuse them...
  2. Jun 6, 2012 at 11:16 AM
    #62
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You have the tire shop turn the sensors 180 degrees when they reinstall them in the new allow wheels. That turns the sensor toward the inside of the tire so you can properly mount the tire without hitting the sensor.
  3. Jun 6, 2012 at 12:46 PM
    #63
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" TuRD PRO replica wheels
    it's cool sweetpea, take your time.
  4. Jun 6, 2012 at 12:48 PM
    #64
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Put a piece of tape over the light, or unplug the tpms ecu. Behind and to the right of the radio I believe. I taped mine before I found the ecu, havnt messed with it
  5. Jun 6, 2012 at 12:59 PM
    #65
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Its not that hard to pull the guages out and either remove or burn out that little LED. Probably easier than doing the PVC method.
  6. Jun 6, 2012 at 7:05 PM
    #66
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Air it down to 25psi, use the reset button, then crank it up to 40psi and forget it for a couple of years at least.
  7. Jun 22, 2012 at 2:30 AM
    #67
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
  8. Jun 22, 2012 at 2:46 AM
    #68
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    VERY interested in the ABS kill. I wont take one for free, but a reduced price would be good.....:rolleyes:
    But seriously, Bump cause I want one. :drool:
  9. Jun 22, 2012 at 2:47 AM
    #69
    Hot2na
    Any more pipe bomb pics ?? I dont see what so difficult about this method...just put'em in a pipe,reinflate & you're good to go....am I missing anything ??
  10. Jun 22, 2012 at 6:35 AM
    #70
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Nope
  11. Jun 22, 2012 at 7:37 AM
    #71
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Update??
  12. Jun 26, 2012 at 7:47 AM
    #72
    Enders Taco
    Enders Taco Well-Known Member
    Ben
    Hampton Roads VA
    DCSB 4x4 6SP
    All Pro APEX Front Bumper, All Pro Sliders, Icon Coilovers with rear shocks and add a leaf pack, URD short shifter, Pioneer X930BT Nav with Polk speakers
    Ditto. If this product comes to market in the next week or so, I'll buy one. I think if I do the electrical tape mod, I wouldnt worry about it afterwards.
  13. Jun 26, 2012 at 8:49 AM
    #73
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Product?? Just tape it or unplug the tpms ecu
  14. Jun 26, 2012 at 11:40 AM
    #74
    Tripps2012
    Tripps2012 2014 TRD OR
    NC
    2014 TRD OR
    You guys are over thinking this. The product is already out there you have 2 options to keep your TPMS and have any wheels you would like.
    Cheapest is a relocation stem your factory sensor fits into the loop on the stem then the stem is bolted into the valve stem hole easy peazy...:D
    Or a universal band and cradle like the Ford setup. You install the band and cradle then your factory sensor mounts into the tab on the cradle. These are expensive but work 95% of the time.
  15. Jun 26, 2012 at 11:49 AM
    #75
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I want a VSC / ABS bypass
  16. Dec 26, 2012 at 10:02 AM
    #76
    Sgtfluffy16
    Sgtfluffy16 Well-Known Member
    Corey
    PA
    07 Tacoma Double Cab TRD Sport
    20% tint, HID headlights/ yellow fog light bulbs and LED lights interior/exterior lights. 4.5 Inch RCD lift, 1 Piece custom driveshaft, AEM intake, Dynomax Exhaust, Amp research Moto-bed extender, Extang Express tonno.
    Dont laugh.. this is what I do. I took all my sensors out and are in a pressured capsule in the back of my truck. None are in my wheels anymore
  17. Dec 26, 2012 at 10:25 AM
    #77
    OZ-T
    Peter North
    British Columbia
    Easiest way
  18. Dec 26, 2012 at 10:37 AM
    #78
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I suggest you guys not use ABS plastic as a pressure vessel. The jarring and thermal cycle inside your truck will cause the material to fail. I use galvanized pipe. I rigged mine up with a switch that lets me know if there's moisture on the inside of the pipe to prevent the tpms from rusting.
  19. Dec 26, 2012 at 10:40 AM
    #79
    dirtymike
    dirtymike Well-Known Member
    mike
    orlando fl
    2nd gen
    Fiberglass,spindles, coils, 4"leafs, gears&locker, no skids :-/
    That looks like a pipe bomb
  20. Dec 26, 2012 at 10:48 AM
    #80
    98tacoma27
    Ben
    Not Beech Creek
    :laughing: x2
    Not a good thing to have if you got puilled over.
