Lift Installed!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bunsojr, Jun 9, 2012.
  1. Jun 9, 2012 at 9:12 PM
    bunsojr
    bunsojr [OP] Well-Known Member
    Northern California
    2005 Silver DCLB
    Bilstein 5100s with OME 885 Medium Duty Dakar Leaf Springs SPC Upper Control Arms Pro Comp 7032 wheels BFG AT K02 in 275/70/17
    Just finished installing my lift! Bilsteins all around. Front set at 1.75'' and 2'' Wheelers AAL. Started at 10am. Took about 1.5 hrs to finish installing the first AAL. Messed up the threads on and bent the first centering pin. So had to cut it off and try again with the 2nd one. When I finished that up, decided it was time for a lunch break and also went to about 4 auto parts stores before I found a new centering pin that would work.
    After about a 2 hr lunch break and journey to find a centering pin, I finished up installing the 2nd AAL in about another hour and decided to call it quits. Overall, I felt installing the AALs was harder than installing the shocks front or rear. My biggest difficulties were removing the shocks (couldnt find a good place to hold down on to prevent the shock from spinning once the nut was at the very tip) and getting the centering pin head to line up with the hole on the rear end (needed a lot of persuasion).
    I liked how the lift looked so much on the rear, I decided to tackle the front after about another hr break. I contemplated renting a spring compressor for this, but after looking at the available ones at the auto parts stores (they only had the Mcpherson strut compressor ones), I decided that the floor jack method was the better option, and after finishing up, I'm convinced that it's just as safe and just as easy if not easier than removing the entire assembly and using a spring compressor. I made sure to mark the bolts on the LCA as well, which seemed to be one of the best little tricks because I took a quick test drive around the block and it seemed to drive perfectly. I'm still gonna take it in for an alignment on Monday, but it seems to be pretty good right now!
    I wanted to take pics, but got to be too dark! Will take some in the morning! I also forgot to do an identical stance before pic as well as measure the heights before the install...I wish I had done both! Oh well...
    Last thing to say...I think of myself as a person with a lot of common sense and a reasonable amount of patience, but I admit that I don't have the best wrenching skills by any means, nor do I have a huge amount of tools. And before this, the extent of my experience tooling around with cars is changing oil, a flat tire, wiper blades, and washing it. That being said, I installed everything myself with nothing more than hand tools (no air tools) and I felt that this was a perfectly reasonable install for a person like me. I feel so accomplished now! Hahaa...but exhausted.
  2. Jun 10, 2012 at 3:49 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    good job, no go 4 wheel it!
  3. Jun 10, 2012 at 7:31 AM
    Large
    Large Red
    Where's the pics?
  4. Jun 10, 2012 at 7:41 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    ^This
  5. Jun 10, 2012 at 8:02 AM
    IndianTaco
    IndianTaco Well-Known Member
  6. Jun 10, 2012 at 10:01 AM
    bunsojr
    Northern California
    2005 Silver DCLB
  7. Jun 10, 2012 at 10:06 AM
    xgalvanxgx
    xgalvanxgx seymour butts
    Gerardo
    OC (Lake Forest) California
    TRD Off-Road BlackSandPearl 07 PreRunner
    DTF Race Kit with 2.5 x 10 Kings, DMZ SUA rear with 16" triple bypass Kings, King bumpstops front and rear, 17" KMC RG1 powdered in Matte Bronze with black ring with 37" BFG KO2s, front and rear DTF bumpers, front Fiberwerx glass and Mcneil trophy bedsides, K&N 77 Series Intake, Magnaflow, Pioneer touchscreen, Rockford Fosgate 10" sub with box and amp. Dyanamat walls, Andres' devil horn emblem, 50" D4 curved LED bar, rear chase light rack (brake, ambers, white lights) Engine brace, deleted inner wheel wells for max up travel. Cab roll rage built into bedcage.
    you need bigger tires ;)
  8. Jun 10, 2012 at 10:08 AM
    bunsojr
    Northern California
    2005 Silver DCLB
    Yah...need to save up. I'll just have to wait til I wear these out. Unless someone wants to buy them :) They're Cooper discoverer ATR
  9. Jun 10, 2012 at 11:52 AM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    :thumbsup:Good effort man! She looks great....and you definitely have room for bigger tires
  10. Jun 10, 2012 at 12:00 PM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    x2. But it looks good!
  11. Jun 10, 2012 at 3:05 PM
    bunsojr
    Northern California
    2005 Silver DCLB
    Definitely want some new tires, but can't quite justify new ones since my current tires only have around 5k miles on them. Maybe a set of used ones?
  12. Jun 10, 2012 at 3:10 PM
    CayucosTacoma
    2004 Double Cab 4x4
    maybe look for a trade + cash. or look for someone selling their taco and going back to stock
  13. Jun 10, 2012 at 4:11 PM
    bunsojr
    Northern California
    2005 Silver DCLB
    i forgot to measure before i installed them to get a comparison...but it looks significantly higher..haha
  14. Jun 10, 2012 at 4:18 PM
    BeeRadd
    BeeRadd Bought not built.
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    To me the back looks a little too high but I know it's supposed to be a little high so when you haul stuff it doesn't sag. Can the billy's go any higher in the front? Either way nice job, this is my next project for the truck.
  15. Jun 10, 2012 at 4:47 PM
    bunsojr
    Northern California
    2005 Silver DCLB
    the front is set to 1.75. It can go up to 2.5, but I didn't wanna go that high. Plus, I think I'm one of the few that likes the forward rake of the Tacomas. Personally, I think level or front end higher looks weird on the Tacomas.
