How to Replace 2nd Gen Exterior Rear Door Handles on Double Cabs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HonoluluTaco, Jun 22, 2012.
  1. Jun 22, 2012 at 1:44 AM
    HonoluluTaco
    HonoluluTaco [OP] Well-Known Member
    Koi
    Reston Virginia
    10 TRD 4x4 OffRoad DC/SB
    2010 TRD OffRoad DC/SB, 285/70/17 KM2's, Mickey Thompson Classic Locks, Total Chaos UCA's King 2.5 RR Coilover 3" AllPro Leaf Pack, 2.0 Fox RR, Ubolt flip kit, MBRP dual cat back, URD TCAI and MAF Calibrator, TRD Sport Hood w/ scoop, E&G Classics Custom Stainless Grill, Color matched grill and door handles WeatherTech floor mats, FormulaOne Pinacle 15%+Air blue windshield Tint, RedLine hood struts, TRD 3rd Brake light Decal, Relentless Fab Hybrid 2 piece Sliders with Kick out Relentless Fab Aluminum Front bumper, Relentless steel rear bumper, Relentless Steel IFS B.A.M.F LCA Skids, w/ Rear Diff Skid ordered In my Spare room waiting to be installed sits, Wet Okoles, Illuminated 4x4 switch mod, SockMonkey Hawaii TRD OffRoad Decal, Big box of Rammat, Speakers and Custom Sub from Mr.Marv,
    Aloha All...
    Couldn't find a sticky on here on how to replace the rear exterior door handles for the double cabs, so I gave it a shot and wrote it up.
    I want to thank 57HotRodVW on Toyota Nation for his great write up on the rear which saved me a lot of heart ache, only after wasting an hour trying to do it myself and re re researching and finding his write up.
    For the front see Tacoma World's Ron (Edrin55) and his write up, Remove/Replace door handles on Reg. & Access cabs, it's great and will get you thru the front doors which will help with the rear.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/41723-remove-replace-door-handles-reg-access-cabs.html
    2nd Generation Double Cab Tacoma (2005 - 2010)
    Tools needed:
    1 #30 Torx bit
    1 Ratchet with extension
    1 small Flathead screw driver (for prying)
    1 reg Phillips head screw driver
    Parts needed:
    2 door handles (part# 69211-AE020-xx) The last two digits is your vehicle color code.
    2 lock covers (part# 69217-AE020-xx)
    69211- BARCELONA RED 3R3
    69211- BLACK SAND 209
    69211- MAGNETIC GRAY 1G3
    69211- PYRITE MICA 4T3
    69211- SILVER STREAK 1E7
    69211- SPEEDWAY BLUE 8P1
    69211- SUPER WHITE 040
    69211- TIMBERLAND 6T8
    Start by using a phillips and unscrewing this screw
    Using a phillips unscrew this screw
    Then remove this plastic holder by pressing in the middle indent with the phillips then use finger nails to pry out
    Pry this panel off from the edge of the door pulling straight out away from the door (Important take the 3 white clips that remain in the door and put them back on the plastic trim for when you reinstall, if not they will be pushed in the door and you will have to fish them out of the bottom of the door panel)
    Now starting at the bottom sides of the doors where you feel you can get your fingers in the crease between the door panel and the frame pull straight out, you will hear a pop.
    Work your way around the door bottom up the sides(There are none on the top edge where the window is) now lift the panel straight up toward the window, be careful it will still be attached by some wires to the power window button, you can either unplug the wire like i did and remove the whole panel or let it hang gently.
    as long as you have access to this space
    Now take the torx and remove these bolt completely
    Then reach inside here
    and move the latching mechanism down like this
    Now you can see the torx you need to loosen
    Now put your torx bit in the extender and loosen, it wont fall out as it has a retainer clip.
    Now Remove the little lock cover piece by slightly prying then getting your nails under it and wiggling straight out, just like the front doors. Then remove the handle by pulling back and opening.
    Replace the color matched handle by putting the front end in first then the rear. Then put the lock cover on and secure it with the Torx and the extender, then put the latching mechanism back and secure it. Follow all the steps in reverse to reinstall the door panel.
    Done, one step closer to a Color Coded, Scooped TRD OffRoad!!!
    Good luck:cheers:
  2. Jun 22, 2012 at 3:02 AM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Thanks! I actually needed to see this! Couldnt figure out how to get the door panel off. Now I can finally finish the arm rests. Great write up!
  3. Jun 22, 2012 at 4:30 AM
    tango down
    tango down Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
    nice work brah
  4. Oct 20, 2013 at 11:29 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I don't use my remote to get into my locked truck. In fact, I don't know where it is at. I hate the fact that the passenger side of the truck does not have a key hole like the older cars did.
    Is there any way I could use a driver's side handle with key hole and replace the passenger one with it?
    Yes, that will involve getting the tumbler to work with your key.
  5. Jan 12, 2014 at 1:30 PM
    jetta.the.hut
    jetta.the.hut B4nn3d
    Aren
    Aberdeen,NC
    2013 Access Cab Long Bed 4x4
  6. Mar 2, 2014 at 3:32 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Very helpful thanks braddah! :)
  7. Mar 2, 2014 at 4:52 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    Thanks for the time and effort you put into this and the photo's!! Much appreciated as me and fellow TW Brother (Bullaculla) knocked this out in no time:) Yeah...the truck is filthy from rain and road spray..:)
  8. Mar 2, 2015 at 6:04 PM
    10PreRunner
    10PreRunner Well-Known Member
    Kevin
    Knoxville, Tennessee
    2013 SR5 4x4 Double Cab
    Are there two different covers for the front doors? One must have a hole in it for the key hole right?
  9. Mar 2, 2015 at 10:56 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Just the Drivers side has a key hole...
  10. Mar 3, 2015 at 6:26 PM
    10PreRunner
    Kevin
    Yes I know this, but the parts diagram doesn't say anything about passenger or drivers side.
  11. Mar 3, 2015 at 6:29 PM
    Swank
    Swank Certified Mall Crawling Instructor
    Steven
    Greenville NC
    SOLD/TOTALED
    How much did all the parts cost you? Been looking to do this myself.
    edit* just realized this is an old thread :facepalm:
  12. Mar 3, 2015 at 10:39 PM
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
  13. Mar 4, 2015 at 2:15 AM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    Thanks, nice write up.
  14. Mar 4, 2015 at 3:49 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    My next thing to do…..
  15. Mar 4, 2015 at 4:02 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  16. Mar 4, 2015 at 5:42 PM
    10PreRunner
    Kevin
    Thanks squint, I'll check their eBay store and see if they have any in red.
  17. Mar 4, 2015 at 6:21 PM
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    Definately on my list to get ride of the Limiteds ugly chrome door handles.
  18. Mar 4, 2015 at 6:58 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    What color is your truck it i hard to tell in the picture?
  19. Mar 20, 2015 at 11:28 PM
    WorldWar546
    WorldWar546 Baja Member
    Anthon
    Utah
    TRD Charged '14 Black TX Baja
    TRD Supercharger And a lot of rice n chrome
    Thanks HonoluluTaco this really helped!!
    TacomaJustice likes this.
  20. Jun 9, 2015 at 9:19 AM
    projectstealth
    projectstealth Member
    Cory
    las vegas
    stealth blacked out
    Xd addicts falken rockey mountains bush Wackers pioneer 7 inch dynomax exhaust k&n intake 3 inch lift aal hid headlights and fog lights led interior lights
    Did anyone else have trouble with the rear door handles. When u put them back on they don't spring back out. Please help me
