Fiberglass bedsides and gas filler neck (glassworks)
Old 06-29-2012, 06:06 PM   #1
TX RPO [OP] TX RPO is offline
Desert Warrior
TX RPO is a splendid one to beholdTX RPO is a splendid one to beholdTX RPO is a splendid one to beholdTX RPO is a splendid one to beholdTX RPO is a splendid one to beholdTX RPO is a splendid one to beholdTX RPO is a splendid one to beholdTX RPO is a splendid one to behold
TX RPO's Avatar
Air Force:
TX RPO's Tacoma Gallery
Quick question for those who have fiberglass bedsides. They are obviously wider so what did you guys do for the gas filler neck? Since it now sits in compared to the bedside? Pics would be helpful as well! Thanks!
Shane
Old 06-30-2012, 12:08 PM   #2
Desert Warrior
TX RPO's Avatar
Air Force:
bump
Old 06-30-2012, 12:15 PM   #3
anthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shed
anthony250f's Avatar
anthony250f's Tacoma Gallery
I wanna know this answer
Old 06-30-2012, 12:20 PM   #4
rcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shed
rcfreak201's Avatar
rcfreak201's Tacoma Gallery
I know this came up in the past but i believe you use the piece from the 4-Runners, ask in the LT BS Thread!
Old 06-30-2012, 02:46 PM   #6
Desert Warrior
TX RPO's Avatar
Air Force:
Really?? I'll check in with the LT BS thread though
Old 08-06-2012, 05:04 PM   #7
Milowilli
Milowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shed
Milowilli's Tacoma Gallery
Covered up with ABS plastic liners.
Old 02-19-2013, 05:19 PM   #8
sully1981 is one of the sharper tools in the shedsully1981 is one of the sharper tools in the shedsully1981 is one of the sharper tools in the shedsully1981 is one of the sharper tools in the shedsully1981 is one of the sharper tools in the shedsully1981 is one of the sharper tools in the shedsully1981 is one of the sharper tools in the shedsully1981 is one of the sharper tools in the shedsully1981 is one of the sharper tools in the shedsully1981 is one of the sharper tools in the shedsully1981 is one of the sharper tools in the shed
sully1981's Avatar
sully1981's Tacoma Gallery
what is that liner
I am in the process of putting on the defined spring under kit with shock hoops and was looking for ideas to cover bed holes from shocks. where did you get the abs liner from. That looks perfect. Also who makes your bedsides i just ordered fiberworks bedsides and they told me my stock hoses should fit for the filler tube since i have a long bed
Old 02-19-2013, 05:35 PM   #9
Those look like glassworks
Old 02-20-2013, 06:42 AM   #10
Milowilli
Those are Glassworks Fenders. You may have to extend hoses for it to fit. Be careful with plastic pipes as they can break up towards the filler cap.
I used black ABS plastic sheets for the liners 3/32 thick and 3/16 thick for bed holes. The sheets can be moulded into shape with a heat gun. For the thicker plastic I moulded and screwed it into the bed. For the liners I used plastic push in clips. Same on front fenders. For the defined kit I had to do a shackle flip as the rear sagged down too much for my application.
http://www.tapplastics.com/product/p...abs_sheets/524
filler neck leaking wheeler3129 1st Gen. Tacomas 2 03-01-2012 09:00 AM
foam in my oil filler neck and cap deftoned_one Technical Chat 14 09-26-2011 10:21 AM
Scrap of foil dropped into fuel filler neck... JKD 2nd Gen. Tacomas 6 01-23-2011 09:51 PM
Fuel filler Neck size? chich2000 2nd Gen. Tacomas 3 11-04-2010 02:59 PM
Mold in my oil filler neck? MaineYota 2nd Gen. Tacomas 5 03-28-2010 07:32 PM
