2011 TRD Won't Move in 4x4 Full Steering Lock?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by K Williams, Jul 8, 2012.
  1. Jul 8, 2012 at 4:17 AM
    K Williams
    K Williams [OP] Well-Known Member
    Long Island, NY
    2011 TRD Off Road V6 MT
    Banks Monster Exhaust URD Stage II Clutch
    Do you all have any trouble with your trucks if you are in 4x4 mode with your steering wheel at full lock to the right? Mine won't move at low speeds unless I give it a lot of gas. Even then, it sounds like the drivetrain is really struggling.
  2. Jul 8, 2012 at 4:42 AM
    boomer6
    boomer6 Well-Known Member
    John
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Sounds like its binding up. My 2011 requires more gas at FULL lock.Figure its normal.
  3. Jul 8, 2012 at 4:55 AM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Id reccomend not doing that..you will break something, either u joints or cv axles if you force it. If you need to make a tight turn, take it out of 4x4
  4. Jul 8, 2012 at 5:17 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I have a 2011 and it's definitely harder to get going when turned. It's just the tires are all trying to go the same speed but have different distances to travel. You probably notice it won't do that in the snow.
    I see your a union brother, right on!
  5. Jul 8, 2012 at 5:18 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Steve
    Buffalo NY
    2010 RC 2.7 4x4
    BUCKLE UP! It makes it harder for Aliens to pull you out of your Truck.
    Don't do that.
  6. Jul 8, 2012 at 5:25 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    I wouldn't recommend doing that.
  7. Jul 8, 2012 at 5:28 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Turning full lock in 4 wheel is not healthy for the truck.
  8. Jul 8, 2012 at 5:36 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    none of these guys have any idea what they are talking about. ive been a toyota master technician for 12 years, when you turn the truck to full lock you have to make sure you are on dry pavement and give it full throttle also. its works alot better when the locker is engaged and youre in 4-lo by the way. just put the pedal to the floor and it will do its thing, this trick unveils a noticable hp gain, and im pretty sure everyone on this site has done it as one of their first and easiest mods. im surprised you've never heard of it. do some searching.
    :anonymous:
  9. Jul 8, 2012 at 6:20 AM
    Large
    Large Red
    Literally laughing out loud at that comment. Lol...
  10. Jul 8, 2012 at 8:44 AM
    scocar
    scocar hypotenoper
    OP, read your users manual.
  11. Jul 8, 2012 at 8:47 AM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    It happens. Binding in the front. Try not to turn so sharp in 4wd.
  12. Jul 8, 2012 at 8:54 AM
    joes06tacoma
    joes06tacoma Well-Known Member
    Joe
    Central Coast, CA
    06 4x4 Off Road Access Cab v6 6spd
    LEER Shell with dome lights operated with 3 way switches, aux backup lights with relay and 3 position switch, modified wiring to compass/temp display and clock to include switch that disables dimming function (poor man's DRL solution), Scan Gauge 2
    X2
    If it's binding up, there is too much traction and you should not need to be in 4WD anyway. This sounds like an excellent way to destroy your transfer case. 4WD is only for use on low traction surfaces, as opposed to AWD in some vehicles that are designed to be in 4WD on dry pavement. There is a differential unit inside an AWD transfer case to allow for dry pavement. Tacomas don't have that.
  13. Mar 27, 2013 at 3:38 AM
    K Williams
    Long Island, NY
    Thanks for the info.
