No-Drill Rock Slider Options
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jckid, Jan 5, 2009.
  1. Jan 5, 2009 at 2:32 PM
    jckid
    jckid [OP] Member
    CA
    09 Black TRD PreRunner Access Cab
    I am looking for some rock sliders for my 09 Access Cab. I really like the Shrockworks sliders, but I would prefer something that doesn't require drilling the frame. Does anyone know of a no-drill option for rock sliders/rock rails? I want small round tubing like the Shrockworks design.
    Edit: I'm looking for bolt-on sliders, but something that bolts to existing holes.
  2. Jan 5, 2009 at 2:37 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    I belive the shrockworks sliders are goin to be the best bolt-ons your goin to get, Others are goin to be weld-on like allpro's
  3. Jan 5, 2009 at 3:26 PM
    weihenstephaner
    weihenstephaner Well-Known Member
    Atlanta, GA
    2009 4x4 TRD OR DC SB Mag Grey (SOLD)
    Bought a Tundra
  4. Jan 5, 2009 at 3:36 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Jason
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    I think he's looking for weld-on sliders...
    Probably pretty much all of them could be welded on whether they're bolt on or not...
    All Pros can be bolted or welded (mine are welded
    Shrockworks (bullet proff but LONG wait)
    Demello
    to name a few...
  5. Jan 5, 2009 at 3:38 PM
    jckid
    jckid [OP] Member
    CA
  6. Jan 5, 2009 at 3:40 PM
    jckid
    jckid [OP] Member
    CA
    Actually, I guess I should have clarified...I want bolt on sliders, but ones that bolt up to existing holes. I don't want to drill or weld.
    ChadsPride likes this.
  7. Jan 5, 2009 at 3:42 PM
    LonghornTaco
    Jason
    Minnesota
    Whoops! The shrocks bolt to existing holes on the side of the frame but require 6 holes on the underside (or so Silverback says...).
  8. Jan 5, 2009 at 3:52 PM
    SnoBoarder
    SnoBoarder Hardcore wheeler, try and keep up.... if you can.
    Lost
    85 4Runner - Built not Bought
    :thumbsup: Demello's Bolt-ons
    Mine are being built this week! :D I bought the Bolt-ons but requested semi gloss powder coat black instead of wrinkle finish as pictured. Jason goes out of his way to use factory frame holes plus he clearences the gussets for existing rivets so you don't have to grind them down. It is recommended that you drill the holes for the bottom mounting bolts for maximum strength.
  9. Jan 5, 2009 at 3:52 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    good luck man, ive been looking for the same thing shrocks take about 9-12 weeks to get after order if i was you i would look at demello offroad and get bare metal theyre having a special on them 375, but you will have to spend 10 mins and drill 3 holes on each side. from what ive heard its not hard to install or drill the holes
  10. Jan 6, 2009 at 4:45 AM
    RCBS
    RCBS How long you willing to tolerate this crap??
    Harden your bark, there are storms on the horizon.
    Goodbye 06, Hello 21. TRDORDCSBMT
    Tornado intake, Duralube, Fartcan.
    X2. if you aren't going to bash on em' you'll probably be ok w/o the bottom bolts...they are the ones that require drilling. frankly man, just get the Shrocks or Demellos and drill the six holes...it don't hurt that bad after the first one :) i've not seen any that don't require ANY drilling.
  11. Jan 6, 2009 at 4:54 AM
    SnoBoarder
    Lost
    I'm drilling the extra holes without question. I have some brand new titanium bits ready for the task. Thanks because that reminds me that I need to borrow the electric drill for next week. Cordless drills and dull bits are not up for the task for frame drilling. :D
  12. Jan 6, 2009 at 6:30 AM
    ETAV8R
    ETAV8R Out DERP'n
    Republik of Commiefornia
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    wow, those slee ones are badass...way costly though. anyone here have them? pics?
  13. Jan 6, 2009 at 11:38 AM
    RCBS
    i drilled mine w/a Milwaukee 18v cordless...no problem. good bits, slow speed and cutting oil. a carlift helps...don't forget to sheild your eyes.
  14. Jan 6, 2009 at 12:24 PM
    SnoBoarder
    Lost
    I don't have an 18V (wish) but I'm thinking the cutting oil will ease the pain. Good idea. Thanks!
  15. Jun 17, 2010 at 6:01 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    Reviving an older thread. Anybody make sliders without drilling yet?
  16. Jun 17, 2010 at 6:09 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Search "sleeve" type sliders. If you find anything about revenge fab- skip those. But you'll get the idea.
    They have a boxed end with bolt holes over the top of the frame- Might be what you are looking for...
  17. Jun 17, 2010 at 7:02 AM
    vermintrex
    vermintrex Well-Known Member
    Vancouver
    TRD SPORT Shorty
    BFG A/T KO 265/70/17, '11 FJ wheels, 5100's all four corners, Eibach springs, 1/4" Taco lean spacer, Leer 100XR, WeatherTech liners, trimmed mud flaps and I farted in it.
    Have a look at Avid, they have sliders that bolt onto the factory running board mounting holes. They do make a point of explaining that the bolt on's are not intended to support the weight of the truck. They have weld on sliders too.
  18. Jun 17, 2010 at 9:28 AM
    Manwithoutaplan
    ID
    Mine are East Coast Gear Supply Sliders and i weld them on.
  19. Jun 17, 2010 at 10:49 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    I will be working on a way to use u-bolts and plates to clamp them on to the frame. I'm going to do all the fab work myself. I'll post some drawings when I figure it out.
    Don't hold your breath. Prodjects take a backseat to my job and sidejobs.
  20. Jun 17, 2010 at 10:49 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Don't hold your breath. Projects take a backseat to my job and sidejobs.
