4'' Lift on 05 2wd Prerunner. will this work?
Old 07-17-2012, 03:57 PM   #1
Tunajoe13 [OP] Tunajoe13 is offline
Tunajoe13 is just really niceTunajoe13 is just really niceTunajoe13 is just really niceTunajoe13 is just really niceTunajoe13 is just really nice
Tunajoe13's Tacoma Gallery
Hello
Looking to lift my 05 2wd Prerunner will Camburg's 4'' lift spindal kit in the front and Allpro's expedition 3'' leaf pack kit in the rear. Apparently the expedition leaf pack will give 4'' of lift without 400-500lbs of load in the bed. Both lift kits come with extended brake lines.
My questions are...
1. Do i need front coilovers with a spindal lift right away or can I wait a bit using factory shocks?
2. What will be my max rim and tire size? (Im looking to rock 33's on 20's or 18's).
3. How much total lift would I actually be getting with lift and tires?
4. Will I need back spacers?
5. Is there anything else I'll need that im forgetting right now? LOL
This is my first lift and I wanna do it right. Thanks all!
Old 07-17-2012, 03:59 PM   #2
BulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shed
Name: You can call me Susan if it makes you happy.
Gender: Trans
BulletToothTony's Tacoma Gallery
First off good choice on lifts, you dont need coilovers right away so your good there. You will be able to run 33's and if you want to trim and cut alot your can run 34's and even 35's . You will get 4 inches of lift from teh spindles and a maybe and inch or more depending on the tires you get. Spacers will be dependent on the offset and backspacing or your rims you get....
Only i can see you might be missing is extended brake lines... other will add if i missed something too
Old 07-17-2012, 04:10 PM   #3
Thanks! I forgot to mention that they both come with extended brake lines. So with adjustable coilovers and rear blocks I could get even more out of that lift?
Old 07-17-2012, 04:12 PM   #4
Gender: Trans
Mmm im not sure check some of the threads about spindles (im 4x4 so i dont know everything about them) but the more preload you put on coilovers the stiffer the ride....
2wd prerunner lift question 05yota 2nd Gen. Tacomas 10 01-11-2011 08:33 AM
07 Tacoma Prerunner (2wd) w/ lift, 20k, Silver Spring, MD TYM2JET Buy / Sell / Trade 4 01-03-2011 05:34 AM
2wd non prerunner lift? OLDSKOOLRACER 1st Gen. Tacomas 3 08-16-2010 10:33 PM
suspension lift for 03 taco prerunner 2wd socal19 1st Gen. Tacomas 9 03-15-2009 12:53 PM
Lifting a 05+ 2wd tacoma non-prerunner more then 2.75 inches jwjknorr Suspension 3 02-12-2009 03:39 PM
